Pinout for Aux Input on LX - Page 7 - 8th Generation Honda Civic Forum
LinkBack (9) Thread Tools Display Modes
Old 05-29-2010, 04:13 PM   #121 (permalink)
very interesting thread, but i still can't find a solution for my problem, i have a 09 civic lx which has a stock aux port connected to factory radio ( non nav), now i just purchased a nav online froma 07 civic ,and im installing it im trying to figure out a way before installing on how to keep my aux port working on it, now the nav doesn't have the aux bottom like the stock radio, so is their a harness or a way to connect it to my nav and instead of using the xm radio , use that for the aux so i can connect my ipod, i seen on a website a harness that looks useful [URL="http://www.tss-radio.com/honda-and-acura-harness-for-pie-auxiliary-inputs-p-3898.html?osCsid=8577a303fe2254da8f025fb49e18c850"] any help will be appreciated .
jacob650 is offline   Reply With Quote
Old 05-29-2010, 04:38 PM   #122 (permalink)
nav should support the aux input, it gets added as a tab in the audio source menu
Old 05-29-2010, 04:43 PM   #123 (permalink)
wow, sounds cool ill check that out!! thanks much!!
Old 06-23-2010, 03:25 AM   #124 (permalink)
Matthew
Ok so I'm having some Issues. I have Audio L and R connected to pins 13 and 14 using a 3.5mm to rca cord I just cut off the rcas and ran both wires into L and R. Now for pin 3 on the ground can that just go to a common ground cause I don't have a ground coming off the 3.5mm to rca thing. Either way the second I short pins 5 and 15 it switches to AUX, Should it do this? All I hear is a buzzing noise and no sound. What could be the problem here?
mdawg is offline   Reply With Quote
Old 07-28-2010, 01:44 PM   #125 (permalink)
gREg
so i did the install too but i have an issue... my wires were all different colors, and that COULD be it, but I think I found the right sets.
The problem is that when I have my ipod volume up past half way, I get fuzz through the aux now. So I have to turn my ipod all the way down and my stereo all the way up.
I used 24 gauge stranded wire, i dont know if thats why though. Also.... everyone's only using 5 of the 6 wires right? so whats the 6th for? Is it possibly a shield? I dont have a meter to check anything, im going on sound and advice on here.... anyone?
rockinroll_mister is offline   Reply With Quote
Old 07-28-2010, 05:51 PM   #126 (permalink)
gREg
well... i figured it out i think.... but im not happy...
when i use a cd player as my source audio instead of the mp3 player... i get a crisp clear bass signal and can turn it WAY up. so basically i think im SOOL when it comes to making my mp3 player sound great.
Old 08-08-2010, 02:15 PM   #127 (permalink)
jcole's Avatar
josh
reply to male and female for the splicing into the aux
my aux install :hey guys i know its a little late but, i have seen so many people ask about doin the female end and splicing and attaching to the car. so last night i got bored and figured id give it a shot so here it is lemme know if this helps or not.
pins are listed from left to right with the connector tab facing up
pin 1: right channel audio
pin 2: left channel audio
pin 3: audio ground
pin 4: not used
pin 5 connect 5 and 6 together to get to switch from cd to aux
pin 6: connect 5 and 6 together to get to switch from cd to aux
here is the connector that is needed for the aux cable to splice into, i cut the blue tape to get some slcak
then i cut the electrial tape to get some more to make life easy
youre suppoesed to conmect pin 5 and 6 together (to be able to switch from cd to aux so i just connected them with a smal wire and teped them up then i tape pin 4 to it also because its not used so i did it to get it out of the way for no confusion
here it is with all the wires stripped and ready to be connected
here is the femaile connector that your gonna need
here it is after its cut and stipped ( black and red are right and left ) (the open wire that is wrapped around everything is the audio ground)
then you need to figure out where u want to mount it .. as you can see in this pic i mounted right on the center console.. but something that make this easy just drill out a smaller hole than needed and because its surronded in rubber that has give in it you can slowly dremmel out how big you need it and slowly wedge it in there as i was starting to in this pic
after its all wedged in start connecting wires and putting everything back together and here is the finished product
here is the finished product with the male end plugged in not to shabby
let me know wat u guys think..... sorry about the crappy pics but its the stupid iphone for ya
jcole is offline   Reply With Quote
Old 08-16-2010, 10:23 PM   #128 (permalink)
Been wanting to do this for a while now so I read through this thread today and decided to give it a shot. Total cost - $2.99+tax.
Front panel connector from an old computer
Paper clip for pin 5 and 6 (TY for the tip whoever that was)
Radio shack part:
1/8" Stereo Panel-Mount Audio Jack (2-Pack) - RadioShack.com
Just need to clean it up now but it works perfect!
Thanks guys!
OhSixCivic is offline   Reply With Quote
Old 09-14-2010, 03:32 PM   #129 (permalink)
In the Honda procedure (in the pdf document) it says to disconnect the negative terminal of the battery. Is it really necessary. Did any of you guys make it work without touching the battery?
