#21 (permalink)
DP Squad Member #2
So....I swapped out my AEM intake for the Injen that arrived today and here's my initial impressions:
In short, both are pretty good products quality-wise. However, Injen put more time into research for theirs and it shows. Game, set & match to Injen--- |
#22 (permalink) |
^ Good post, stevieray.
For those interested I took several short vids of the car redlining with the CAI and made a compilation. http://youtube.com/watch?v=sbEbvWCNwrg |
#24 (permalink) |
Johmil
I'm thinking, once I get mine, seeing I have access to chaffing tape, I'll just wrap some of it around the area where the metals touch just like how I would at work with our planes.
#26 (permalink) |
Taken directly from their site:
14. Should I rotate my filter to get more longevity? This is actually recommended. Most vehicles have a particular area to draw air in from based on the filter surroundings and rotating the filter will keep it clean longer. 15. How do I know when to clean the air filter? How often you need to clean your filter will depend on the air and road conditions in your area. Most filters require cleaning before the dirt build up gets as thick as the wire mesh. The usual interval is 30,000 - 40,000 miles depending on driving conditions. We recommend that you check your filter about once a year in normal usage and once every six months if you are located in a dirty environment. If you are running with a cold air intake we recommend checking the filter every 10,000 Ð 15,000. Using a Hydro-Shield will reduce service intervals. 16. Can I use cleaning agents other than the Injen cleaner and oil? We highly recommend that you only use Injen Technology oil and cleaner. Injen Technology air filter is a specific mineral oil blended with special polymers to form a very efficient tack barrier. Standard petroleum products such as transmission fluid and motor oil will soften and destroy the filter bonding agents and sealed edges. Injen cleaner is a non-detergent degreaser. Solvents, gasoline and various house hold chemicals will harden the rubber seals causing the filter to distort and may affect the ability of cotton fibers to function properly. A mild detergent can be used in an emergency situation, but care should be taken to fully rinse and remove the soap. Removing soap from the filter can be extremely difficult or time consuming. Always ensure the filter is completely dry before re-oiling. 17. Can I use an air compressor to dry the filter faster? No, this can blow holes directly through the filter material and ruin the filter. Choose a warm sunny day if possible to clean the filter and let it dry naturally. 18. Should I hit the filter on the ground or use a brush against the screen to remove larger particles of debris? No, this could damage the filter base or top and tear holes in the cotton gauze. (see filter cleaning instructions provided with every kit or cleaning instructions on this web site). 19. How much oil should I use to re-oil my filter after it is cleaned? Surgical cotton air filters are extremely absorbent and will not require significant amounts of oil. Keep in mind very little oil goes a long way. Using a small bead of oil, run the bead up and down the filter pleat allowing time for the filter to absorb the oil and act as a wick. If after 10-15 minutes the filter has areas that look gray, add a small amount of oil in the gray or un-oiled area only. Never over oil an air filter. And you will need to remove the bumper for the filter or remove your front left wheel and go from the fender well. |
#28 (permalink) |
Tom Smith
Takes more time to take off the wheel and mess with the Fenderwell cover which also has to be removed in order to get to the filter. I would just take off the bumper. Takes about 10 minutes and it isn't difficult.
#29 (permalink) |
Alright, big problem so far...
Im in the middle of installing the Injen CAI in my car with only 2 hours left till work. I didn't think it would take this long. Anyway, im trying to line up the top piece of the CAI to the throttle body but it seems nothing is lining up right. If the top piece is connected to the throttle body it wont line up with the Vibra-mount, and vice versa. It's been about an hour messing with this thing and I can't seem to line it up at all... Seems like the pipe wasn't bent far enough. A quick reply would be very appreciated. |
#31 (permalink) | |
Tom Smith
PS: Did you take the bumper off? I highly recommend it. I makes the installation a lot easier than going through the wheel well alone. |
#33 (permalink) | |
Tom Smith
The CAI is a one piece design whereas the R-18 is a 2 piece. There is a lot more tubing on the R18 then on the K motor and you will hardly see the Cai tubing on the Si because it goes straight down towards the fender and bumper area which is a good thing as far as performance goes since the air has a shorter way to travel to get to the Throttlebody and hardly any tubing is in the hot engine compartment where the aluminum tube can get heated. So there are a few differences. Overall the Injen Cai is the best mod I have installed on my Si to date. Not much in way of looks but the sound and the performance gain was very noticable. And it sounds 10 times better than any Exhaust out there. True engine sound. Very Sweet when it hits VTEC ![]()
#35 (permalink) | |
Tom Smith
Definitely not factory. I changed mine to the Honda Fit horn. Better sounding than the Civic horn but still not great. I will get some Hella Highway Blasters as soon as the weather improves. |
#37 (permalink) | |
Tom Smith
Of course they will tell you that since they want to sell their filters if you ever need a new one. The one that comes with it should last a lifetime unless you have an accident. I would just clean it once a year and reoil it with K&N oil and you should be okay |
#38 (permalink) | |
#40 (permalink) | |
Tom Smith
Here is a link to his site: This is for the R18 http://www.corsportusa.com/store/cat...oducts_id=1067 This is for the K20 http://www.corsportusa.com/store/cat...roducts_id=819 Remember the price you see is shipped. No hidden charges. I am very happy with the Injen Cai. Great Performance and Fantastic Sound! |
| Pics from the K-series meet at Markham (lots of pics) | 954K20_SI | South | 20 | 02-09-2011 11:11 AM |
| what type of CAI is good for r18? | inasim | Intake & Spacer Discussion | 15 | 12-05-2007 07:42 PM |
| INJEN CAI AVAILABLE | whitecivicsi | Intake & Spacer Discussion | 47 | 07-09-2006 01:59 PM |
| Unboxing the Injen CAI non-Si w/ PICS | peliROJO | Intake & Spacer Discussion | 12 | 07-01-2006 02:16 PM |
| DIY install of new head unit in sedan UK/AUS | aussiebuddha | I.C.E., Electrical, Security, & Navigation | 4 | 04-04-2006 03:30 PM |
