Pinout for Aux Input on LX - Page 3 - 8th Generation Honda Civic Forum
LinkBack (9) Thread Tools Display Modes
Old 04-14-2007, 02:10 PM   #41 (permalink)
Wegue Wegue
Cr8tive_leo's Avatar
Adrian
Is there a voltage running through pins 5 & 6 of the aux clip? (Just curious, yeah I could rip my console apart ad check myself, still too cold outside to do that)
Many thanks, Awesome DIY
*** EDIT : + Rep applied accordingly! Woot! WTG!
Cr8tive_leo is offline   Reply With Quote
Old 04-14-2007, 02:21 PM   #42 (permalink)
Civic4u's Avatar
This should help you..
Center Console removal for Aux input install
Civic4u is offline   Reply With Quote
Old 04-14-2007, 02:44 PM   #43 (permalink)
Wegue Wegue
Adrian
Thanks, but it doesn't tell me if thre is any voltage on 5 or 6 *grins*
It's all good, thanks for the assist.
Woot!
Old 04-15-2007, 04:05 AM   #44 (permalink)
Honestly I have no clue if there is a voltage on 5 and 6. The method for determining the pin out was pure guess and check, finding grounds and then sending signal to different pins until the speakers made noise and finding the combination of pins to make aux available.
ethlar is online now   Reply With Quote
Old 04-15-2007, 11:28 AM   #45 (permalink)
Wegue Wegue
Adrian
I'll check em out when I get a chance, *or maybe invest in a book*
Many thanks again. THis DIY helps a lot.
Old 04-18-2007, 04:04 PM   #46 (permalink)
Wegue Wegue
Adrian
Originally Posted by PokeyD16Z
Just did it temporarily without solid core wires. I'm gonna get some solid core wires tomorrow...anyone have an idea what guage works best here?
PAPER CLIP!
*grins* I just did my aux job, man, took 15mins.
And $0.00.
Parts:
1 standard paperclip
1 old set of stereo headphones (or a dolalr store brand)
solder iron, solder
Electrical tape
Electrical shrink wrap
Heat gun
After removing the center console rear tray (easy as anything)
Step 1: cut paperclip into equal lengths of four. Bend one piece into a 'U' and use that as your bridge wire.
Step 2: rip apart the old headset wire, strip the non plug end about 1/4inch to half an inch
Step 3: Solder grnd, red and white wires to a piece of paperclip
Step 4: heat shrink wrap over solder
Step 5:
Insert each end of the paper clip ito the Aux plug, they fit snuggly and won't fall out, take a bit of slack on cord, wrap it securley with electrical tape on the aux plug , and replace the cover.
*(the cord I used is 5 feet long, and I fed it through one of the tab holes in teh back of the cetre console tray, lots of room, it's at least 1/4inch by just under 1/2 inch hole, two of them so you don't have to dremel or anything)
I have this piece too that I will install in the tray at some point.
THAN YOU Again for this DIY info, awesome! WOOT!
Old 08-05-2007, 06:32 AM   #47 (permalink)
Does anybody know how I can use my stock AUX input with my aftermarket head unit? The new head unit has an AUX input in the back. I want to wire my stock AUX input in the Civic to the rear of my aftermarket head unit. I ask in forums and everyone points to this thread. Unfortunately this thread shows how to install an AUX input to a Civic with no pre-existing AUX.
jjohan35 is offline   Reply With Quote
Old 08-08-2007, 01:46 PM   #48 (permalink)
Wegue Wegue
Adrian
Should be able to take the connector and do simialr install, just use phono jacks to connect to the new aux input, hardwire the into the left/right side of your aux. Something like that, what headunit do you have? Thanks
Old 08-09-2007, 07:03 AM   #49 (permalink)
"something like that" really doesn't help.
Old 08-09-2007, 10:36 AM   #50 (permalink)
Wegue Wegue
Adrian
Yes, you still haven't said the model of your headunit, or post a pic of the back end where the Aux is, so that we can see exactly and suggest how to properly attach it.
Old 08-11-2007, 07:06 AM   #51 (permalink)
It's a Pioneer Premiere head unit. It takes normal mini stereo jack input.
Old 08-14-2007, 03:26 PM   #52 (permalink)
chok's Avatar
Sirichok
Originally Posted by edyweber
Hi!
