Old 09-28-2007, 09:58 PM   #41 (permalink)
Dave
No lowe's in canada lol
absolutely cannot find anything similar
maybe i'm not looking hard enough.
well anyhow, I installed it with battery. works like a charm for now...until battery runs out :s
daveshin is offline
Old 09-29-2007, 08:27 PM   #42 (permalink)
R4DG's Avatar
radio shack has the quick connectors you need, just make sure its the same gauge as your wire
it does not have to be 3M
check an audio shop or an auto parts store
at O'Reilly we sell quick connectors made by Calterm
R4DG is offline
Old 10-12-2007, 10:03 PM   #43 (permalink)
SiAzul's Avatar
Mario
Nice DIY man, I also wanna do this and I have all the required items but I have one question, My garage opener uses one of those square batteries with the pos and neg on one end, will that be an issue with power or are those also 12v?
SiAzul is offline
Old 10-13-2007, 03:36 AM   #44 (permalink)
TigerDave's Avatar
You mean a 9 Volt battery? I wouldn't recommend that.
TigerDave is offline
Old 10-13-2007, 01:53 PM   #45 (permalink)
SiAzul's Avatar
Mario
What should I do? can I program another control? or is there a way to convert the voltage?
SiAzul is offline
Old 10-16-2007, 05:43 PM   #46 (permalink)
SiAzul's Avatar
Mario
What about a resistor? dont they reduce the amount of voltage coming in? anybody know if I could solder one between the incoming power line and not have a problem? correct me if im wrong, I dont know very much about this type of thing
SiAzul is offline
Old 10-25-2007, 02:36 AM   #47 (permalink)
TigerDave's Avatar
From what I recall in electrical class in college ('92), resistors reduce the amount of amperage, not voltage. But I could be wrong! Google it.
Old 11-04-2007, 05:39 PM   #48 (permalink)
J_Bone's Avatar
Jason
If I remember right, you can add a 390 ohm resister in line to reduce the Voltage from 12volts to 9 volts.
They are cheap enough to buy and test it out before you install it or ask someone at the local Radio Shack or electronic store.
Great DIY!! This will be my first mod.
J_Bone is offline
Old 11-04-2007, 05:45 PM   #49 (permalink)
J_Bone's Avatar
Jason
If I remember right, you can add a 390 ohm resistor in line to reduce the Voltage from 12volts to 9 volts.
J_Bone is offline
Old 01-03-2008, 12:52 PM   #50 (permalink)
1337 h4xZ0r
Phalanx's Avatar
MASShole
Okay, well... I finally got around to doing this mod. Well... sort of.
I didnt reall ALL the pages to see if anyone had a similar issue. But here goes...
To anyone doing this mod... be wary of bending the 'nipples' of the Button too much. Im a novice when it comes to electrical wiring and soldering, etc (this was my first time). All was well until i went to secure everything down and install it back in my car. When I was securing it, i bent the red wires to get it to lay flat and in doing so, tugged a bit on the 'nipples' of the button. When I did this, the 'nipples' broke off. So, now I need a new button.
So yea, dont bend and pry the buttons 'nipples' too much!
happy modding!
Ill post pics when I get it done. Im putting my button in the roof of the coin tray (below to the left of steering wheel)
"A car never breaks. It presents us with opportunities to upgrade."
Originally Posted by gibbletz View Post
what are u smilin about...dood i almost had u...had me? u never had me...never had your thread...ohhh granny posting not double clicking like ya should yo lucky that 100 pics of porn didnt blow your wad on the keyboard...ask any poster any real poster it dont matter if u fwap by an inch or a mile fwappings fwapping...ohhh..
Phalanx is offline
Old 02-25-2008, 08:37 PM   #51 (permalink)
jjackowski's Avatar
Jeff Jackowski
I'm curious as to how long this mod works. When I last added electronics to a car, it was a 1989 Civic and the CMOS chip I used lasted two weeks. I had to protect the circuit from noise on the power line; then it worked for the remaining 8 years or so I had the car. Do these garage door openers have protection? They wouldn't really need it to run from a battery. Are the new Civics better about delivering a more constant unwavering voltage? Firing spark plugs needs lots of current, so it makes noise, but I don't know how much it's isolated from the rest of the car's power supply.
Might be a little late, but it is my understanding that will work only if the circuit draws about 31mA. (V=IR) If it needs more current, the voltage will drop further. If it needs less, the voltage will rise. It'll probably be OK if the voltage doesn't rise above 9.5v, but expect the voltage to drop a little under the load of transmitting so measure when not transmitting. The voltage from a battery will drop, too, especially as the battery wears out. The transmitters are made to deal with this, so I think using a resistor will work, but you'll need to measure your results and change resistors accordingly. A more robust solution is to use a 78L09 voltage regulator, but a garage door transmitter probably doesn't need the extra help.
jjackowski is offline
Old 02-26-2008, 11:57 AM   #52 (permalink)
TigerDave's Avatar
Six months later, it's still working fine for me!
Old 02-26-2008, 12:09 PM   #53 (permalink)
Caraholic......
Cybergypsy's Avatar
nice clean work guys....
Like the wind, I'm subject to change.
Cybergypsy is offline
Old 04-28-2008, 12:50 AM   #54 (permalink)
modders in the GTA ?
'big-ups' on a SiCk write up !!! wish i had any skills to do something like this
$$$ CASH REWARD $$$ seeking honda enthusiasts or MoD guru in the GTA area who has done this already and would like to again :P. new 2k8 DX-G w/ <1000km ($$$ bonus for installing new LEDs)
zosky is offline
Old 04-28-2008, 11:16 AM   #55 (permalink)
07Ex's Avatar
Wow, that a nice DIY!
07Ex is offline
Old 04-28-2008, 07:29 PM   #56 (permalink)
eub
voltage regulator
if your garage door opener is not 12v by design, you will want to stay away from resistors, and go with a voltage regulator instead.
Search Results Page
eub is offline
Old 04-28-2008, 11:25 PM   #57 (permalink)
TigerDave's Avatar
Selling the button, any takers?
Folks, I sold my Civic (and I miss it too), so I am selling the modified button shown in the original DIY post. I've added bullet connectors making it much easier to install and will include the female bullet ends as well (shown in the small bag).
First one to PM me gets it.
Asking $15 including shipping (hey, it's $10 worth of parts alone).
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
DIY: Aftermarket radio Install in an EX xtv-sidecar Audio 192 05-08-2008 10:17 AM
DIY: Ambient lighting, cup holder, under the dash, and the change pocket. mishima8 Interior Style Mods 72 03-19-2008 11:42 PM
DIY: small battery mount benmunger Electrical 9 12-31-2007 10:29 PM
Powered by vBulletin® Version 3.7.0
