#101 (permalink) | |
![]() Join Date: Nov 2007
#102 (permalink) | |
i plan on boosting around 9psi but i already have a crushed fpr so i dont know if the reflash thats going to come with the comptech stage 3 would take into account the walbro pump and a crushed fpr... i think its gonna be designed for a stock pump.. reason i'm asking is do you think i would be better off replacing the crushed fpr to a stock one and using the walbro when stage 3 comes out or leaving the crushed one in and switching to the walbro as well. thanks. |
#103 (permalink) |
Nick
I don't know how they do it on a stock pump (i think they upgrade to the walbro too, i read a bunch of DIY on crsx). There are quite a few on here that had their stock pumps begin to fail, I'm one of them.
#104 (permalink) |
thats good to know. i'm gonna look into getting the walbro before i upgrade. i'm just confused as to whether or not i could leave my crushed fpr in or have to go back to the stock one if and when comptech comes with with the new stages.
#106 (permalink) |
Nick
My walbro is already failing, I ordered a new one and I'm waiting for it. I suspect it was either a manifature (?) defect or running seafoam that did it in. I ran seafoam before my stock pump ate ****aki too. So I am never running seafoam again. Everyone I have talked to is surprised the walbro failed, they are a very reliable pump. For now new walbro, then in the somewhat near future I'm going to do a return line/ext fpr.
#107 (permalink) | |
Location: AMERICA! I will bleed on Old Glory to make sure the stripes stay red.
Willie Mack
#110 (permalink) |
Mike Wagner
Okay guys i just read the whole thread and i wanna make sure that its fine to run this pump on my set up.
I have full bolt ons (i/h/e) with stock injectors (duh). But i am also running a 75shot of nitrous (will be upping to a 100shot with the pump) so is it okay to run this pump in my situation?? I mainly want it to make sure im going to have good FP when i spray the 100 shot but from what i read on here it should still be fine when im just daily driving...... |
#112 (permalink) | |
Mike Wagner
#113 (permalink) |
Nick
I don't know the juice so I have no clue. I would think you would need bigger injectors to take advantage of the extra fuel pressure while your on the spray, but then you would need some kind of management setup.
#114 (permalink) |
Seafoam should never go anywhere near you car EVER!!!! That **** is so bad for your motor. I witnessed an 04 Mazda truck go up in smoke from that crap. It was one of those Mazda crossover car/trucks. I can't remember the model name but it was kind of funny. It made this horrible snapping noise and it just shut down. The #3 cylinder rod just snapped and seized the motor instantly. The block was split and the entire motor was junk. It needed an entire long block. So use seafoam and ruin your motor. It's just as bad as those fuel system cleaners that you feed into your intake manifold to "clean" your motor. What a scam. Lol...I do those all day at work and they do nothing but increase the risk of blowing your motor to ****. Lol...
#116 (permalink) | |
Mike Wagner
so im going to assume its okay to use in my situation, casue my buddy has a Walbro255 for sale for $50 so i think imma go ahead and get it |
#117 (permalink) |
Good luck with that. I would never do that. As long as you use good fuel and oil and keep your oil clean you should be OK with carbon build up. How many miles on your car? You shouldn't have to clean carbon out of your motor yet. Even if you did have build up it would take years and at least 75K plus miles. At least in my experiences, that's what I found. Cheap no name brand gas is the leading cause of carbon build up.
#119 (permalink) |
i cleaned the carbon off my old b16 pistons by hand when i had my cylinder head off for machining. lol it took like an hour but my pistons were shiny and new again.
elbow grease ftw! :P |
| DIY:FUEL PUMP INSTALLATION | BATANG CITY JAIL | Do It Yourself Articles | 8 | 11-14-2011 02:34 AM |
| walbro fuel pump | lbkeegan2003 | Forced Induction And Nitrous | 5 | 06-30-2008 01:29 PM |
| is there a diy for fuel pump removal? | honda06si | Do It Yourself Articles | 5 | 01-08-2008 12:44 PM |
