DIY Auto windows thread *merged* - Page 3 - 8th Generation Honda Civic Forum
Old 09-01-2008, 03:11 PM   #41 (permalink)
ImTheVoiceOfGod's Avatar
Curtis
Thanks wing_gundam
(click for details)
ImTheVoiceOfGod is offline   Reply With Quote
Old 09-01-2008, 03:13 PM   #42 (permalink)
Member # 4524
GlxyGry06Si's Avatar
Originally Posted by jasyatz View Post
Just ordered the Autoloc One touch express unit from ebay...I have done this on both my Odyssey(es), my S2000 for both windows and the roof. It can be done..I'll get the wire colors and pictures as soon as I get the unit.
Jeff
so did you do it? how did it go?
Originally Posted by TheIncident88 View Post
Sometimes I actually wonder if you are serious or just ******* with me. If it's the latter, then well played sir. If not, then I shall return my palm to it's previous position upon my face.
Old 09-13-2008, 06:16 PM   #43 (permalink)
Member # 4524
bump for an answer
Old 09-23-2008, 07:06 AM   #44 (permalink)
mad monkey's Avatar
Jeremy
Where's benmunger?!
mad monkey is offline   Reply With Quote
Old 09-23-2008, 05:38 PM   #45 (permalink)
Bump...
Ellementum is offline   Reply With Quote
Old 10-05-2008, 08:54 PM   #46 (permalink)
ok so here is the down low, alot of you have been saying that you think the new civics have window sensors. im living proof that the 08 lx's dont, the other night i rolled my best friends hand in the window.
westcoast0223 is offline   Reply With Quote
Old 10-05-2008, 09:03 PM   #47 (permalink)
dcubed121's Avatar
David
the drivers Side does.
dcubed121 is offline   Reply With Quote
Old 10-23-2008, 11:03 PM   #48 (permalink)
You would have to switch out the switches and find a window motor that has the auto feature cause there is a sensor in the motor that tells it when to stop.
CBRDC5 is offline   Reply With Quote
Old 10-25-2008, 12:13 AM   #49 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
I am and have been working on this matter for a while....since 06 looking into it this week...using OEM honda parts...
RIP Bernie Mac, Ricardo Montalban, Lux Interior, Dom Deluise, M.J., Ed Kennedy, DJAM, Patrick Swayze, Brittany Murphy...
fiji06si13 is offline   Reply With Quote
Old 10-25-2008, 12:16 AM   #50 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
wrong its in the switch on honda's....the motor has the sensor in it already...
I have taken it apart.....I am currently tying to figure a way out to use factory switches to make this work...
Old 10-25-2008, 12:22 AM   #51 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
master switch consists of the following...
Driver side switch is a potentiameter (spelling???) pretty much a variable resistor when you go to one resistence it works likepassenger window switch when you push it further it activates auto down....
Passenger side switch is a 3 position switch neutral middle and up and down.
Old 11-07-2008, 11:22 PM   #52 (permalink)
dwm5f5's Avatar
Dan
is the auto up/down a feature of the switch itself? If it's a potentiometer, shouldn't there be some sort of logic board somewhere between the motor and switch to interpret the resistance? If we were to duplicate that and replace the switch, I would think that would solve it...
dwm5f5 is offline   Reply With Quote
Old 11-30-2008, 10:50 AM   #53 (permalink)
jasyatz's Avatar
Yup installed. Forgot to take pictures and get wire colors. Took longer to remove the door panel than to get the wiring done.
You have to cut both wires at the motor. Wire in the ground from the Autolock unit to the switch side and then the motor side of the ground. Then cut the power pire to the motor and wire in the switch side to the autolock unit then the motor side. Then get a power source for the unit (I used the R/F stock window switch so when the window lock is enguaged on the L/F swuitch, window will not work at all. Then ground the unit. I used the factory window motor ground again. You really don;t even need the factory wire colors. Just get a test light and find the power window motor and switch. It's simple after that.
Works perfectly. I almost like the R/F one touch better than the L/F push and hold auto feature.
Jeff
jasyatz is offline   Reply With Quote
Old 11-30-2008, 11:36 AM   #54 (permalink)
joon joon's Avatar
so with the autolock unit, u could have auto up/down from the inside??
joon joon is offline   Reply With Quote
Old 11-30-2008, 07:37 PM   #55 (permalink)
jasyatz's Avatar
Yup..It's all mounted in the door. COntrol unit fits in the palm of your hand..
Zip ties to the harness inside the door.
Old 12-01-2008, 12:50 AM   #56 (permalink)
Vee Easy
Jeff
sorry man, you lost me with the r/f and the l/f's? what are you referring to, with the
auto lock can u still use the windows normally, or are they always auto up and auto down ?
Strate L O S S is offline   Reply With Quote
Old 12-01-2008, 12:55 AM   #57 (permalink)
SLICK_iVTEC's Avatar
Max
Originally Posted by strate l o s s View Post
sorry man, you lost me with the r/f and the l/f's? What are you referring to, with the
r/f is right front, l/f is left front. Lol sry about the caps if they still show up. Too lazy to retype everything
SLICK_iVTEC is offline   Reply With Quote
Old 12-01-2008, 01:08 AM   #58 (permalink)
Make and model?
Originally Posted by benmunger View Post
that other guy that did it says he is making a diy. I dont want to pull mine apart... its so perdy already...
So what is the make a model of this module that enables the auto up and down?
vlonjati is offline   Reply With Quote
Old 12-01-2008, 02:25 AM   #59 (permalink)
Vee Easy
i see , so is that you that i qouted above? cause if so do you still have normal functions of the window switch, or is it just auto up and down, meaning it will always go all the way down unless you cut it off ?
Old 12-01-2008, 12:01 PM   #60 (permalink)
joon joon's Avatar
So I would have full up/down control from the inside, would I be able to control it with my key fob?? And will the unit work for 4 doors cuz that's wat I have
Auto down windows both sides for Si coupes fiji06si13 Mechanical Problems & Technical Chat 87 12-21-2008 12:45 AM
all auto windows?? t85konrad Do It Yourself Articles 8 05-26-2008 07:38 PM
Auto Windows DJFriar I.C.E., Electrical, Security, & Navigation 6 01-03-2007 10:39 AM
Auto Up/Dn Windows ndingler Do It Yourself Articles 10 08-14-2006 04:19 PM
Auto pitch windows? si_civic Mechanical Problems & Technical Chat 6 07-19-2006 03:51 PM
