LinkBack (8) Thread Tools Display Modes
Old 01-17-2007, 07:34 PM   #61 (permalink)
Jiah Quayle
actually looking at that diagram I wired mine differently so I guess I cant just add in the relay. I spliced right in to the ignition wires, pos, neg and then ran the ground. Would an in line fuse be a good idea in my case?
1st HI 06 Si is offline   Reply With Quote
Old 01-17-2007, 07:42 PM   #62 (permalink)
BATANG CITY JAIL's Avatar
^^ if its works for you then ,yeah..and running it on the fues is a good idea to..thats y you dont have a problem because of that..
Old 01-17-2007, 07:45 PM   #63 (permalink)
Jiah Quayle
I wanted to try and integrate the systems so that I didnt need the key but it still needed to be in the car. so that it was more like the "keless" in the new cars, I was thinking that you would have to move the receiver for the chip to the center consul. Any one think this would work? What size fuse should I put in line? one on each Pos, neg and grnd.
Old 01-17-2007, 07:56 PM   #64 (permalink)
i actually thought about this as well.....i would like to just keep the key in my pocket when i jump in and just push the start button....sum1 figure it out post it up
Old 01-17-2007, 07:58 PM   #65 (permalink)
you still need the key to unlock the steering wheel... and also the accessory, and since our steering wheel also electrical, (electronic assist) you also need to hack the security of the car to make the steering work.
Old 01-17-2007, 08:02 PM   #66 (permalink)
Jiah Quayle
well how close dose the key need to be to the receiver? Figure that out and then move the receiver to the center consul, but you would have to have one additional button or switch I would think to activate the acc. or the start position. Unless you got a relay that was also an on off switch so that you could push it again to turn off the car.
Old 01-17-2007, 08:24 PM   #67 (permalink)
every car with keyless start that i've driven (lexus IS, acura RL, mercedes cl65amg...that's all i could think of now) usually went something like this.....
u jump in and turn this thing, normally located where the key would go...
and start the car with the key in ur pocket...
after i thought about it....it makes no sense to do this b/c u still have to turn something....the only advantage would be to be able to keep the key in ur pocket....
Old 01-17-2007, 08:31 PM   #68 (permalink)
Jiah Quayle
yeah I think there has to be some type of switch so that if you just need to roll up a window you dont have to start the car.
Old 01-17-2007, 08:37 PM   #69 (permalink)
yup..and that key card have some have some kind of infrared that once its in the location of the car the security alarm will be disabled and unlock the steering wheel as well... i have something in mind in the near future about this stuff but not that keyless start system..its more in secutiy of the car but i still have to use the key so i can unlock the streering wheel...
Old 01-17-2007, 08:43 PM   #70 (permalink)
Jiah Quayle
yeah I forgot about the steering wheel lock....
Old 01-17-2007, 08:45 PM   #71 (permalink)
articsilber323's Avatar
very nice + rep
articsilber323 is offline   Reply With Quote
Old 01-18-2007, 12:29 AM   #72 (permalink)
John
WIRING THE PRONGS???
How did you wire the actual wires to the little prongs???? Did you use butt connectors or something??? or did you just wrap the wire around the prong and solder the wire to the prong and heat strinked it?????
xxmstajxx is offline   Reply With Quote
Old 01-18-2007, 06:25 AM   #73 (permalink)
solderd it on the wires...its kinda hard but you'll get it... and carefull...
Old 01-18-2007, 07:20 AM   #74 (permalink)
Frightened inmate #2
J-Ro's Avatar
Jason
I seriously doubt a keyless start could be made to work without some serious electronic hacking and modification. The keys in the civic do not use RF technology in any way. There's no receiver in the car; the key coding verification done by the ECU is completely done by a direct electrical connection to the key (you could check this by getting an ordinary key copy, then attempting to start the car with it, with the original key close by... the car wouldn't start).
Therefore, to do a keyless start, you would have to build an RF transmitter chip into the key, and a receiver chip into the ingition electronics somehow. And if you could somehow do that, then you'd still have to figure out a way to modify the ignition cylinder to get it to turn and unlock the steering column without the key, which is a near impossibility.
Old 01-18-2007, 03:42 PM   #75 (permalink)
John
solder
So you must used a lot of solder to get the wires to saty on right????
Old 01-18-2007, 04:03 PM   #76 (permalink)
badass!
disfilam04 is offline   Reply With Quote
Old 01-18-2007, 04:18 PM   #77 (permalink)
great diy
irichard is offline   Reply With Quote
Old 01-18-2007, 04:52 PM   #78 (permalink)
how does the relay i must buy look like? pics?
what do you use to make the hole in the dash?
Old 01-18-2007, 05:57 PM   #79 (permalink)
you go to radioshock and ask them for spst 30A 12v relay..they should know it.
http://www.goodsky.co.uk/media/small/GRL.jpg <--- picture
Old 01-18-2007, 06:04 PM   #80 (permalink)
not really but its hard coz the copper keep melting and get into the other niddles so i keep trying and trying until i get it right with out melting the copper to the other niddles..
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/22121-diy-push-start-button-wiring-diagram.html
Necesito su ayuda, Engine start electrico - Foros Hondaclub Argentina This thread Refback 02-09-2008 01:49 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: START BUTTON This thread Refback 01-23-2008 12:56 AM
DIY: push start button ( wiring diagram) - 8th Generation Honda Civic Forum This thread Refback 01-08-2008 09:51 AM
DIY: push start button ( wiring diagram) - Page 9 - 8th Generation Honda Civic Forum This thread Refback 01-04-2008 01:34 PM
EJ1 Owners Club - The community for 1992-1995 Civic Coupes -> G-rat This thread Refback 12-29-2007 05:03 PM
EJ1 Owners Club - The community for 1992-1995 Civic Coupes -> G-rat This thread Refback 12-28-2007 07:53 PM
S2000 engine start button wiring - ClubCivic.com - Honda Civic Forum This thread Refback 12-18-2007 12:22 PM
DIY: push start button ( wiring diagram) - Page 15 - 8th Generation Honda Civic Forum This thread Refback 12-05-2007 10:34 PM
Navigation wiring diagram grandpa1 I.C.E., Electrical, Security, & Navigation 1 06-24-2008 09:41 PM
push button start. sickyute Do It Yourself Articles 26 02-17-2008 07:15 PM
Half-decent S2000 Start Button Install J-Ro Do It Yourself Articles 26 02-09-2008 06:17 PM
S2000's push start button installed pic's BATANG CITY JAIL Introduction & Pictures 54 11-08-2006 02:39 PM
S2000 Push Button Start Install Guide unplugged Inside and Out 30 10-21-2006 11:01 AM
