#186 (permalink) |
Jeremy
The front and rear mounts are both on the bottom. The sides are up top. There is also something as having too much. The vibrations cause by an ETD are alot more mellow compared to having the Boomba mounts installed. If all you have is an intake and installing an ETD would eliminate your wheel hop when at the race track, then having Boomba mounts would be too much since you don't need such an aggressive modification to correct you problem.
#187 (permalink) |
![]() Join Date: Mar 2007
There are 3 motor mounts (that carry the weight of the engine) front and sides.
There are torque dampers that is the rear (oil pan) and top (near the top frame), which actually keeps the engine from rocking back and forth. Boomba is slightly more expensive than an ETD, so why not just get it? It gives you room for more mods down the line without worrying about wheel hop. I believe an ETD would have more vibrations than Boomba due to most of the support is coming from the top and the top torque damper is the closest to the firewall. |
#188 (permalink) |
i've had these for 2 weeks and from 1-2.5k rpms i notice its slightly louder but other then that its 95% just like i was before. its fantastic. vibrantions are nealry gone and the wheel hop is 100000000000000% gone. this is the best mod i have ever done.
#190 (permalink) | |
Jeremy
Alot of people don't get mounts because of the amount of engine vibration transfer into the cabin. That's like saying if your car was setup for road racing and your head had stock ports and a T-80 turbo was 10 bucks more than a Gt30R would you still get the T-80 turbo? Or if your motor was stock and you were replacing your clutch and a stage 3 unsprung clutch was 1 dollar more than an OEM replacement. Would you get it? You might but to each his own. Do what tickles your own pickle and no one elses. With that said, there IS such thing as having "too much". Haha wusup Ku, you caught me while I was making my post hehe Last edited by mad monkey; 05-04-2009 at 04:41 AM. |
#192 (permalink) | ||
The two torque dampers dampen the engine equally, right? So once you replace the top mount, the engine now transfers all the "movement" to the top one now due to it being stiffer. The top ETD now occurs pretty much the MOST of the load. Guess where the load is closest to? The cabin. So you were saying? |
#194 (permalink) | |
Jeremy
You quoted him and said your technical info as if you're really saying that the ETD transfers more engine vibration into the cabin than if you were to replace 3 motor mounts. If you are then I'm sorry to whoever reads your misleading information. But just like how you know of people with the innovative mounts, I know of people with the ETD and the boomba mounts. And not one of them have stated that the ETD gives off more vibration than the Boomba mounts. So what I'm saying is... There is something as "too much". Last edited by mad monkey; 05-04-2009 at 05:04 AM. |
#196 (permalink) | |
I've been in a car with boomba and 75a innovative and I honestly didn't know they had motor mounts until they told me. The torque damper however was a different story, I felt it.. subtle, but I knew it was there. Too much is subjective, if you want to reduce wheel hop with full mounts then do however way you want.. but for the money, Boomba beats an ETD anyday. |
#197 (permalink) | |
Jeremy
I've also been in cars with the ETD, dogbone and boomba mounts and I've noticed it right when they start their cars. And when the boomba mounts calm down after about 2 or so weeks of driving, they're still more noticable than an ETD coming from not just my mouth, but of the drivers that have done to the modifications also. You're right, too much is subjective and boomba mounts are not that much more than the price of an ETD, but like I said in response to you saying that there was nothing as "too much", whatever tickles your pickle. Last edited by mad monkey; 05-04-2009 at 05:13 AM. |
#198 (permalink) |
8thcivic Sponsor
![]() Join Date: Feb 2007
Dan
If you have these mounts, we would appreciate your review. If time permits, please write up a review for us so our customers know how others feel that already have them installed.
Offering Aftermarket Parts for All Automobiles at Low Prices - WeSellCarParts.com Thanks!
WeSellCarParts.com 2006+ Honda Civic Parts Page - Your Source for Car Parts. If you don't see what you need, just ask We are a large stocking distributor for Boomba Racing and PowerRevRacing! Shop WSCP.CO! |
#199 (permalink) |
Stephen
I'm sorry, but with an ETD installed, your front brace mount and rear oil pan mount are going to take MORE abuse since the etd is going to resist movement, therefore the top of the engine isn't moving as much, but the bottom of it most certainly is.
I had both an ETD on full stiffness and now i have boomba mounts. These mounts vibrate worse at all ranges of idle to WOT vtec, to taking off from a stop etc. The ETD was hardly noticable at all. |
| Boomba Motor Mounts Review | Bboy_Burst | Engine Swaps, Mounts, Pulleys | 280 | 10-23-2011 12:21 PM |
| New colors for Boomba motor mounts! | BOOMBA RACING | Boomba Racing | 73 | 06-07-2011 07:07 PM |
| Boomba Racing Motor Mounts??? | RGV-SI- | Engine Swaps, Mounts, Pulleys | 162 | 05-27-2009 12:43 PM |
| Innovative mounts review | Efi2nr | Bolt-Ons And All-Motor | 32 | 03-28-2009 01:32 AM |
