#122 (permalink) | |
Moises
Here are some images of the Denso fuel pump installed ![]() ![]() Please, bear in mind that I installed this pump because I changed to a fuel return line system with -6AN lines. The OEM pump was not enough with the new system. Last edited by PanamaSi2007; 06-19-2009 at 04:06 PM. Reason: insert images |
#123 (permalink) |
Bottles
Okay question im getting ready to install my jrsc and I dont have to crush the fpr and the kit comes with 650cc injectors. So is that saying that my injectors are are tuned to be running on a lower percentage or what ?
#125 (permalink) | |
Nick
You can order one from your local dealer. Its needed because the pump won't seal properly in the assembly without a larger oring. you'll have fuel blowing past it and your fuel pressure will be lower. |
#132 (permalink) |
:banned:
ok,I read a few pages and figured since it was'nt mentioned I'd ask,what is the higher HP rating the stock pump is good for?Would a full bolt-on N/A engine need a larger pump or wold stock handle it? I'd hope the stock one is good to at least 300WHP,boosted or not.
#133 (permalink) | |
Nick
#134 (permalink) |
ghetto fabulous
how are people getting the white plastic piece that holds the pump in place back on with the new fuel pump? the one with three clips directly beneath the rubber insulator part of the pump? the oem one has the same body dimensions, however the head of the pump is recessed in a little bit and the walbro is not, therefore it is near impossible to get the white plastic piece (clip) back beneath the fuel pump.
#138 (permalink) | |
Nick
the DIY shows you how to trim the rubber insulator so that the white plastic piece will clip back on. Don't get the install kit, you won't need it You definitely don't need a return line for this pump. itzmill-you might want to get on a jrsc thread, i don't know the answer. |
| DIY:FUEL PUMP INSTALLATION | BATANG CITY JAIL | Do It Yourself Articles | 8 | 11-14-2011 02:34 AM |
| walbro fuel pump | lbkeegan2003 | Forced Induction And Nitrous | 5 | 06-30-2008 01:29 PM |
| is there a diy for fuel pump removal? | honda06si | Do It Yourself Articles | 5 | 01-08-2008 12:44 PM |
