Old 07-18-2007, 09:52 PM   #41 (permalink)
HYPHY SiVIC's Avatar
BJ
i installed an antique horn "AaoOOhooGAH" on my Si. its sound like a duck call if you just tap the horn.. thanks to the duck squad "SiC crew"
HYPHY SiVIC is offline   Reply With Quote
Old 07-31-2007, 05:53 PM   #42 (permalink)
I was too timid to do the Horn install myself so I had the dealer install the Honda Fit Sport horn for 130 (parts and labor). It's not much louder but it does honk... people actually turn and look instead of giggling.
tommyo is offline   Reply With Quote
Old 07-31-2007, 08:30 PM   #43 (permalink)
Wakeboarder11's Avatar
Tyler
Guys all i have to say is if you are going to do this, use a fuse on the horn wire right there. I didnt use one and my ground shorted and the short damaged my ecu.
Wakeboarder11 is offline   Reply With Quote
Old 08-17-2007, 04:35 PM   #44 (permalink)
lionelp's Avatar
Lionel Pereira
Do you have a fuse on there now? Did the dealership fix it?
lionelp is offline   Reply With Quote
Old 08-25-2007, 10:08 PM   #45 (permalink)
goixiz's Avatar
Why do you need a fuse
Is the existing horn not have a fuse ?
goixiz is offline   Reply With Quote
Old 08-31-2007, 10:52 PM   #46 (permalink)
I'm installing a Nautilus and I have everything wired. Yet I get no sound from my horn. Any suggestions?
Kid Red is offline   Reply With Quote
Old 08-31-2007, 11:12 PM   #47 (permalink)
OK, I just bypassed the relay and went straight to the horn and think I lost hearing in my left ear now. Does that mean I should not use the relay? And why would the horn sound when I give it power as opposed to only sounding when the horn button is pressed? I still have the battery connected, I'll disconnect that, bypass the relay and see if the horn sounds upon reconnection of the battery. Damn loud horn!
Old 08-31-2007, 11:17 PM   #48 (permalink)
K, if I bypass the relay, the horn sounds when I connect the battery. If I use the relay, I get no sound with the battery connected and I press the horn button. Ideas?
Old 09-01-2007, 10:40 AM   #49 (permalink)
So I by-passed the relay and everything works fine. I have a real horn now, real 138 db loud Not sure why the relay prevented everything from functioning normally?
Old 09-02-2007, 01:31 PM   #50 (permalink)
CraigH's Avatar
Maybe you have the connections on the relay mixed up?
CraigH is offline   Reply With Quote
Old 09-05-2007, 08:07 PM   #51 (permalink)
ryker's Avatar
Originally Posted by HondaF1Fanatic
Hella Supertones baby, 118dB.
Jon
would those require any relays or extra wiring. I used them on my VW Golf and they are LOUD. Didn't need any extra wires or relays. Just a wire adaptor that I fab up so I didn't have to cut wires.
ryker is offline   Reply With Quote
Old 09-20-2007, 08:16 PM   #52 (permalink)
Avenger's Avatar
Rob
Well, I went to the junkyard today and pulled a dual horn setup from a 2nd gen Chrysler Intrepid
Installed it.........now it sounds quite similar to my '02 Intrepid's horn (a good thing)
Avenger is offline   Reply With Quote
Old 02-07-2008, 01:00 PM   #53 (permalink)
KEVIN
Diy Horn Upgrade
I Ordered Factory Ridgeline Horns. They Are About 15 Bucks Each. High And Low Tone. You Can Use One And It Plugs Right In. I Used Two And I Used The Factory Plug On One And An Adapter On The Other. I Think You Can Order That Plug Too,but I'm Not For Sure. I'm Going To Do A Friend Of Mine And I Will Update With Pics.
SISEDAN18 is offline   Reply With Quote
Old 06-06-2008, 12:41 AM   #54 (permalink)
Should I attempt this if I don't understand the basics of wiring?
capoderra is offline   Reply With Quote
Old 06-28-2008, 05:53 PM   #55 (permalink)
simons2k's Avatar
Simon
I replaced my '08 Si Sedan horns with S2k (AP2 snail type) horns when I got my HID's installed. In the Si, you'll find you have 2 horns, one on the left and one on the right. It took 10 minutes to install...plug and play!
simons2k is offline   Reply With Quote
Old 07-05-2008, 11:14 AM   #56 (permalink)
darken0420's Avatar
Dave
no one has really touched on the wiring in depth its just a "splice in to this" or "connect into that" Someone said use a in line fuse but my insructions say nothing about that. Is it two wire or one? Iv'e heard both on that topic too. I purchaed a BADBOY dual tone horn model 419 and it says connect it right up if its two wire and connect the (-) end to a ground if its a one wire system. Now I'm scared I'm going to blow something. The instr. say that if you connect them backwards it will just not work so you will need to swith them and thats all. Nothing about a fuse or disconecting the battery. CAN SOMEONE PLEASE CLEARIFY!!!!!!!!!!!!!!!!!! IM DYING TO GET RIDE OF A CASE OF THE MEEP MEEPS fyi it ame with a technial support number (888)550-horn (4676) if it helps anyone. Mon-fri 8-4 eastern time. I'll all but Id rather hear the voie of experience with my car here. THANKS
darken0420 is offline   Reply With Quote
Old 07-05-2008, 11:19 AM   #57 (permalink)
darken0420's Avatar
Dave
edit: It came with a number...
edit: I will call but id rather hear the voice of...
My "C" on the keyboard gets stuck sometimes. POS work laptop....sorry
Old 07-05-2008, 03:36 PM   #58 (permalink)
darken0420's Avatar
Dave
Got it!!!!
Ok so there are two horns on my 08 fg2 civic si. I took the bumper off (which is YES much easier than it sounds) And remove both oem horns. Then I put my new badboy horn on the passenger side for ease of grounding the wire. YES it has only one wire per horn therefore you must ground the
(-) end of the horn. Tested it and boy it is bad a$$. Hope this helps someone. I can only guess that other after market horns might be different but this is what I did today, took about 1 hour due to the fact I have never taken off the bumper. No fuses went out, I didn't unhook the battery, I just tapped the horn when it was hooked up. Payoff........priceless goodbye meep meep goodbye.
Old 07-15-2008, 10:36 PM   #59 (permalink)
I think this is definitely something I should do when I get my car back from the bodyshop...apparently my wussy horn wasn't loud enough to stop a garbage truck from backing up into the driver's side corner of the front bumper of my ONE WEEK OLD Si...
night_hawk_ninja is offline   Reply With Quote
Old 07-15-2008, 10:46 PM   #60 (permalink)
asndragonboii's Avatar
I'm doing mine this weekend.
BTW according to my service manual, the 08 SI's are the only one with 2 horns
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/3420-diy-horn-bumper-removal.html
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: civic horn question This thread Refback 02-29-2008 08:33 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-13-2008 04:41 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 07:58 AM
4-door sunroof dimensions? shoptb Dealership Experience 2 10-12-2005 01:52 PM
so i hear the fuel to use is the expensive one PICHY Civic SI 9 10-03-2005 05:53 PM
Another newbie Phun Siz Introduction & Pictures 3 09-10-2005 05:31 PM
Useless fact of the day- Wed Prototype Water Cooler 7 08-10-2005 11:03 AM
caption it webby Photoshop 5 06-25-2005 08:51 PM
