#122 (permalink) |
did my first oil change on my 07 SI...drain bolt was easy to loosen..it was the oil filter that gave me a hard time. what a surprise! i knew it was going to from reading the threads. i bought the "key" from walmart...plastic piece of crap in my opinion although it was the right size it kept slipping because there are too many angles on the oil filter. i turned the wheels all the way to the left and just got in there with my right hand where the axle is. i bought a special oil filter wrench where it has 3 hooks that expand and contract that attach to a ratchet. got a real nice grip from that and gave it a few tries and it popped loose. success!! bought it from pepboys if anyone wants to know. they also have it at sears too. did the freeze bag trick and it worked wonders. no spillage. i actually spilled some oil when taking the drain plug out...kinda splattered. stupid oil filter!! it was def on tight. i put in 5 quarts of mobil 1 5w-30..i know some ppl on here say 5-5.5 but the manual reads something like 4.8 so i went safe and kept 5. all in all it took almost the whole day! cuz i was running back and forth from the store for the right oil filter wrench but once it came off..it was cake. just had to wait for the oil to drain. GL to first timers on the oil change..it will take some time for sure. but success is inevitable
#123 (permalink) | |
2007 civic si coupe @ i spent about 40-50 minutes trying to get the filter off from behind the right wheel while having the steering wheel turned all the way to the left as others had described and it ended in frustration, so i grabbed my laptop and went outside and sat next to the car and found this post. took me like 5-10 minutes to get the filter off this way with enough clearance for an oil wrench. wish i would have found this post first as it would have saved me 40-50 minutes and a ****load of aggravation. this method would have had me with an engine full of 5 quarts of mobil 1 EP 5w-30 ($24.95 - walmart) and mobile 1 EP filter m-110 ($10.99 - autozone) filter during my one hour lunch. from start to finish took me around 20-25 minutes doing it this way vs. the lost 40-50 minutes going from behind the right wheel. note: called a mobil 1 lube express and they quoted me between $70-$80 for 4 quarts mobil 1 5w-30 oil change and from $90-$100 :SHOCKED: for 4 quarts mobil 1 5w-30 extended performance oil change. DIY cost $10.99 for the filter + $24.95 for 5 quarts of mobil 1 EP for a total of 25 minutes, a shower and less than $36. thanks man! |
#124 (permalink) |
I'm a little confused...after reading the first post it says to buy a washer for your drain bolt...when I did my first oil change I'm pretty sure I used a new washer for the filter and not the bolt...
#129 (permalink) |
Andrew
Just did my first oil change tonight and all I have to say is... WHO EVER PUT THE OIL FILTER ON AT FACTORY, SCREW YOU A$$HOLE!!!!! I know it was going to be a pain reading all the posts but jeeeez, it took me forever to get that damn oil filter off on my Si.
#136 (permalink) |
DO NOT USE THAT!!! i bought one of those from walmart and since the oil filter has a plastic lining....the key slips around the filter. basically it doesn't have a good grip. try buying the retracting claw looking thing. sorry not sure what its called but u attach a ratchet to it. works like a charm..with a little muscle.
#137 (permalink) | |
R18 FTMFW
there is a way to get the filter out without having to take off your wheel... you pop your tool on the filter then scoot toward the back of the car a little bit more.... there is a bigger hole that you can actually see the filter throu... then snake your hands in there and unscrew the sum b!tch.. i can take pics if ya guys want... but not till tommorw afternoon.... |
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/18649-oil-change-diy.html
| Oil change question... - 8th Generation Honda Civic Forum | This thread | Refback | 01-16-2008 03:51 PM | |
| Oil Change DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-10-2008 12:39 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-09-2008 12:23 PM | |
| Oil Change DIY - Page 2 - 8th Generation Honda Civic Forum | This thread | Refback | 12-27-2007 07:55 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 12-21-2007 05:45 PM | |
| Oil change DIY? - 8th Generation Honda Civic Forum | Post #0 | Refback | 12-05-2007 03:25 PM | |
| Oil Change Info. | jc21 | Mechanical Problems & Technical Chat | 42 | 06-14-2010 09:30 AM |
| Oil Life | Elmacho | Civic SI | 33 | 01-05-2009 09:36 PM |
| Everything Oil: All you'll ever wanna know | atruhondagrl | Bolt-Ons And All-Motor | 14 | 06-16-2008 01:45 PM |
| Recent oil change with lab results | ChristopherSi | Garage | 12 | 11-03-2006 01:43 AM |
| Oil change DIY? | letsgoflyers81 | Do It Yourself Articles | 21 | 10-11-2006 11:07 AM |
