Pinout for Aux Input on LX - Page 5 - 8th Generation Honda Civic Forum
LinkBack (9) Thread Tools Display Modes
Old 01-02-2008, 02:35 PM   #81 (permalink)
Awesome help!
To everyone who posted this info, Thanks! This is awesome info!
I got a shiny new iPod Touch for Christmas and was using an FM transmitter (which pretty much sux when you live in SoCal since there are very few open frequencies) until I came across this info. Of course, I have a 06 Civic LX so I had no Aux port. But I do now!
I used a 3.5mm M-F extension cable for my cable between the console and the Aux connector. I connected the female end of the cable to the aux port in the car and the male end of the cable to the new jack in the console. Now if I need to remove the console for some reason I just unplug the connector under the console and it can be easily removed.
All told this cost me about $20, and that included the cost of buying a soldering iron and solder. WAY cheaper than paying Honda to do this. And using the little Radio Shack plug I was able to mount the aux jack just above and between the shifter and the parking brake.
Now I'm off to Fry's to find a right-angle 3.5mm cable.
db869 is offline   Reply With Quote
Old 01-03-2008, 03:47 AM   #82 (permalink)
wassim
Thanks to ethlar and chock for their help on this DIY...
This truly saved me some D's !!! haha
wassim87 is offline   Reply With Quote
Old 01-07-2008, 05:32 AM   #83 (permalink)
bartone's Avatar
Justin
wow i finally had time to do this and i got a friend to help me out with this, i basically made a connector board to connect to the pins. and it works fine!
thanks for the info
bartone is offline   Reply With Quote
Old 01-16-2008, 05:36 PM   #84 (permalink)
wassim
i did it myself..pretty easy after i got went to radio shack and baught everything i need..
total cost was 14 dollars...that was becasue i baught a soldering kit..
Old 01-19-2008, 03:11 PM   #85 (permalink)
g1sk8terz's Avatar
Does this look correct?
Red = right
Green = left
Yellow = ground (from both wires)
I plugged pins 1,2,3 (from page 1's reference pins) respectively with red,green,yellow but no sound.
I plugged pins 1,2,3 respectively with green,red,yellow but no sound!
I'm not sure what's wrong here.
I got the paper clip to connect pin 5 & 6 and it worked because I could switch CD to AUX...just no sound.
g1sk8terz is offline   Reply With Quote
Old 01-19-2008, 05:41 PM   #86 (permalink)
Wegue Wegue
Cr8tive_leo's Avatar
Adrian
yeah....
Cr8tive_leo is offline   Reply With Quote
Old 01-19-2008, 11:08 PM   #87 (permalink)
g1sk8terz's Avatar
Nevermind,
I scrapped that first wire and used another wire (aux cable), which already had the ground wire in one wire. My first wire (headphones) had a red, yellow, green yellow and the two yellow's were the ground. The second wire (aux cable) had a red, yellow, and white. After experimenting with combinations and the help of my uncle, we figured out the red wire was the ground. The sound works now. Maybe the first wire (headphone) was broken or something.
Now I just have to mingle around with it some more because my sound system is giving me a sound output lower than I expected. Anyone know how to fix this?
Thanks for the DIY!
Old 01-22-2008, 04:11 PM   #88 (permalink)
wassim
my friend has a 2007 accord lx...do you think this is still possible on his car..i did it on my 06 civic lx and worked fine...so im wondering if it works on his so i could hook him up..
Old 02-01-2008, 05:02 AM   #89 (permalink)
bartone's Avatar
Justin
it should be, u just have to find the aux output
Old 03-22-2008, 04:23 AM   #90 (permalink)
how do I connect RCA jacks from the amp to the stock head unit?
yugannie is offline   Reply With Quote
Old 03-22-2008, 12:07 PM   #91 (permalink)
you need a device called a LOC
ethlar is online now   Reply With Quote
Old 03-22-2008, 01:34 PM   #92 (permalink)
06si's Avatar
Kenny G
LOC= Line out Converter just so you know
06si is offline   Reply With Quote
Old 03-27-2008, 12:45 PM   #93 (permalink)
CivicLX4221's Avatar
I just bought a pioneer H/U which has a 3.5mm female input for aux in the rear. My question is if i splice a 3.5mm male cable. Can i use T-Taps to tap into the factory aux. I would prefer to tap from the cables near the factory radio harness if possible. If thats possible which wires do i need to tap.
