#141 (permalink) | |
u remove it from under the thottle body but have a rag or something ready cause the coolant is going to come out of it and quite a bit of it. all the hoses that are on that one piece (the like double metal one) will be removed and replaced |
#142 (permalink) | |
Have the replacement tube nearby, because it'll be dripping loads of coolant otherwise. ![]() Obviously the lower square points to underneath the throttle bottle, like the picture you attached before. The upper square is where the tube should be connected to.
#143 (permalink) |
oh and the instructions say to leave it in 5th gear (don't know why but if someone could explain that be great) before you tighten everything up.
i didn't, i accidentally left it in 4th, no reason jus was there when i went to turn it on after the install. test drove it after install and it shifts the same. drove to work last night and back and its fine. however, i would like to know why it says dat |
#151 (permalink) | |
so how does she run now?? |
#152 (permalink) | |
I can definately feel the increased mid-range power, and the sound is incredible. |
#153 (permalink) |
oh yea dat sucks. i took it off then got the splash, got scared and put it back in, went n grabbed a rag, took it back off and put the new one on wit the wrong size clamp also. luckily i had some other lil clamps around the garage.
atleast you got it on and it works great. congrats on you're cai diy. |
#156 (permalink) | |
https://www.dragraceinc.com/INJ-SP1578.html it says its $270...but once u hit checkout, at the last page when you enter ur credit card number it gives u 5% off for some reason! |
#158 (permalink) | |
#160 (permalink) |
If you are interested in getting one and need info about whether it will fit ask Dan from Wesellcarparts.com. They are a site sponsor and have a great price. Plus, his customer service is excellent. I had a problem and he has helped me get everything straight with no fuss.
Good luck. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
