#403 (permalink) |
Erik
Any results with this installed on a Si coupe?
![]() I really want it done and the only practical way I can think of right now is put VSA in that socket and get a Sedan door plate and wire mirror controls to it instead. Ugh. |
#408 (permalink) |
I don't have my mirror controls plugged and its been about a month. Haven't had any reason to mess with the side mirrors. Its not something you really use. I already have the location where they will go just haven't had the time to set it up..
#410 (permalink) |
Robert
if you have a meter and know how to use one this is what you do.....
-pull the dash off under you steering column -find orange wire with your steering column wires(this is your first accessory line) -if you cant find that one you can use the red line(this is your second accessory line) -once you have found the wire..... with a pair of strippers carefully pull the wires jacket back so you have expossed a few centimeters of wire without cutting the wire. -know set your meter to dc current -know ground the black probe comming from the meter...make sure you found a good ground , in a location so you dont have to hold it because in the next couple steps you will need both hands. -know with the red lead from the meter you are going to hold it to the bare wire -know this is why you need both hands....while holding the probe to the bare wire grab your keys and put it into your ignition.....turn it over to the first click -if you are testing the orange line your meter should have read 12 volts as soon as turned to the first click -if you are testing the red line it should turn 12 volts on the second click -if it reads nothing first check and make sure you have a proper ground as well as a solid connection at the wire... -if your meter continues to read nothing check to see if there is duplicate oranges and/or red wires and test those. -This proscess will help you in finding and comfirming the right wire -hope this helps let me know if you have any questions. |
#420 (permalink) |
![]() Join Date: Feb 2007
just put it in, so i might not quite remember correctly. but, i think it comes on with the key in the ignition....and when the parking lights and then headlights come on.
but not all the time. and not when the alarm/remote is triggered. |
| Half-decent S2000 Start Button Install | J-Ro | Do It Yourself Articles | 41 | 01-05-2011 03:39 PM |
| Navigation wiring diagram | grandpa1 | I.C.E., Electrical, Security, & Navigation | 1 | 06-24-2008 10:41 PM |
| push button start. | sickyute | Do It Yourself Articles | 26 | 02-17-2008 08:15 PM |
| S2000's push start button installed pic's | BATANG CITY JAIL | Introduction & Pictures | 54 | 11-08-2006 03:39 PM |
| S2000 Push Button Start Install Guide | unplugged | Inside and Out | 30 | 10-21-2006 12:01 PM |
