#542 (permalink) | |
David Spooner
#545 (permalink) | |
David Spooner
But in my opinion his way of doing it is still better than the original schematic shows. Reason being is that if some dumb kid or person did push the big red bottom with the car in gear and key in ignition it would start even without the clutch engaged or auto shifter in park position. |
#548 (permalink) | |
David Spooner
#550 (permalink) |
Sorry for too lazy to read the whole 28 pages thread, but can someone tell me what is the benefit for installing such a button, besides look cool? I think you still have to put the key in with this mod, right?
#552 (permalink) | |
Jchoomal
And it's work well. Yes, it's correct to the case of may no need to put the time ihibitor.. , as may just only car owner to operate, pushing the botton switch to start the engine. However some time the engine working sound can't hear when driver was in the car with door closed, may confused about he had already started the engine or not and re-pushing the EN start button again, or protect someone pushing the button. ( My propose just to protect MOTOR START working during engine had kept operating only ) And another advantage point is, if you put the timer inhibitor relay by hidden some where, not easily to see and set time just a few second (Ex. 5 sec. to examine the minimum of time to function the EN start button by yourself) plus with you had took out the key starting wire out, made your car have to push this botton only to start engine within 5 sec, if the time had over , the engine can not start. This advantage point may able to protect your car from thief or some kid during you cleaning car by condition of listening music , etc. |
#553 (permalink) | |
Jchoomal
Umm.. my post above #552 just some of advantage point. One more benefit is , using the key start as original, ther are high current voltage pass through the key terminal to drive the MOTOR START directly ( starter cut relay 1) , the high current some time make a key terminal short circut , spark!! To modify as new diagram , whenever EN start button had pushed, just operating the Starter cut relay 2 which I had add only. After this relay worked , the high current voltage goto stater cut relay 1 and the goto Motor start unit. |
#554 (permalink) |
i got to page 12 and couldnt read any more due to tiredness but i dont think this question was ever answered.
will this just straight up plug in without splicing? like i drill a hole mount it, and plug it in to the existing holes and go about my way or what? wil this even work wit a civic? JDM Integra DC5 Honda Access Start Button Kit |
#557 (permalink) |
can i use the fog wire to install the start button?
![]() the black plug is the relay plug in, the blue connector is the fuse box in and out, the green connector is to the switch button on the fog lights, the white wire plug in in the second connector on fuse box the white connector on fuse box, the brown connector plug on the blue wire if goes to the fog lights in the bumper. ![]() ![]() hey every one !!! have ideas to plug in this in the start button ?? what do you think ?? works ?? tnks !! regards!! Rafael |
#558 (permalink) |
hey guys i tried to install this. The button light up but when it wouldnt start the car. I connect the red wire to the red in the brown harness and I grounded it by the cigarrette lighter. I also used a relay. any suggestion?? thanks in advance
| Half-decent S2000 Start Button Install | J-Ro | Do It Yourself Articles | 41 | 01-05-2011 03:39 PM |
| Navigation wiring diagram | grandpa1 | I.C.E., Electrical, Security, & Navigation | 1 | 06-24-2008 10:41 PM |
| push button start. | sickyute | Do It Yourself Articles | 26 | 02-17-2008 08:15 PM |
| S2000's push start button installed pic's | BATANG CITY JAIL | Introduction & Pictures | 54 | 11-08-2006 03:39 PM |
| S2000 Push Button Start Install Guide | unplugged | Inside and Out | 30 | 10-21-2006 12:01 PM |
