#41 (permalink) |
Six eyes
![]() Join Date: Apr 2006
Jason
I prefer having the light for the engine start always on because when you turn the key to ON, the interior lights turn off, so if it's dark out, without it being lit, you'd have to poke around for the button
To each his own though.The ring around the hazard button I machined out of 6061 aluminum bar stock. After turning, I wet sanded and polished (minus the fingerprints ) The ring covers up the edges of the hole in the dash, and I also wanted it to have the same trim as the start button to help give it an OEM appearance.
#42 (permalink) | |
#43 (permalink) | |
Six eyes
Jason
The result was good, but the consequences of a screw-up are pretty high
#44 (permalink) | |
\EDIT* i will add some video hows the botton do the work..lol.. |
#46 (permalink) | |
Six eyes
Jason
![]() Theoretically, you could do it without the key, but you'd have to somehow disable the ECU from doing the code verification in the key and redo the wiring to bypass the ignition cylinder. In any case, if you did that, anybody could get in your car and start the engine, sans key
#49 (permalink) | |
#52 (permalink) | |
#53 (permalink) |
Six eyes
Jason
Cut yellow ignition wire = button start, no key start
Splice yellow ignition wire = button start and key start I think it would be fairly difficult to burn the button if you're using a 30A relay, and provided you're using the OEM S2K start button and not a replica. I don't like the idea of splicing the ignition wire because it seems to me that if you want to keep the key start, then why add a button in the first place? Go all the way or don't go at all
#55 (permalink) | |
also i thought to just put like a cut off switch to the key ign.....you could leave it off but just in case the push start does fail....then u could just flip the switch and then the key works again....this is possible right??? btw i got the idea from my old stereo system i had a switch that went between the battery and the amp so everytime i got next to a cop i would just flip the switch and no bass...then when he left flip it back and bass comes back on.....same concept i think |
#56 (permalink) | |
and yes, i leave the the ignition wire on incase if the push start will fail. *if the push start and the ignition wire (yellow wire) will fail, theres one more trick to make the car run, but im not telling the secrete...
#59 (permalink) | |
| Half-decent S2000 Start Button Install | J-Ro | Do It Yourself Articles | 41 | 01-05-2011 03:39 PM |
| Navigation wiring diagram | grandpa1 | I.C.E., Electrical, Security, & Navigation | 1 | 06-24-2008 10:41 PM |
| push button start. | sickyute | Do It Yourself Articles | 26 | 02-17-2008 08:15 PM |
| S2000's push start button installed pic's | BATANG CITY JAIL | Introduction & Pictures | 54 | 11-08-2006 03:39 PM |
| S2000 Push Button Start Install Guide | unplugged | Inside and Out | 30 | 10-21-2006 12:01 PM |
