#256 (permalink) |
5 qrts gets me to the full mark on the dip stick......with a Mobil 1 filter.
I did my 9th oil and filter change last weekend and I used a set of ramps for the first time (the ramps get the front wheels up about 5" from the ground). All of my prior oil changes were done using jack stands (I'm not sure how high the front was up). Anyway, my Si took 5.25 quarts to get it to the fill mark (I checked the level both when hot and when cold). I found the need to add an add'l 1/4 qrt a little odd. I must just have to do with the ramps vs. place stands and the fact that I let it drain for about 1 hour vs. my normal 15 minutes. |
#259 (permalink) |
Sorry, I was not clear. It was on the ground (on a level garage floor) when I checked it. It was only on the ramps when I drained it and replaced the filter. I'm soooo extreme when I replace my MTF (it's up on four stands when I pump the new fluid in) that I actually check the front to rear and left to right level using a 4' long carpenters......and shim the jack stands accordingly.
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/18649-oil-change-diy.html
| Oil change question... - 8th Generation Honda Civic Forum | This thread | Refback | 01-16-2008 03:51 PM | |
| Oil Change DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-10-2008 12:39 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-09-2008 12:23 PM | |
| Oil Change DIY - Page 2 - 8th Generation Honda Civic Forum | This thread | Refback | 12-27-2007 07:55 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 12-21-2007 05:45 PM | |
| Oil change DIY? - 8th Generation Honda Civic Forum | Post #0 | Refback | 12-05-2007 03:25 PM | |
| Oil Change Info. | jc21 | Mechanical Problems & Technical Chat | 42 | 06-14-2010 09:30 AM |
| Oil Life | Elmacho | Civic SI | 33 | 01-05-2009 09:36 PM |
| Everything Oil: All you'll ever wanna know | atruhondagrl | Bolt-Ons And All-Motor | 14 | 06-16-2008 01:45 PM |
| Recent oil change with lab results | ChristopherSi | Garage | 12 | 11-03-2006 01:43 AM |
| Oil change DIY? | letsgoflyers81 | Do It Yourself Articles | 21 | 10-11-2006 11:07 AM |
