LinkBack (8) Thread Tools Display Modes
Old 03-18-2008, 11:43 PM   #221 (permalink)
BATANG CITY JAIL's Avatar
if its a serious question...
Originally Posted by bizzybearfigiblue View Post
what if i do this and my car is automatic?? do i still need to leave it in Neutral??
no....
BATANG CITY JAIL is offline
Old 03-19-2008, 12:16 AM   #222 (permalink)
Originally Posted by Szwaboski View Post
lol since automatics don't have clutches I would think it wouldn't matter plus I think park would work just the same?
well technically automatic DO have a clutch you just dont have control of it but his question was hilarious
CorntoeGoblin is offline
Old 03-19-2008, 12:42 AM   #223 (permalink)
Image Hosted by ImageShack.us
Toys For TotsMember
no....
bizzybearfigiblue is offline
Old 03-19-2008, 08:46 AM   #224 (permalink)
Szwaboski's Avatar
Nik
Originally Posted by Jepetto View Post
Is the LED behind the start button lighting up?
Do you have the key in the II position?
Can you hear the relay open when you press the button?
No the LED behind the start button isn't lighting up but I don't have it hooked up to light up.
The key is in the II position and the clutch was pressed in.
I thought I heard a slight noise but I thought it was just my imagination.
Szwaboski is offline
Old 03-19-2008, 08:50 AM   #225 (permalink)
Szwaboski's Avatar
Nik
Originally Posted by J-Ro View Post
Hmm.... check your wiring. I'm pretty sure you need blue for power and yellow for ignition. I'm pretty sure I didn't touch the orange in my install. Also, check to make sure that you've got a good ground.
Well I'm going back today we did this at the circuit city install shop since that's where my friend works and he just looked up the wiring from their database and checked it to make sure it was a 12v wire and it was. I'm going back there tonight so we can have another go at it. I guess we'll try using the blue for power instead of the orange, can't hurt to try.
Old 03-19-2008, 09:15 AM   #226 (permalink)
Jepetto's Avatar
The LED inside the button is connected to the 12V input. If this is not lighting up then there is a problem with your 12v input or ground.
Jepetto is online now
Old 03-19-2008, 09:21 AM   #227 (permalink)
Szwaboski's Avatar
Nik
Is this what your talking about? The 2 right parts for the LED?
We only used the first 3 pins on the left like this
Old 03-19-2008, 09:29 AM   #228 (permalink)
Jepetto's Avatar
nope, thats a different button. If you open the button up you can see that those two pins actually go to nothing. I'll try and get a picture posted later. This is also why I recommend using a power source that you can turn off else your led will constantly stay on.
Old 03-19-2008, 09:33 AM   #229 (permalink)
Szwaboski's Avatar
Nik
Ok well the LED never turned on so does that mean I have a broken button?
Old 03-19-2008, 09:33 AM   #230 (permalink)
Szwaboski's Avatar
Nik
and yea I'll suggest them using the cigarrete lighter
Old 03-19-2008, 09:44 AM   #231 (permalink)
Jepetto's Avatar
Probably not, unless you ran a lot of amps though it by accident. There is really nothing to the internals, just pipes.
Double check your connections and a militmeter can be a life saver if you have one. If you don't, go buy one.
Old 03-19-2008, 09:50 AM   #232 (permalink)
Szwaboski's Avatar
Nik
A militmeter checks the volts right? We were using that all night. We blew a fuse we had because a ground and the 12v power wire touched so hopefully it didn't mess up the button. I'll make sure we check all connections again tonight. Thanks
Old 03-19-2008, 10:12 AM   #233 (permalink)
Jepetto's Avatar
A mulitmeter can check Voltage, Amps, and Resistance. All useful info
If you want to test your button, hook up your power and ground to the button. Touch the output of the button with the positive connection of the multimeter and make sure the the negative connection of the multimeter is in contact with a good grounding point. Press the button and you should see the multimeter spike from 0 to 12v.
Old 03-20-2008, 10:35 AM   #234 (permalink)
Szwaboski's Avatar
Nik
yea we tried that with all different combinations and we weren't getting anything out of the button so hopefully tonight I can resolve it
Old 03-20-2008, 01:46 PM   #235 (permalink)
Jepetto's Avatar
Here are the insides of the button.
Top:
Bottom:
Old 03-20-2008, 06:08 PM   #236 (permalink)
Szwaboski's Avatar
Nik
Ok I'm back up at my circuit city roadshop and we're going to attempt this again. Oh and it was an accessory wire that we hooked the 12v power to and my friend said it's the same as the cig. wire
Old 03-20-2008, 07:30 PM   #237 (permalink)
Szwaboski's Avatar
Nik
Ok we got it to work... Bad relay adapter lol
Old 03-20-2008, 08:52 PM   #238 (permalink)
Szwaboski's Avatar
Nik
Ok here's some pictures of my push start button.
Old 03-20-2008, 11:10 PM   #239 (permalink)
Toys For TotsMember
nice... looks a little too much to the right IMO... but good nonetheless
Old 03-20-2008, 11:45 PM   #240 (permalink)
Hail corporate masters.
J-Ro's Avatar
Jason
Nice! Good to see you got it working.
Epic Northeast Meet quotes:
Originally Posted by portabuddy
People sometimes think I'm pregnant, but I'm actually not.
Originally Posted by jrMartinez24
You don't look Canadian. You look like you're from Boston.
J-Ro is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/22121-diy-push-start-button-wiring-diagram.html
Necesito su ayuda, Engine start electrico - Foros Hondaclub Argentina This thread Refback 02-09-2008 01:49 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: START BUTTON This thread Refback 01-23-2008 12:56 AM
DIY: push start button ( wiring diagram) - 8th Generation Honda Civic Forum This thread Refback 01-08-2008 09:51 AM
DIY: push start button ( wiring diagram) - Page 9 - 8th Generation Honda Civic Forum This thread Refback 01-04-2008 01:34 PM
EJ1 Owners Club - The community for 1992-1995 Civic Coupes -> G-rat This thread Refback 12-29-2007 05:03 PM
