LinkBack (8) Thread Tools Display Modes
Old 11-13-2007, 05:01 AM   #141 (permalink)
darailer's Avatar
your correct, even the escort manual (and everywhere ive read online) says to put it up high...ive heard that the higher you put it up, the less chance you have to detect lidar (at least lidar from the rear), but the better chances you have to detect radar from all direction. mounting it low on the dash isnt as effectivce because it cant see out the rear of the car and it has more obstructions looking out the front of the car (other cars)...look at it this way, if ur eyes were at the level of the radar detector and it was mounted low on the dash, you couldnt see as well in front, back or to the sides of you right? but if it was mounted high, then you have a better perspective of traffic and everything else around you. you just have to figure out what type of radar (or lidar) the police use around where you drive and go from there. hope this helps
darailer is offline   Reply With Quote
Old 11-13-2007, 05:50 AM   #142 (permalink)
KenB's Avatar
Ken
Not sure about the other manufacturers, but the Valentine manual says, "Valentine One works best when mounted high in the windshield, and toward the center between the windshield pillars. Use your choice of windshield or visor mounts." I took this heart and that's why you see mine mounted above my rear view mirror in the picture above.
KenB is offline   Reply With Quote
Old 11-13-2007, 08:44 AM   #143 (permalink)
benmunger's Avatar
Yup, higher is better for radar. Closer to headlights is better for lidar.
benmunger is offline   Reply With Quote
Old 11-21-2007, 05:14 PM   #144 (permalink)
darailer's Avatar
+1 for you benmunger. I just did the install in my car and with your guys help, it was super easy. yet more confirmation that the wire to tap into for the 07 SIdan is purple.
Old 11-24-2007, 01:15 AM   #145 (permalink)
darailer's Avatar
My first time uploading pics! Thought i would show some pics of the install. I put it to the side of the rearview so i dont have to look very far to see it, the mute button is easy to reach and so it has a clear 360 view
took em at night so i had to work around the flash in the rearview
Thanks once again, great DIY
Old 11-26-2007, 09:45 AM   #146 (permalink)
benmunger's Avatar
Im glad you liked the DIY...
FYI, if you flip down your sunvisor it's going to hit the radar detector.
Old 12-01-2007, 03:19 AM   #147 (permalink)
ballorfall's Avatar
nice write up...I just hardwired my Valentine one on the sedan. Thanks
ballorfall is offline   Reply With Quote
Old 12-01-2007, 10:37 AM   #148 (permalink)
GORDATA's Avatar
Big Daddy Surge
Ballorfall- Post a pictures, I have a valentine one but dont know where to mount it.
GORDATA is offline   Reply With Quote
Old 12-01-2007, 10:42 AM   #149 (permalink)
KenB's Avatar
Ken
Old 12-01-2007, 11:27 AM   #150 (permalink)
GORDATA's Avatar
Big Daddy Surge
Did you use double sided tape or velcro.
Old 12-01-2007, 11:38 AM   #151 (permalink)
KenB's Avatar
Ken
The suction cups on the V1 are horrible so I used industrial grade Velcro instead. Works great - mounts solid and has never slipped, moved, or fallen.
Old 12-01-2007, 01:16 PM   #152 (permalink)
darailer's Avatar
i use sunglasses so im not to worried. i never thought about that tho. thanks
Old 12-12-2007, 02:12 AM   #153 (permalink)
Rabbit's Avatar
How do you tap into the green wire exactly?
Do you just cut it, and connect the green wire to the hardwire that will connect to the detector?
Rabbit is offline   Reply With Quote
Old 12-12-2007, 09:55 AM   #154 (permalink)
benmunger's Avatar
dont cut it... just strip off some of the green rubber insulation and twist the positive (usually red) wire from your radar detector, to the cars green wire.
Old 12-12-2007, 10:17 AM   #155 (permalink)
Undispu7ed's Avatar
Jon
If you guys are having trouble with mounting the radar with suction cups, go to a tint shop and have them tint the windshield with a strip. Costs 10 bucks at every reliable tint shop from where I live. Its main purpose is to block the sun when you're driving, but it's also useful for that.
Undispu7ed is offline   Reply With Quote
Old 12-13-2007, 05:50 PM   #156 (permalink)
Rabbit's Avatar
Thanks benmunger
Old 12-28-2007, 06:00 PM   #157 (permalink)
Undispu7ed's Avatar
Jon
Just an update, for my 08 Si coupe the pink wire was the 12V power.
Old 12-28-2007, 06:40 PM   #158 (permalink)
vince1128's Avatar
Vince
i just have the shitty $49 target cobra with just the ac adaptor, can this be hard wired? b/c it seems like you guys are talking about expensive detectors that come with wires already set to hardwire?
vince1128 is offline   Reply With Quote
Old 12-28-2007, 06:58 PM   #159 (permalink)
Undispu7ed's Avatar
Jon
Yeah, cut the black wrapping and you should take the red wire (from the wire from the AC adapter) and tap it into the 12V wire inside the map light.
Old 12-28-2007, 10:17 PM   #160 (permalink)
vince1128's Avatar
Vince
o ok cool thanks alot bro
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/15518-diy-radar-detector-hard-wire.html
ClubCivic.com - Honda Civic Forum - View Single Post - Map LIght Removal This thread Refback 02-23-2008 08:12 PM
DIY: radar detector hard wire - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-07-2008 10:15 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 03:33 PM
DIY: radar detector hard wire - Page 9 - 8th Generation Honda Civic Forum This thread Refback 01-15-2008 03:43 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-13-2008 09:49 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-09-2008 10:50 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-08-2008 10:10 PM
DIY: radar detector hard wire - Page 10 - 8th Generation Honda Civic Forum This thread Refback 12-30-2007 09:45 AM
DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) GulfCoastGhostHunters Audio 300 07-04-2009 07:18 AM
DIY: Turn Signal Mirrors CameronJr9 Lighting 167 05-14-2009 10:54 PM
upgrading your electrical system CivNick I.C.E., Electrical, Security, & Navigation 9 08-28-2006 08:08 PM