NO HAND is offline   Reply With Quote
Old 09-16-2010, 04:30 PM   #130 (permalink)
in the second set of pictures where you've shown how to wire it up, is the belkin charger you're using have a 1/8" output on it. All you have to do is hook your ipod up to the charger and the AUX will autmotically read it? Where did you get that?!
dus10 is offline   Reply With Quote
Old 09-16-2010, 04:38 PM   #131 (permalink)
i had one of these, it takes the line level audio off the dock connector and has a powered amp to bring it up to the level you want.
Amazon.com: Belkin Auto Charger for iPod (White): Electronics Amazon.com: Belkin Auto Charger for iPod (White): Electronics
its a older charger though so its not compatible with most of the current ipods (gotta love apple for that load of bs) I think it worked with my 160 gig classic, 1st gen touch but wouldnt work with my brothers 3rd gen touch.
I use a avic f700bt with the usb connection now so the ipod lives in the glovebox
Old 10-07-2010, 03:49 AM   #132 (permalink)
Hello
Hello all,
This is my first post here. I am from India and I drive a 2006 Civic 1.8 S-MT. It does not come with the Aux-in cable as I saw with you guys from the USA.
I am very keen to try this DIY this weekend. Just to summarize on what I've read so far, I would need:
  1. A Soldering iron
  2. A 3.5mm male to female cable
  3. Paper clips
  4. Lotsa talent (short supply here)
Is there anything I am missing here?
Kind regards,
Hiren
hirenmistry is offline   Reply With Quote
Old 10-11-2010, 12:43 AM   #133 (permalink)
yaahhhoooo!! I was able to get the AUX-IN done and it was not as hard as I had imagined.
Thanks to everyone for the tips. You guys are rockstars!!!
Cheers
Old 03-27-2011, 01:27 PM   #134 (permalink)
Help
I have a problem with my Honda Civic 2006, middle-eastern model
I can't find the plugs for the auxiliary wires.
Can somebody help me please
I took photos of the front and back of the radio, I hope it helps
Pinout for Aux Input on LX-1.jpg   Pinout for Aux Input on LX-2.jpg   Pinout for Aux Input on LX-3.jpg   Pinout for Aux Input on LX-4.jpg
fadster83 is offline   Reply With Quote
Old 03-27-2011, 01:40 PM   #135 (permalink)
you may not be able to do it the same way as the US model civics. Im assuming that the CD/AUX button you have alternates between the tape deck and the CD.
I think if you tap into those GA L+/L- and R+/R- wires running from the tape deck to the radio you might be able to add your own aux input that way
Old 03-27-2011, 01:47 PM   #136 (permalink)
Thank you ethlar for your help, will try these GA holes
Do you think I can use the same jacks for AUX and tape?
Old 03-27-2011, 01:56 PM   #137 (permalink)
i dont know, it depends on how the tape mode triggers. If you can activate tape without a tape in the deck perhaps, otherwise you might have to rig it in some way that turns off input from the deck but keep a tape in the thing to activate it and then send your aux audio on those lines
Old 04-13-2011, 12:35 AM   #138 (permalink)
runtohell121's Avatar
Aux input jack + FiiO L1 (Line Out Dock) for iPod.
runtohell121 is offline   Reply With Quote
Old 04-15-2011, 12:32 PM   #139 (permalink)
marcel56k's Avatar
Marcel
Ok. After hours and hours of research, there is an easy solution -- Scosche HAAXB. Then you connect it to a PAC AUX35 or Peripheral PDM35 (they are the same).
It's as easy as it gets!
Pinout for Aux Input on LX-scosche-haaxb.jpg   Pinout for Aux Input on LX-pac-aux35.jpg
marcel56k is offline   Reply With Quote
Old 04-15-2011, 02:54 PM   #140 (permalink)
why use that when every LX EX and Si from 2007 up has an aux built in?
the issue is the 2006 LX didnt come with one, it was an accessory you could add. Also i dont see where that HAAXB would plug in, i dont recall ever seeing a plug that would fit in in the back of a civic stereo
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/6171-pinout-aux-input-lx.html
HondaHybridClub.nl • View topic - AUX kabel (DIY) This thread Refback 09-12-2011 12:20 PM
Civic Aux Ba?lant?s? yada USB ! This thread Refback 08-26-2011 08:16 PM
Civic Type-R Owners Club & Forum • View topic - IiPod on standard stereo This thread Refback 08-10-2011 03:56 PM
Question about Honda Civic Auxiliary Input - Honda Civic Forum This thread Refback 07-25-2011 01:07 PM
: Aux-in how-to 4 door - Civinfo This thread Pingback 06-25-2008 12:49 PM
2007 Hybrid Aux Input - Civinfo This thread Refback 06-10-2008 02:15 PM
DIY AUX Input converter?? This thread Refback 03-04-2008 03:52 AM
Forum de Carros - Forum Carros WEB - Noticias automotivas - Noticias CarrosCarros - VW - FIAT - Honda - Toyota - Citroen - Peugeot - Ford - Comunidade Automotiva - Tuning - Spy Pics - Flagras e Segredos - Revista 4 rodas - Revista Auto Esport • This thread Refback 02-29-2008 04:27 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 01:20 AM
Center Console removal for Aux input install ethlar Audio 66 01-29-2012 08:36 PM
Should I get a Civic LX? Coupe blueoakleyz Civic Coupe And Sedan 7 04-01-2006 11:58 PM
