Old 08-18-2008, 01:32 PM   #1 (permalink)
Kroze's Avatar
DIY: Oil change w/fumoto quick drain valve **PICS***
I can't believed it got 45k miles on it already. Still run like the day it came off the dealer. My average is 35-36mpg and this tank i'm getting 39mpg (I get ~410-430 miles between fill-up at 11 - 11.5 gallons)
Maintenance minder system told me it's time to change the oil.
Mobil 1 Synthetic & OEM Honda filter since day 1. I know it's just a Civic but I'm planning to get 300k miles out of this car without any major engine problem.
Jack the car up..
Remove the 710 cap.
Fumoto oil drain valve & oil filter
Flip the switch and watch it in action This thing makes oil changes a breeze.
Remove & replace the oil filter but make sure to put some oil into the new filter first & lube up the O-ring. Clean up any oil spills around the area with a shop rag.
Fill her up with only 4 quarts of oil...meaning you should have 1 quart left since it's a 5 quart container.
Reset the oil life by turning the key to "ON" position & holding the button as shown until the display starts to blink. Hold the reset button again to reset the oil life meter to 100%
Kroze is offline   Reply With Quote
Old 08-18-2008, 02:15 PM   #2 (permalink)
Kroze's Avatar
Just in case anyone is wondering...
You need the Fumoto 106 & the long extension.
The only difference between the 106 vs. the 106N is the nipple at the end as seen in this pic.
Old 08-18-2008, 02:45 PM   #3 (permalink)
kenchan's Avatar
nice job and DIY. always fun reading these.
that's a different oil filter wrench you got there. i use those larger channel-lock
looking ones. your engine room looks very clean too.
Old 08-18-2008, 02:58 PM   #4 (permalink)
Be a Man
cereal83's Avatar
How easy is it to flip the switch? Great DIY btw. Seems like it takes longer to jack up the car then do the oil change
cereal83 is offline   Reply With Quote
Old 08-18-2008, 11:23 PM   #5 (permalink)
so whats crackalakin
St Jude
[hwy]Hagen's Avatar
Hey-gen
very nice.
[hwy]Hagen is offline   Reply With Quote
Old 08-18-2008, 11:36 PM   #6 (permalink)
infiniti_4_life's Avatar
Artem
Not bad, altho my oil filters come off with just a little bit of pressure. I've done maybe 5,000 oil changes (worked in a shop and did a lot of repeat customers for years.) and never had any problems. The trick is to get them tight but not too tight. It takes practice
infiniti_4_life is offline   Reply With Quote
Old 08-19-2008, 02:36 AM   #7 (permalink)
can you please post a link to the correct one for a 2006 ex civic?
is this correct?
QuickOilDrainValve.com - the best way to change oil
gchang817 is offline   Reply With Quote
Old 08-19-2008, 02:38 AM   #8 (permalink)
Moderator
St Jude
ImTheVoiceOfGod's Avatar
Corsport Fanboi
Damn you R18s with your convenient oil filter placement.
Originally Posted by 2fast4u2 View Post
We don't ban members, they ban themselves.
ImTheVoiceOfGod is offline   Reply With Quote
Old 08-19-2008, 02:45 AM   #9 (permalink)
do i need one of the adapters?
Old 08-19-2008, 03:06 AM   #10 (permalink)
why is the extension needed?
Sle.simon is offline   Reply With Quote
Old 08-19-2008, 03:21 AM   #11 (permalink)
tomasro's Avatar
Turner
I think the space where drain bolt initially went has some of the oil pan hanging above it that would get in the way of the valve of the drain valve. The extension clears the valve from getting hung up when installing...I believe.
for those of use that maintain our cars, and don't like to be annoyed by things such as drain bolt torque settings, this is AWESOME. This is totally going on my christmas list!
update: get it here cheaper
Shop
tomasro is offline   Reply With Quote
Old 08-19-2008, 09:11 AM   #12 (permalink)
Kroze's Avatar
You turn the switch on & off with 1 finger. Jacking the car up & lowering it takes pretty much 70% of my time in changing the car's oil. If I have a ramp to drive the car up, it'll probably take me 5 minutes to change the oil.
Old 08-19-2008, 09:15 AM   #13 (permalink)
Kroze's Avatar
is this correct?
Yes that is the correct one...but it have the nipple at the end. You don't really need the nipple version.
You also need the "Long extension"
Old 08-19-2008, 09:44 AM   #14 (permalink)
Be a Man
cereal83's Avatar
How easy is it for you to hit a bump and then all the oil com spilling out?
Old 08-19-2008, 09:45 AM   #15 (permalink)
____________
0720Steve's Avatar
nice. i wanted one of these. might have to get one.
what would be nice is an oil filter relocation kit.....or a dual filter setup.
0720Steve is offline   Reply With Quote
Old 08-19-2008, 11:56 AM   #16 (permalink)
is this the long extension?
Old 08-25-2008, 09:29 PM   #17 (permalink)
____________
0720Steve's Avatar
which one do you need for the si?
Old 08-27-2008, 06:10 PM   #18 (permalink)
Tennisjon2002's Avatar
Tennisjon2002 is offline   Reply With Quote
Old 01-06-2009, 01:46 PM   #19 (permalink)
Thanks for posting this. I will be getting the quick drain valve. This will make things so much easier.
Mesajoejoe is offline   Reply With Quote
Old 04-03-2009, 02:10 AM   #20 (permalink)
kwonoh2's Avatar
Jason Ohhyun Kwon
nice write up
kwonoh2 is offline   Reply With Quote
Fumoto Oil Drain Valve tpofa-07LX Mechanical Problems & Technical Chat 5 04-20-2008 10:49 PM
Fumoto oil drain valve? Fixer Do It Yourself Articles 30 09-26-2007 06:59 AM
Fumoto Oil Drain Valve victor Mechanical Problems & Technical Chat 1 07-13-2007 04:47 PM
Replace Drain Plug with Fumoto Valve AtmcBlueEXNav Do It Yourself Articles 14 05-15-2006 06:06 PM
