DIY - Replace your factory horn with 118db "Bad Boy" (39 pics) - Page 3 - 8th Generation Honda Civic Forum
LinkBack (12) Thread Tools Display Modes
Old 01-24-2008, 10:52 PM   #41 (permalink)
sleeperone's Avatar
08 TW accord coupe 5M
very nice DIY
sleeperone is offline   Reply With Quote
Old 01-25-2008, 02:53 AM   #42 (permalink)
TigerDave's Avatar
Originally Posted by sleeperone View Post
very nice DIY
Thanks.
Sadly, the car is currently up for sale.
TigerDave is offline   Reply With Quote
Old 01-27-2008, 12:18 PM   #43 (permalink)
TigerDave's Avatar
As I mentioned in the previous post, if anyone is interested in this Si (complete with the new horn!), check out:
http://www.8thcivic.com/forums/8th-g...es-so-cal.html
Old 02-07-2008, 05:41 PM   #44 (permalink)
just installed triple air horns from hella will post a video soon.
Ek37 is offline   Reply With Quote
Old 02-07-2008, 07:47 PM   #45 (permalink)
Agnt004's Avatar
Greg
Where did you fit them?
Agnt004 is offline   Reply With Quote
Old 03-10-2008, 12:52 AM   #46 (permalink)
sgtmorph's Avatar
2011 FA5 ASM
subscribed.....
sgtmorph is offline   Reply With Quote
Old 03-11-2008, 09:01 PM   #47 (permalink)
08Si_C's Avatar
just installed this Badboy into mycar. Same steps except the 08 has 2 factory horns so you need to disconnect the one on the right hand side and tape it with electrical tape.
08Si_C is offline   Reply With Quote
Old 03-11-2008, 09:18 PM   #48 (permalink)
Excalibur's Avatar
Jeremy
Badass. I wish it was plug n play.
Old 03-11-2008, 11:52 PM   #49 (permalink)
wheeler's Avatar
Dave
Originally Posted by unplugged View Post
i was going to put an Accord horn on it, at least it won't sound as wimpy. And you can get them for dirt cheap in a junk yard.
The Accord has two a low and a hi tone. Let me know when you do the DIY for it, I'm interested. Incidentally at College Hills they sell them for $18 a piece. I'd be interested to see how a good splice job would look, or would you use a single horn?
wheeler is offline   Reply With Quote
Old 03-12-2008, 12:15 AM   #50 (permalink)
sgtmorph's Avatar
2011 FA5 ASM
i heard the "bad boy" horn on another vehicle.....it's friggen LOUD...
Old 03-29-2008, 03:30 AM   #51 (permalink)
fiji-blew's Avatar
i heard people wee swapping w/ the fits horn as well
fiji-blew is offline   Reply With Quote
Old 04-16-2008, 05:16 PM   #52 (permalink)
Soichiro Jr.'s Avatar
These questions are for you, or anyone else who has installed this horn. Did you use an inline fuse? If so, what size 10amp? Also where did you place it? Any problems so far? Thanks.
Soichiro Jr. is offline   Reply With Quote
Old 04-16-2008, 10:24 PM   #53 (permalink)
Agnt004's Avatar
Greg
I put a 20 amp(like it says in the manual that comes with it) inline fuse on my horn and one installed in a friends car. She has an lx btw, and my car is an si. However, I later realized it wasn't necessary when my friends horn stopped working soon after it was installed. It turns out the fuse for the horn in the car's fusebox blew, which is rated at 10 or 15 amps (I forget). She replaced the fuse multiple times and it keeps failing. The worst part is that the fuse controls both the horn and the rear tail lights, so when the horn stops working so do your brake lights. I will be fixing this soon by putting a relay in and directly getting power from the battery, not the original horn power wire. I will use the horn power wire to switch the relay on and off.
