Oil Change DIY - Page 19 - 8th Generation Honda Civic Forum
LinkBack (6) Thread Tools Display Modes
Old 03-06-2010, 01:00 PM   #361 (permalink)
Just did my mind for the first time. Easiest oil change I've ever done but you will DEFINITELY need some type of wrench to get the factory filter off. Advance Auto Parts didn't have an exact fit socket-type wrench but they did have this: Oil Filter Wrench by Performance Tools - Part W173C/T70426 - Advance Auto Parts
Very handy and it should fit just about any filter.
robm3 is offline   Reply With Quote
Old 03-06-2010, 01:34 PM   #362 (permalink)
alinktothepast's Avatar
Logan
^^ I didn't buy a filter wrench. If I can't manage to loosen the filter by hand. I take my belt off (the leather belt on my pants) and sinch that around it. Works exactly the same way plus its pretty much free.
alinktothepast is offline   Reply With Quote
Old 03-09-2010, 12:00 AM   #363 (permalink)
Vash
very nice
Vash is offline   Reply With Quote
Old 03-18-2010, 06:01 PM   #364 (permalink)
Matt
Alright I've searched all over and I know I saw this part on the forum somewhere. I'm looking for a quick release type oil drain plug. It looks basically like a quarter turn valve so you can just flip the valve and the oil comes out without the need of tools. Can anyone point me in the right direction?
ciprich211 is offline   Reply With Quote
Old 03-18-2010, 11:32 PM   #365 (permalink)
asndragonboii's Avatar
I think it's called Fumuto or Fumoto or something like that
Old 05-06-2010, 11:54 AM   #366 (permalink)
Anyone ever hear from the dealership that 5 quarts isn't enough for the Si? I thought it took ~4.6 quarts, but the dealership told me 5.3.
mike120886 is offline   Reply With Quote
Old 05-07-2010, 03:07 AM   #367 (permalink)
drahgon's Avatar
Daryl
i put more then 4.6 qts in whenever I do my oil change, 5.3 sounds about right...
drahgon is offline   Reply With Quote
Old 05-13-2010, 04:09 PM   #368 (permalink)
Can someone confirm about the K&N HP-1018 Oil Filter. I got it from Amazon and not sure if I can use it - seems too big. '09 Civic EX Sedan.
Thanks.
evox2008 is offline   Reply With Quote
Old 05-22-2010, 07:26 PM   #369 (permalink)
vtaakalldayerrday's Avatar
wat engine cleaner oil is good????
vtaakalldayerrday is offline   Reply With Quote
Old 05-22-2010, 10:07 PM   #370 (permalink)
av911's Avatar
Change to synthetic.
Old 05-23-2010, 10:19 AM   #371 (permalink)
The dealership always charges me 5 qts of oil.. And when I brought them 6. Qts they only used 5...
dc5rn is offline   Reply With Quote
Old 05-24-2010, 04:42 PM   #372 (permalink)
lols no i meann when u change oil
ofcourse fullsynthetic but after ders a small bottle
i forgot watchu call but it soppose to clean da engine,fuelpump n wateverss
im asking wat is a good brand lols
Old 07-26-2010, 07:45 PM   #373 (permalink)
jchanggg's Avatar
R18 Crew Member #271
my car is at 20% for my oil change but i basically no nothing about cars and im planning on trying this soon is there anything i need to know besides from this DIY?
jchanggg is offline   Reply With Quote
Old 07-26-2010, 11:24 PM   #374 (permalink)
Make sure the car is safely supported.
Remove Oil cap from valve cover
Remove drain plug, let all oil run out until its like drip drip drip
Then replace Drain plug, before u do clean the threads and washer.
Snug the drain plug, don't try to torque it down.
Remove old oil filter, and spread a little oil on the new filters O ring so the filter can be removed very easily next time.
Snug it on good also.
Fill engine with oil, On my GF's r18(lx,dx,ex) I put about 4.5ish My Si I put almost the entire 5 quart jug.
Reinstall filler cap
Lower car, Start it up and let it idle for 20 seconds and then reset you Oil indicator, I think you hold both buttons, look it up.
sisean is offline   Reply With Quote
Old 07-27-2010, 01:11 AM   #375 (permalink)
I just let the dealer change my oil.
VTECHFTW is offline   Reply With Quote
Old 07-27-2010, 09:51 AM   #376 (permalink)
DUI Elite's Avatar
(R18 Crew # 049) BMW owner
^lol good post in a DIY thread budd..
DUI Elite is offline   Reply With Quote
Old 07-28-2010, 05:36 PM   #377 (permalink)
say55ow's Avatar
If you drive an SI..
remove the right wheel, that way you have easy access to your oil filter.
Good luck.
say55ow is offline   Reply With Quote
Old 09-29-2010, 08:27 PM   #378 (permalink)
Good luck.
Surprisingly, my oil filter was a piece of cake. I removed the passenger side front wheel, sat on my butt with the brake disc basically above my lap, and just reached in with my right hand. I was able to get an easy grip on the filter and loosen it easily. The drain bolt on the other hand, that freakin thing has to be welded on there. It is definitely too tight to do with a breaker bar in a driveway. The manual says its torqued to 29ft.lbs., but it has to be tighter than that. I put what little ass i had into it, and it didn't even creak.
countit178 is offline   Reply With Quote
Old 11-10-2010, 12:55 PM   #379 (permalink)
What is the best oil (type/brand) and oil filter? Does it really make a difference of what type you use.... What has your experience been?
sawman5 is offline   Reply With Quote
Old 11-10-2010, 01:11 PM   #380 (permalink)
RCHamel3's Avatar
Rob
When I first bought my honda and started doing research on the different oils and reg vs. synthetic, everyone has their own opinions. No matter what oil you use, your honda will last a long time if take care it.
The first time I went to the Honda dealer to get my first oil change years ago, i noticed they offered a mobil 1 synthetic oil. I looked into mobil 1 and everyone said great things about it. Its a better oil than the reg stuff and honda gives it the seal of approval(literally). For me, Mobil 1 is the best choice. Honda approves it and is readily available at any auto store, unlike Amsoil(not sold in local auto stores) which is another fav on this site.
RCHamel3 is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/18649-oil-change-diy.html
Oil change question... - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 03:51 PM
Oil Change DIY - 8th Generation Honda Civic Forum This thread Refback 01-10-2008 12:39 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-09-2008 12:23 PM
Oil Change DIY - Page 2 - 8th Generation Honda Civic Forum This thread Refback 12-27-2007 07:55 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 12-21-2007 05:45 PM
Oil change DIY? - 8th Generation Honda Civic Forum Post #0 Refback 12-05-2007 03:25 PM
Oil Change Info. jc21 Mechanical Problems & Technical Chat 42 06-14-2010 09:30 AM
Oil Life Elmacho Civic SI 33 01-05-2009 09:36 PM
Recent oil change with lab results ChristopherSi Garage 12 11-03-2006 01:43 AM
Oil change DIY? letsgoflyers81 Do It Yourself Articles 21 10-11-2006 11:07 AM