CivicLX4221 is offline   Reply With Quote
Old 07-07-2008, 04:21 PM   #94 (permalink)
Hello all I have a couple questions. I am looking to wire my iPhone up for use using this method but I am having some difficulty understanding the DIY. Im embarrassed to admit that since I am pretty fluent with electronics. So could anyone possibly 'dumb it down' a little for me? I appreciate any comments or suggestions. Thanks in advance.
Justin
justincivic is offline   Reply With Quote
Old 07-07-2008, 04:56 PM   #95 (permalink)
where specifically are you confused, shoot me a PM if you want
Old 07-28-2008, 04:25 PM   #96 (permalink)
have to agree with justin--a bit confusing for me. granted, i have zero experience with wiring. i got how to take off the console to get at the taped-up AUX plug, but from then it gets a bit hazy for me. so i understand at one end, there is the AUX plug which i ultimately want to connect to a stereo-mini male plug for my iPod. everything in between i dont get. do i just get one of those 3-pin female stereo-mini jacks and mount that into the console somewhere, and then wire that directly to the AUX plug? and then is it a simple matter of following the wiring outs as depicted here (wire the browns together, etc)? help!!
UhhCanJenGo is offline   Reply With Quote
Old 08-21-2008, 02:15 PM   #97 (permalink)
I am in the same boat here, so any help would be greatly appreciated!
SaveByHexy is offline   Reply With Quote
Old 08-21-2008, 04:59 PM   #98 (permalink)
Wegue Wegue
Adrian
There are a few options for this install.
I used an old pair of headphones, cut the cord close to the headset and spliced that wire into the aux plug behind the shifter.
The cable was fed through a slot in under the rear cubby hold (on the centre console, right behind the shifter) and it's nice and long... I've been look for pictures I had, but non are here, I can upload some later.
Nice thing with using the headphone cord, once you strip it... red, green black, solder some thick paper clips to each wire, heat shrink wrap, and insert into the corresponding colour hole on the aux port. The other end already has your male plug to attach to whater device you want.
Put a paper clip in pin 5 & 6, voila, you can switch between aux and cd.
Good to go.
Old 09-01-2008, 10:54 AM   #99 (permalink)
Is there a way to patch the AUX-in from my new stereo to the snazzy plug that sits next to my 12v? I have an extra aux-in on my HU, so I might as well hook it up while I've got it all taken apart. I see the pin-out for the aux input for use with the OEM, but not a way to patch that plug to an aftermarket HU. Can anyone point me in the right direction?
Thanks!
jem199 is offline   Reply With Quote
Old 01-21-2009, 06:52 AM   #100 (permalink)
Originally Posted by chok View Post
i would say just try it!
1. Jump the pin 5&15
2. Power on the unit
3. Press the aux button
4. If that make the "aux" show up on the display, you are good
hi just had the intructions followed but the hu does not detect my aux source? Is there any difference for the 2006 civic v here in the philippines?
Thanks a lot!
kulotzki is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/6171-pinout-aux-input-lx.html
HondaHybridClub.nl • View topic - AUX kabel (DIY) This thread Refback 09-12-2011 12:20 PM
Civic Aux Ba?lant?s? yada USB ! This thread Refback 08-26-2011 08:16 PM
Civic Type-R Owners Club & Forum • View topic - IiPod on standard stereo This thread Refback 08-10-2011 03:56 PM
Question about Honda Civic Auxiliary Input - Honda Civic Forum This thread Refback 07-25-2011 01:07 PM
: Aux-in how-to 4 door - Civinfo This thread Pingback 06-25-2008 12:49 PM
2007 Hybrid Aux Input - Civinfo This thread Refback 06-10-2008 02:15 PM
DIY AUX Input converter?? This thread Refback 03-04-2008 03:52 AM
Forum de Carros - Forum Carros WEB - Noticias automotivas - Noticias CarrosCarros - VW - FIAT - Honda - Toyota - Citroen - Peugeot - Ford - Comunidade Automotiva - Tuning - Spy Pics - Flagras e Segredos - Revista 4 rodas - Revista Auto Esport • This thread Refback 02-29-2008 04:27 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 01:20 AM
Center Console removal for Aux input install ethlar Audio 66 01-29-2012 08:36 PM
Should I get a Civic LX? Coupe blueoakleyz Civic Coupe And Sedan 7 04-01-2006 11:58 PM
