DIY: radar detector hard wire - Page 7 - 8th Generation Honda Civic Forum
LinkBack (8) Thread Tools Display Modes
Old 07-03-2007, 03:21 PM   #121 (permalink)
benmunger's Avatar
Originally Posted by s7mk
If i got the cig adapter on that thing... when i chop of the adapter, are there gonna be 2 wires (ground, power) inside the 1 thick black wire?? or is there gonna be some other confusing **** in there?
Unscrew the plug... inside is a red (+) and black (-) wire.
benmunger is offline   Reply With Quote
Old 07-09-2007, 05:50 PM   #122 (permalink)
black07coupe's Avatar
ya i just got my detector today, i opened up my dome light and theres only 1 wire, i dont even have that harness you guys show in the pics.
black07coupe is offline   Reply With Quote
Old 07-10-2007, 09:29 AM   #123 (permalink)
i have the map light problem now too, because i tapped into the 1 wire that is coming down to the lights.
Old 07-11-2007, 12:34 AM   #124 (permalink)
suorum's Avatar
Nice man! Good Job! I will certainly used to install my radar! Thanks!!
suorum is offline   Reply With Quote
Old 07-29-2007, 09:05 PM   #125 (permalink)
BigGeorge's Avatar
George
Depending on your radar detector bracket, you can pull the headliner down a little bit (where it meets the windshield) and slide the suction cups up there. On my other civic I did the same thing and had no problems with it and it was there for five years. The detector I have is a Bel vector 995, I believe.
BigGeorge is offline   Reply With Quote
Old 08-17-2007, 06:43 PM   #126 (permalink)
sidecut305's Avatar
FA Crew #81
Hardwired my new detector this week on an 07 si sedan. I also tapped into the purple wire (believed to be the 12 V for sedans) and my detector works perfectly. Turns on when key is turned and turns off when door is opened.
Excellent DYI, +1
sidecut305 is offline   Reply With Quote
Old 08-28-2007, 04:04 AM   #127 (permalink)
ldawson77777's Avatar
V1 Display not working
I purchased a V1 last week and hard wired it the same day. It worked great until today. When I plugged it in today, it powered up fine. It went through it's routine of tests (loud beep, softer beep, etc.), but then the display shut off. I disconnected it and tried again. Same thing. I started driving and left it in that state (a blank display) and behold, the detector is on, but the display was not working. When I passed by the super market, I got the usual multiple bogey alerts from the doors, but NO lights at all!?
I then hooked up the detector to the cigarette lighter adaptor and it worked perfect (display came on and stayed on). I ripped the hardwire out and started again thinking it was just a poor ground. I ruled this out because I was grounding it to bare sheet metal (I scraped the paint away to make sure it was a good connection). I then checked the 12V+ with a multi-meter and is was reading 12.22V, which is just fine. I tried two different phone connectors (both the straight and curled one that came with it) and the same blank display appeared. The only thing I can think of is the direct-wire power adaptor is bad. Anyone else seen this before? Anyone else have any other ideas? Thanks for the insight!
ldawson77777 is offline   Reply With Quote
Old 08-28-2007, 04:05 AM   #128 (permalink)
Oh and, thanks for the DIY. Very helpful. Saved me time having to use the multi-meter (that is, until this incident that happened above).
Old 08-30-2007, 11:01 AM   #129 (permalink)
goixiz's Avatar
Can a regular phone wire (for X50 Passport) be used
I plan to fuse it as well but all it needs is 12 V supply - correct ??
goixiz is offline   Reply With Quote
Old 08-30-2007, 11:11 AM   #130 (permalink)
^Yes.
achapman is offline   Reply With Quote
Old 08-30-2007, 11:13 AM   #131 (permalink)
GORDATA's Avatar
Big Daddy Surge
You are probably hook it up to the optional display or something related to that. Check the wiring, Also do you have a pictures of where did you place the Radar, I could not decided so I haven't hardwire it yet.
GORDATA is offline   Reply With Quote
Old 08-30-2007, 11:53 AM   #132 (permalink)
benmunger's Avatar
Silly question... do you have it on dark mode?
Old 09-02-2007, 01:30 AM   #133 (permalink)
Wally's Avatar
EX Coupe MT
Version #2 RADAR Detector Hard Wire Install Method / Position
For my new '07 EX Coupe, I installed my RADAR detector in a different place. Far left, down on the dash. I used this position on my '06 EX Sedan for 20+ months with positive results. So lets not argue about positioning for now. This post is more to post about the wire run location and what fuse #8 can do for you - see below . ..
Next I hid the wires in the trim along the door jam down to the fuse box (see the pictures). The trim just folds away and you can tuck the wire behind it for a clean look.
