DIY: push start button ( wiring diagram) - Page 7 - 8th Generation Honda Civic Forum
LinkBack (19) Thread Tools Display Modes
Old 09-26-2007, 04:18 PM   #121 (permalink)
Originally Posted by Joel H
What happened to the Wire Diagram?
x 2
sctuned.com is offline   Reply With Quote
Old 10-03-2007, 11:18 PM   #122 (permalink)
Can somebody sent me a copy of the diagram?
trey99ek is offline   Reply With Quote
Old 10-08-2007, 11:07 AM   #123 (permalink)
i cant see any wiring diagram all over the topic, can someone re-send the wiring diagram for me, thanks.
kelwinW is offline   Reply With Quote
Old 10-08-2007, 01:34 PM   #124 (permalink)
here it is... i had to look for it sorry i took so long...
Originally Posted by BATANG CITY JAIL
i recommend using a T-tap for the 12V and ignition wire on the brown harness.
Old 10-09-2007, 04:45 PM   #125 (permalink)
Where is the best place to get a button from?
gdrum is offline   Reply With Quote
Old 10-09-2007, 08:40 PM   #126 (permalink)
BATANG CITY JAIL's Avatar
honda dealer
Old 10-09-2007, 08:40 PM   #127 (permalink)
or ucan get it from ebay pre-wired..
Old 10-10-2007, 09:25 PM   #128 (permalink)
can we use JDM civic type-R start button.
it comes with the panel.
is the panel will fit ?
found in here www.civicdrm.co.nr
emailed the seller, and they can ship to here or Canada.
President is offline   Reply With Quote
Old 10-10-2007, 09:37 PM   #129 (permalink)
looks like it will fit.. but what are you goin to use to adjust ur window?
Old 10-10-2007, 09:55 PM   #130 (permalink)
mine at door side.
Old 10-10-2007, 11:26 PM   #131 (permalink)
mine at door side.
? u have 4 dr? well.. i dk
Old 10-10-2007, 11:26 PM   #132 (permalink)
mine at door side.
what i mean is mirror...side mirror
Old 10-19-2007, 12:34 AM   #133 (permalink)
I just installed the CTR Start Engine Button to my FD2, everything working fine.
Before installation, i tested the button operation, found that 5-pins,
pin-1 and pin-2 is Normally Open contact, which when u press the button there will be a Closed Circuit.
pin-3 is not in use.
pin-4 and pin-5 is for Red LED.
Below is the wiring diagram i figured out :
there is a option to connect the pin-2, either to the ACC +12V or Brake pedal +12v signal.
by using ACC signal, the push button is always stanby to ignition once the key is on ACC, this giving the potential to accidentally press on the button and crank the ignition again even after the engine already being started.
by using the brake pedal signal, ignition only happen when u press on brake pedal and the start button together, it prevent accidentally ignition as mentioned above.
once thing i noticed that, the Red LED very dim, not bright enough.
Old 10-19-2007, 12:39 AM   #134 (permalink)
And, i'm using a 30A rating contact relay.
But, according to my mech, he say is better to use highier rating relay, maybe 40A or even highier, coz ignition is at high current demand.
how true, or anyone using highier rating relay? or still the 30A relay will serve more than enough?
Old 10-19-2007, 09:03 AM   #135 (permalink)
unless you press the botton hard engouh than it will crank. and the bottong is not that soft to push..
Old 10-19-2007, 08:40 PM   #136 (permalink)
i noticed one thing is different from what we do normal crank ignition with key.
for key ignition, after ACC we crank to iginition to start engine, while the move to crank ignite, the Headunit lights will goes off then after started engine the light back to normal after the crank key back to ACC.
but by using start engine button, we skip the crank ignite, then don have this HU light off happening, is it normal for start engine operation to have this situation?
Old 10-19-2007, 09:15 PM   #137 (permalink)
the engine wont crank on the key unless u step on the clutch,but you can crank the engine but it wont start if u press the start botton..
