#264 (permalink) |
Yeah I have that fused pulled too and I think a switch would be sweet, because sometimes I'd like them on. So my plan is to add another switch right under this one in the center. But if you were to add a switch for DRL's, this is exactly what it could look like. ![]() |
#266 (permalink) |
Yeah, I just checked all the wires up there and there are no ACC actuated positives, at least not in my Ex. There are constant positives and headlight actuated positives.
I saw the DIY thread about how to install your radar up there and they must have used a constant positive. |
#267 (permalink) |
Maybe there is hope for you.
Read this thread, about half or 3/4th down. DIY: radar detector hard wire "12V when car is on. also it stays powered after you turn the ar off untill you open a door." I didn't start my car to check the power, maybe Si is different. Worth a look. |
#268 (permalink) |
I hardwired my V1 about a month ago. Well I will try not to kid everyone my buddy did 99% of the work for me but we tested all the wires in the sunroof and none of them worked. We ended up finding a yellow wire under the dash that works 100% great. If you pop the piece of the dash off right below the steering wheel you will see a wiring harness with a yellow wire and you can just tap right into that. All the wiring is real close and I just ran the phone chord up the pillar and over to the center of the car. I will take some pics and post them up soon.
#271 (permalink) |
The info in this thread is very accurate and very important IMHO. We thought we had two good wires up top but then when you lock the doors the wire have power to them again. That would result in your radar staying on 24/7 and I didnt want that. I would def recommend going down below to the yellow wire.
| DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) | GulfCoastGhostHunters | Audio | 201 | 08-25-2008 04:14 PM |
| DIY: Turn Signal Mirrors | CameronJr9 | Lighting | 120 | 08-25-2008 11:27 AM |
| upgrading your electrical system | CivNick | I.C.E., Electrical, Security, & Navigation | 9 | 08-28-2006 08:08 PM |
