LinkBack (9) Thread Tools Display Modes
Old 05-05-2007, 01:55 PM   #81 (permalink)
dust0ut's Avatar
Dustin
nothing at all hitting the cables or selector.
dust0ut is offline
Old 05-11-2007, 04:23 PM   #82 (permalink)
Tad Broughton
How long does it take to install this? Got mine in yesterday and wanna know if I'll have enough time to do it after work before it gets dark
ensoniq is offline
Old 05-11-2007, 04:56 PM   #83 (permalink)
I C U !!!
06blaksi's Avatar
Muffin Eater
Took me about 2 hours to do
Priscilla
Come to 8thcivicfest....watch Rick take my eyelids off!!!
Originally Posted by SoCal07Si View Post
are u guys blind? Of course thats a 4" drop. 1" on each wheel
06blaksi is online now
Old 05-11-2007, 04:57 PM   #84 (permalink)
I C U !!!
06blaksi's Avatar
Muffin Eater
I also had to run to the parts store for clamps!
Priscilla
Old 05-11-2007, 04:58 PM   #85 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
If it's your first time doing it, 3 to 4 hours. The process is just lengthy because you're figuring out what to remove for the first time and so on. Once you're done the installation, you'll probably think it could be done in 1hour and 15 minutes or something.
Yodums is offline
Old 05-11-2007, 05:02 PM   #86 (permalink)
Tad Broughton
First time on this car.... Done a 03 Tiburon GT and a 2000 Si before
ensoniq is offline
Old 05-11-2007, 05:04 PM   #87 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
I say 1.5 hours tops then. I mean it's just removing the old airbox and putting in the CAI.
Yodums is offline
Old 05-11-2007, 05:36 PM   #88 (permalink)
Tad Broughton
Aight, headin out to the auto store to pick up some clamps and a shop light ( in case it gets dark on me ) ..... Let you guys know how it went when Im done! 06blaksi thanks for the DIY should allow me to burn thru this
ensoniq is offline
Old 05-12-2007, 12:22 AM   #89 (permalink)
Tad Broughton
Took about an hour and 20 mins... I played with removin the bumper for a good 15... Found out the Sedan doesnt have the 2 bolts to remove underneath by the fender well.... Pity you cant see the damn thing and all its chrome glory =/ ... but sounds badass and I can feel a slight boost in power... Thanks guys!
ensoniq is offline
Old 05-12-2007, 12:28 AM   #90 (permalink)
dust0ut's Avatar
Dustin
^^ LOL I spent FOREVER looking for these two bolts. I was going crazy haha. I'm such a n00b
dust0ut is offline
Old 05-12-2007, 12:41 AM   #91 (permalink)
Tad Broughton
Yeah, I started getttin pissed... but decided to grab a beer calmed down and saw there were 11 push tabs not 7 holding my bumper in place...and zero bolts ! felt like an idiot for not catching it sooner ;p
ensoniq is offline
Old 05-12-2007, 12:48 AM   #92 (permalink)
Andy
I had 9, no bolts, but theres no hole for the vibra mount (I have an FA5) but its all good, I'm just gonna shove some 2 sided tape where the intake touches and I should be fine... no cutting involved here, just carefully sliding it in...
axtran is offline
Old 05-12-2007, 12:53 AM   #93 (permalink)
dust0ut's Avatar
Dustin
That's very strange...there should be a hole lol
dust0ut is offline
Old 05-12-2007, 12:56 AM   #94 (permalink)
Andy
was there a hole on yours? damn it now i have to take apart my car again???
axtran is offline
Old 05-12-2007, 12:59 AM   #95 (permalink)
Tad Broughton
The hole for the vibramount was an existing screw hole that held the resonator box in place..... and I wasnt gonna cut at first but I wanted my intake backed off anything metal.... I had an injen on my old 03 Tiburon GT and it rubbed a hole in it... if its the double sided mounting tape ( foam core ) it will wear down over time. Just double check for the screw pnt for the vibramount!
ensoniq is offline
Old 05-12-2007, 01:06 AM   #96 (permalink)
dust0ut's Avatar
Dustin
dust0ut is offline
Old 05-12-2007, 11:31 AM   #97 (permalink)
Andy
I probably didn't see it because it was so dark. I guess I am dismantling the bumper again! hehe, thanks guys.
axtran is offline
Old 05-17-2007, 12:13 PM   #98 (permalink)
can anyone recommend a good website or place to order this intake? and how much is a good deal?
joenguyen is offline
Old 05-23-2007, 08:36 PM   #99 (permalink)
ABQSI's Avatar
Dustin
Well I just did my Injen CAI install today. Pretty painless for the most part, did have to cut a bit more plastic than I expected. That probably has to do with the fact that I have the Sedan and not the Coupe... perhaps slightly different dimensions. Anyone else have this issue?
Also, with regards to the clamps not fitting, Injen supplies braided hoses with the intake to replace the stock hoses, which were not braided. In the installation instructions, it says only to clamp the one hose that runs coolant to the TB, but it doesn't say anything about clamping the other two that connect to the intake itself. I didn't clamp those two and all seems fine.
All in all a great mod! Love the sound, and the car definitely has more kick at upper altitude now (I live at 8000 ft). I can't wait to drive into the city and see how she runs at 6000 ft!
ABQSI is offline
Old 05-23-2007, 11:26 PM   #100 (permalink)
ABQSI's Avatar
Dustin
Is your battery "+" cable in the way? Mine was in the way after I finished my install... I could feel it when I tried to shift into 1st or 3rd gears. Moved it, and no more problem. I know you said nothing is in the way but you should be able to shift into 5th at a stop.
ABQSI is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/18536-diy-injen-cai-install-si.html
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-26-2008 11:18 PM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 01:38 AM
DIY * Injen CAI install * Si - Page 11 - 8th Generation Honda Civic Forum This thread Refback 01-31-2008 03:02 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 08:17 AM
I'm noob with car shit so if anyone wants to drop a few pointers... - ClubCivic.com - Honda Civic Forum This thread Refback 12-31-2007 09:03 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 12-10-2007 02:59 AM
DIY * Injen CAI install * Si - Page 21 - 8th Generation Honda Civic Forum This thread Refback 12-09-2007 11:39 PM
Just Bought an Injen CAI - ClubSi This thread Refback 12-08-2007 05:28 PM
Just Bought an Injen CAI - ClubSi This thread Refback 12-06-2007 06:48 PM
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
