#22 (permalink) | |
#25 (permalink) |
DIY one myself
I had 2 sets of Hella Supertones - 1x on my Saab92x and this set now on my Civic. I also remove the connector from the old hors to make it a weasthertight connection with thte dual hellas' Im not sure why i can post a sep link but here it is anyways |
#26 (permalink) | |
Mounted with about 15 deg angle in towards the center ![]() Harness from OEM horn (modified) SPlit post fuse for dual horns
#27 (permalink) | |
You can also find it here (where I first learned of its existence): http://www.griotsgarage.com/catalog.jsp?&SKU=77505 and here: http://www.wolo-mfg.com/air.htm the latter of which I bought (on eBay). Will post pics of the install when I actually have the time to do it. |
#30 (permalink) | |
all you have to do is use a 3/16 drill - drill till about 1/2 thickness of white part and just pops out (its epoxied on) |
#34 (permalink) |
Its the additional bracket I would like to buy. I can see it on the parts page for College Hills Honda:
Genuine Honda Replacements Parts The one I want is #8, we have #6. Anyone have a way of finding out that part number? |
#37 (permalink) |
i just did a horn swap on my 08 civic sedan. I installed an 05 honda element horn, it was just plug and play, also spliced extra wire on to the wire before plug to keep stock horn hooked up also. Both horns sounded great together but i ended up unpluging the stock one.i thought it had a problem when i looked doors with key button the horns didnt honk. so i unhooked the stock one. I later realized the cause was the car trunk wasnt latched causing car not to lock or honk when pushing the key button. Oh well if i ever have the front bumper of again i will hook it all back up.
I also did a dyi installed home depot gutter guard sceen to help protect the ac condensor from flying objects. the lower screen is screwed on the backside with #10 washers on the screwheads. Believe it or not there are holes to screw small short sheet metal srews to hold the screen . the two top holes around the grill was a little more trickey, i had to drill some holes and ziptie the screen on. All and All things went well with the removal of the front bummper cover. I only lost one of the two philips screws that secere the bumper cover in the wheel wells. this hapened when i was trying to start thre screw, it fell inside . i may get a new one at the dealler but it doesnt seem really important the bumper removal pics were great Thanks Brad |
#38 (permalink) | |
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/9659-horn-swap-replacement-installation.html
| The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: civic horn question | This thread | Refback | 02-29-2008 08:35 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-06-2008 02:43 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-05-2008 09:52 PM | |
| I want a horn like this!! | Silver8th | Garage | 32 | 12-11-2007 10:17 PM |
| New Horn Ideas? | Silver Bullet | Garage | 24 | 06-24-2006 02:31 PM |
| Does your horn suck??? | freeurmind69 | Inside and Out | 16 | 06-20-2006 12:45 AM |
| Putting E46 M3 horn in the car | mmm def | I.C.E., Electrical, Security, & Navigation | 13 | 05-22-2006 01:56 AM |
| my horn was honking by itself | tallerthanu8807 | Mechanical Problems & Technical Chat | 16 | 04-28-2006 03:54 PM |