Old 04-17-2008, 12:18 AM   #54 (permalink)
Thanks for the quick response. Yes, I just looked in the owners manual, and the horn and stop lights are on the same 15amp fuse.... Are you having trouble with yours(Si)? You said that you installed a 20amp fuse in both of your horn installations, correct? Did you place them(fuses) in an area that you can get to without having to take off the bumper? In your friend's car, have you tried replacing the 20amp fuse with a 10amp fuse? That way, when it blew, brake lights would remain just the horn would go out.... I think. I'm gonna try it within the next couple of days. As long as the 10amp fuse is placed between the horn and oem fuse box, it should go first I think. I think when you use the 20amp fuse(horn), the 15amp fuse(horn/stop) in the oem fuse box goes first. Then no stop lights... I'm hoping the 10amp fuse won't just blow as soon as it's used...
Old 04-17-2008, 12:25 AM   #55 (permalink)
i love my honda fit horn
inyong1988 is offline   Reply With Quote
Old 04-17-2008, 01:16 AM   #56 (permalink)
What would happen if I pulled the 15amp(horn/stop) fuse from the underhood fusebox, and replaced it with a 20amp fuse?
Old 04-17-2008, 11:28 AM   #57 (permalink)
Agnt004's Avatar
Greg
My friend was doing that and I told her not to as it may cause a problem with the fusebox or other car electronics. A 15 was put there for a reason. As far as putting a 10 amp fuse inline before the fusebox, it should work, but may blow a lot. My Si has not had any problems since I installed it, and the inline fuse is not in a reachable spot. If it goes (which it won't because the 15 in the fusebox would go first) I'd have to take off the bumper to replace it.
Old 04-22-2008, 09:11 PM   #58 (permalink)
plrbr533's Avatar
Josh
TigerDave,
Great DIY. I bought the same airhorn and your DIY was perfect.
Only one thing. Since I have the FA5 (Sedan SI) there is no 10mm bolt in front of the front tires to take off.
thanks.
plrbr533 is offline   Reply With Quote
Old 04-22-2008, 09:51 PM   #59 (permalink)
Originally Posted by plrbr533 View Post
TigerDave,
thanks.
How long have you had this installed? No problems(blown fuse) when you honk the horn and press the brakes at the same time? What year is your car? Thanks for any info you have....
Old 04-22-2008, 11:13 PM   #60 (permalink)
plrbr533's Avatar
Josh
Just installed it today. Blown it a few times and no problems. Would not know why stepping on the brakes and blowing the horn would blow the fuse. I believe if you install the switch then you need a fuse.
If it happens to me I will place a 20 fuse like the instructions say.
I will let you know.
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/57397-diy-replace-your-factory-horn-118db-bad-boy-39-pics.html
orkut - Retirar Parachoque do NC 2011 This thread Refback 09-20-2011 10:09 AM
orkut - Retirar Parachoque do NC 2011 This thread Refback 09-08-2011 06:28 PM
orkut - Retirar Parachoque do NC 2011 This thread Refback 07-23-2011 09:36 PM
orkut - Retirar Parachoque do NC 2011 This thread Refback 07-12-2011 11:17 PM
orkut - Retirar Parachoque do NC 2011 This thread Refback 07-10-2011 01:04 PM
fd horn not working This thread Refback 07-10-2011 09:18 AM
fd horn not working This thread Refback 07-10-2011 01:03 AM
fd horn not working This thread Refback 07-10-2011 12:27 AM
Official Sharp Aquos LC-42D64U/LC-46D64U/LC-52D64U Owner's Thread - Page 48 - AVS Forum This thread Refback 02-01-2008 11:20 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-17-2008 01:14 AM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-11-2008 03:41 AM
Official Sharp Aquos LC-42D64U/LC-46D64U/LC-52D64U Owner's Thread - Page 48 - AVS Forum This thread Refback 12-16-2007 01:00 PM
D.I.Y. : Tweeter install in factory Location (w/ pics) vtec_marine I.C.E., Electrical, Security, & Navigation 11 07-06-2008 06:55 PM
Center Dump Exhaust! carter21 Inside and Out 43 01-31-2007 02:40 PM
