#190 (permalink) |
i trimed the rubber a little bit and i didnt use the needle nose pliers. i cant stand the noise. walbro is making a lot of noise. its like your leave the microphone face infront of the amplifier. and i just got random all cylinders misfiring. i guess its the tune. btw after i installed the walbro fuel pump i feel lighter on the foot when i press down the gas pedal
#195 (permalink) |
Oriol
Yup, that's how I did it.
Nick, maybe you should add that to the first post. Separate the rubber from the assembly, then the whole thing will go in very smooth. I also added some grease to the threads, made the whole tightening process easier. From what I've seen, AFR's didn't change, or at least they are in the range. The pump is loud! ![]() Anything I should keep an eye on to make sure it's installed properly? Or what things to look for? |
#196 (permalink) |
Drew
I just did the install on my car this morning. I only notice to sound level of this thing when just turning the key and hearing the initial prime. Other than that I have to listen specifically for the whine which is tough even. Must be it's just a kind of tone certain ears are sensitive to.
#199 (permalink) | |
Nick
#200 (permalink) | |
btw my pump whines all the time. im not complaining the pump quality. i just dont like the whining. its just common |
| DIY:FUEL PUMP INSTALLATION | BATANG CITY JAIL | Do It Yourself Articles | 8 | 11-14-2011 02:34 AM |
| walbro fuel pump | lbkeegan2003 | Forced Induction And Nitrous | 5 | 06-30-2008 01:29 PM |
| is there a diy for fuel pump removal? | honda06si | Do It Yourself Articles | 5 | 01-08-2008 12:44 PM |