Then I used the "un-used" fuse slot #8 to provide power. Yes, this slot will provide power - not sure why Honda is not using it - probably for another feature I don't have (maybe the Auto dimming mirror?)
Turns out the #8 fuse slot is controlled / switched by the ignition switch, so my detector is only powered on when the key is in and the engine is on (just the way I want it) .
When you tap the #8 fuse, the lower part is the positive / power output, so your wire should tap the upper fuse slot (so your fuse, will "fuse" the detector/powered device). My detector uses little power, so I used a 7.5 Amp ATM fuse.
Also, found out the fuse slot #7 is always powered on so keep that in mind for other projects where you want constant un-switched power.
There is a Phillip's slotted bolt/screw (not pictured) that holds the fuse box to the metal frame (to the top right of the fuse box). This bolt is a perfect ground for projects like this. I used a "C" shaped quick connect for the ground wire from the detector here - works nice and is out of the way.
FYI,
Wally
Wally is offline   Reply With Quote
Old 09-10-2007, 01:23 PM   #134 (permalink)
ryker's Avatar
Anybody install Passport SRX, SR7, or Zr3's?
ryker is offline   Reply With Quote
Old 10-07-2007, 11:34 AM   #135 (permalink)
KenB's Avatar
Ken
Thank you, benmunger. I recently picked up an '07 Si Sedan. After driving trucks and sedans for years, it's been too easy to go too fast. Never owned a radar detector before so I picked up a Valentine 1. Had been thinking of ways to do a clean hardwired install and then came across your DIY. Excellent!
A couple of things to add -- the Valentine wouldn't fire up initially after getting the wiring all done. Double checked the fuse, the positive tap, ground, and everything was fine. The Direct-Wire Power Adapter has two jacks -- accessory and main unit. I had the power plugged into the 'Main Unit' jack. Seemed to make sense to me at the time. Out of sheer frustration, I unplugged the power line on the Direct-Wire Power Adapter from 'Main Unit' and plugged it into 'Accessory' and, voila, she came to life.
Also, more confirmation that the purple wire (4th one in on the harness) on Si Sedan is the right one to use. Powers up with ignition. Powers down when you open the door.
Thanks again. Here's some pics. Really pleased with the outcome.
KenB is offline   Reply With Quote
Old 11-04-2007, 06:53 PM   #136 (permalink)
SiRCiviC805's Avatar
(J)
Very clean and straight foward instruction. I have a 08 civic si coupe, are the colors the same as th 06's
SiRCiviC805 is offline   Reply With Quote
Old 11-04-2007, 07:13 PM   #137 (permalink)
KenB's Avatar
Ken
Doubtful that it changed. It should be the purple wire in the harness.
Old 11-07-2007, 11:06 PM   #138 (permalink)
Excellent thread. I just installed a hard wire for a Bel Pro RX65 this last weekend in my 2007 Civic coupe. Your information was dead on, right down to the color coding on the hot wire to tap. I used a black modem POTS wire, they tend to be thicker. Thanks again for the time spent writing the thread.
Keathh is offline   Reply With Quote
Old 11-12-2007, 07:32 PM   #139 (permalink)
darailer's Avatar
Anyone that can help, im getting ready to do this install but i dont know what 3M t tap to use. i have the one that works with 14-18 gauge wires. is the purple wire for the 07 civic SIdan bigger than that? thanks guys
darailer is offline   Reply With Quote
Old 11-13-2007, 05:26 AM   #140 (permalink)
Chase's Avatar
Chase
Just was pointed to this thread, I did not follow this DIY but I would like to show the placement of my device, In theory a RD would work better the higher it is right? When I see people mounting them in the lower corner it makes Me think They aren't getting the performance that could make a difference.. Someone please confirm..
Chase is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/15518-diy-radar-detector-hard-wire.html
ClubCivic.com - Honda Civic Forum - View Single Post - Map LIght Removal This thread Refback 02-23-2008 09:12 PM
DIY: radar detector hard wire - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-07-2008 11:15 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 04:33 PM
DIY: radar detector hard wire - Page 9 - 8th Generation Honda Civic Forum This thread Refback 01-15-2008 04:43 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-13-2008 10:49 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-09-2008 11:50 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-08-2008 11:10 PM
DIY: radar detector hard wire - Page 10 - 8th Generation Honda Civic Forum This thread Refback 12-30-2007 10:45 AM
DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) GulfCoastGhostHunters Audio 503 01-23-2012 12:21 AM
DIY: Turn Signal Mirrors CameronJr9 Lighting 221 12-16-2011 11:09 AM
upgrading your electrical system CivNick I.C.E., Electrical, Security, & Navigation 9 08-28-2006 09:08 PM
