#42 (permalink) |
Ramp SI clearance and Jack-stands.
Can anyone point me specifically to a ramp that they know first hand to be quality and be graded to allow proper clearnance for the SI's relatively low height?
My dad walked me through this on the first oil change - but we were going to use his ramps, unfortunately the front of my SI couldn't quite clear the ramp he had, so we ended up just jacking it up and putting it on stands. I figured the ramp would be the fastest/easiest way to change the oil but... Also, with a ramp, is it really necessary to use jack-stands with it? That's fine if thats the case, I just figured the ramps were solid enough, but I really don't know. thanks, .jeremy |
#43 (permalink) | |
Doh!
#44 (permalink) | |
![]() Join Date: Feb 2006
if you use ramps you do not need to use jack stands because the ramps are designed to support the vehicle on their own, just make sure you put on the parking brake and chock one or both of the rear wheels |
#47 (permalink) |
thank you all!! I went to a garage today, they charged me $15 only to lift the car.. WTF lol
they had some power tools there, so I could remove the drain plug ![]() After the oil change I can feel something is smoothier.. ![]() Lets see when cold comes (night). next step = MTF
#54 (permalink) |
I put 4 quarts in my EX and it seemed kinda low. What did everyone else with EX's put in.
BTW, did my first DIY change last Friday. Not bad but the oil filter was a ***** to get loose with my filter wrench (which worked fine for my PT Cruiser I used to have but is too big for the Civic.) |
#55 (permalink) | |
#56 (permalink) | |
Andrei
#57 (permalink) | |
Andrei
#59 (permalink) |
I laugh at ricers.
FYI. The oil plug needs to be tightened to 29 ft lbs of torque. Just because there is a crush washer doesn't mean to crank it down. 29 ft lbs of torque is finger tight then about 1/3 of a turn. The threads of the plug are very soft and can be stripped very easily. A $30 torque wrench is much better than $500.
#60 (permalink) |
Randy
I did my first oil change on my 07 si sedan yesterday. The car has 750 miles on it, and I wanted dino out and synth in...
I think it is fairly clear that Honda intended the right front wheel to be off and the fender liner piece out in order to get to the filter easily. What a horrible design! Nothing like in the BMW where the filter is right on top of the engine compartment in a metal cannister... I am glad that I switched to synth as I am doing a track day in April. Now on to the brakes... |
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/18649-oil-change-diy.html
| Oil change question... - 8th Generation Honda Civic Forum | This thread | Refback | 01-16-2008 03:51 PM | |
| Oil Change DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-10-2008 12:39 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-09-2008 12:23 PM | |
| Oil Change DIY - Page 2 - 8th Generation Honda Civic Forum | This thread | Refback | 12-27-2007 07:55 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 12-21-2007 05:45 PM | |
| Oil change DIY? - 8th Generation Honda Civic Forum | Post #0 | Refback | 12-05-2007 03:25 PM | |
| Oil Change Info. | jc21 | Mechanical Problems & Technical Chat | 42 | 06-14-2010 09:30 AM |
| Oil Life | Elmacho | Civic SI | 33 | 01-05-2009 09:36 PM |
| Everything Oil: All you'll ever wanna know | atruhondagrl | Bolt-Ons And All-Motor | 14 | 06-16-2008 01:45 PM |
| Recent oil change with lab results | ChristopherSi | Garage | 12 | 11-03-2006 01:43 AM |
| Oil change DIY? | letsgoflyers81 | Do It Yourself Articles | 21 | 10-11-2006 11:07 AM |