I recently got a `06 LX civic in Argentina. I`m trying to connect my ipod to the aux imput, but here is the funny thing. THERE IS NO CONNECTOR as shown here in the PIC. Probably the southamerica version of this car does not include it. So I am trying to get the actual pinout of the stereo itself. I mean the aux pinout from the rear connectors of the audio system. Can anyone help??
thanks!
At the back of HU you will find the 20pin connector (second one from the right). The pins are ordered as following
1........10
11......20
There you go (the pin# in parenthesis is the pin# defined by ethlar post#1)
B3 = AUX SGND (3)
B4 = AUX SH GND (4??)
B5 = AUX GND (5)
B13 = AUX L (2)
B14 = AUX R (1)
B15 = AUX DET (6)
chok is offline   Reply With Quote
Old 08-14-2007, 04:21 PM   #53 (permalink)
thanks for the extra info, id add it to the first post but editing is disabled in the DIY section
Mods: if you could add the information in the above post to the first one id appreciate it
Old 08-14-2007, 04:31 PM   #54 (permalink)
Crazy Yellow Puppet
CameronJr9's Avatar
Back and Forth Forever
It has been done.
Old 08-14-2007, 04:33 PM   #55 (permalink)
thanks cameron
Old 08-14-2007, 11:05 PM   #56 (permalink)
chok's Avatar
Sirichok
ethlar, when you were finding for the combination of the pin to make AUX available (pin 6&5; AUX GND&AUX DET). Did pin6&3 (AUX DET&AUX SGND) also make the AUX available? Thought you tried all combination and could give me some clue about that.
Old 08-15-2007, 12:33 AM   #57 (permalink)
if i remember correctly it didnt make the aux available
Old 10-03-2007, 02:05 AM   #58 (permalink)
we initially thought it needed a resistor between 5 and 6, and with the resistor in the aux input worked but it fell out so we put a piece of wire in its place and it worked just as well. in the assembly pictures we used a small solid core junction for a bread board to link the two.
i dont actually have the honda part to check the resistance, we just did this by finding the grounds and a little bit of guess and check.
Thanks for this info and the wiring to the aux plug. I've done it and all appears to work well. However, I'm concerned about using a solid jumper from 5 to 6 vs. a resistor. If a resistor is intended then wouldn't the jumper draw more current? I'm concerned that if it was designed for a resistor then I'm possibly drawing more current and risking over-heating or damaging the radio or AUX wiring.
Please let me know if you have had any over heat / over current problems.
Thanks!
Jon Pointer is offline   Reply With Quote
Old 10-03-2007, 11:57 AM   #59 (permalink)
ive had this going since i made the original post, Ive had it on drives as long as 10 hours with no more than occasional 5 min bathroom stops and no voltage or heat issues.
Old 10-03-2007, 12:32 PM   #60 (permalink)
chok's Avatar
Sirichok
In my idea, the pin 5&6 is basically a circuit for sensing the HU that there is a device connect to AUX.
By wiring the pin 5&6 to 3.5mm switch type female jack (the jack has 5 pin two for switching, three for audio signal), this will tell the HU that the AUX mode would available when we press the CD/AUX button if there is nothing connect to it the AUX function will be disable.
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/6171-pinout-aux-input-lx.html
HondaHybridClub.nl • View topic - AUX kabel (DIY) This thread Refback 09-12-2011 12:20 PM
Civic Aux Ba?lant?s? yada USB ! This thread Refback 08-26-2011 08:16 PM
Civic Type-R Owners Club & Forum • View topic - IiPod on standard stereo This thread Refback 08-10-2011 03:56 PM
Question about Honda Civic Auxiliary Input - Honda Civic Forum This thread Refback 07-25-2011 01:07 PM
: Aux-in how-to 4 door - Civinfo This thread Pingback 06-25-2008 12:49 PM
2007 Hybrid Aux Input - Civinfo This thread Refback 06-10-2008 02:15 PM
DIY AUX Input converter?? This thread Refback 03-04-2008 03:52 AM
Forum de Carros - Forum Carros WEB - Noticias automotivas - Noticias CarrosCarros - VW - FIAT - Honda - Toyota - Citroen - Peugeot - Ford - Comunidade Automotiva - Tuning - Spy Pics - Flagras e Segredos - Revista 4 rodas - Revista Auto Esport • This thread Refback 02-29-2008 04:27 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 01:20 AM
Center Console removal for Aux input install ethlar Audio 66 01-29-2012 08:36 PM
Should I get a Civic LX? Coupe blueoakleyz Civic Coupe And Sedan 7 04-01-2006 11:58 PM