Old 10-21-2007, 09:55 PM   #138 (permalink)
Quick question.
People who have their switch next to the fog light switch, how do you drill the hole? what size?
1sole is offline   Reply With Quote
Old 10-21-2007, 10:38 PM   #139 (permalink)
Originally Posted by 1sole
Quick question.
i used a dremel tool... and i just cut it... until it fit... if you put it there... you're going to have to cut the dash frame as well...
Old 10-23-2007, 09:26 PM   #140 (permalink)
im installing this right now but i came to a problem
I CANT FIND the brown harness. I found one brown harness and it doesnt not look like the picture of how the harness should look like.
The brown harness that i found is next to whole bunch of different connector.
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/22121-diy-push-start-button-wiring-diagram.html
Thread DIY: push start button ( wiring diagram) - Page 17 - 8th Generation Honda Civic Forum | 8th Generation Honda Civic Forum | BoardReader This thread Refback 09-18-2011 01:31 AM
Keyless Ignition Wiring Schematics - JDMCITY.COM This thread Refback 09-11-2011 03:03 PM
???????? ??? ?????? ???????? ????????????? "?????????" This thread Refback 09-11-2011 09:28 AM
Keyless Ignition Wiring Schematics - JDMCITY.COM This thread Refback 09-08-2011 05:22 PM
Honda Accord - Push to Start ? Any? - Drive Accord Honda Forums This thread Refback 08-22-2011 01:42 AM
Lada Klubas: Diskusijos / Elektra ir kita techninė dalis / Užvedimo mygtuko "Engine Start" el. schemos ir pajungimas. This thread Refback 08-15-2011 04:27 PM
Lada Klubas: Diskusijos / Elektra ir kita techninė dalis / Užvedimo mygtuko "Engine Start" el. schemos ir pajungimas. This thread Refback 08-13-2011 06:25 PM
Lada Klubas: Diskusijos / Elektra ir kita techninė dalis / Užvedimo mygtuko "Engine Start" el. schemos ir pajungimas. This thread Refback 08-05-2011 01:50 PM
Einbau S2K Startknopf Seite 2. - da fehlt doch irgendwie das... This thread Refback 07-11-2011 10:35 AM
Honda Accord - Push to Start ? Any? - Drive Accord Honda Forums This thread Refback 07-06-2011 01:04 AM
????? ?????? ? ?????? ????????? ???????? This thread Refback 06-22-2011 06:52 PM
Necesito su ayuda, Engine start electrico - Foros Hondaclub Argentina This thread Refback 02-09-2008 02:49 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: START BUTTON This thread Refback 01-23-2008 01:56 AM
DIY: push start button ( wiring diagram) - 8th Generation Honda Civic Forum This thread Refback 01-08-2008 10:51 AM
DIY: push start button ( wiring diagram) - Page 9 - 8th Generation Honda Civic Forum This thread Refback 01-04-2008 02:34 PM
EJ1 Owners Club - The community for 1992-1995 Civic Coupes -> G-rat This thread Refback 12-29-2007 06:03 PM
EJ1 Owners Club - The community for 1992-1995 Civic Coupes -> G-rat This thread Refback 12-28-2007 08:53 PM
S2000 engine start button wiring - ClubCivic.com - Honda Civic Forum This thread Refback 12-18-2007 01:22 PM
DIY: push start button ( wiring diagram) - Page 15 - 8th Generation Honda Civic Forum This thread Refback 12-05-2007 11:34 PM
Half-decent S2000 Start Button Install J-Ro Do It Yourself Articles 41 01-05-2011 03:39 PM
Navigation wiring diagram grandpa1 I.C.E., Electrical, Security, & Navigation 1 06-24-2008 10:41 PM
push button start. sickyute Do It Yourself Articles 26 02-17-2008 08:15 PM
S2000's push start button installed pic's BATANG CITY JAIL Introduction & Pictures 54 11-08-2006 03:39 PM
S2000 Push Button Start Install Guide unplugged Inside and Out 30 10-21-2006 12:01 PM
