DIY: radar detector hard wire - Page 3 - 8th Generation Honda Civic Forum
LinkBack (8) Thread Tools Display Modes
Old 02-14-2007, 10:54 AM   #41 (permalink)
benmunger's Avatar
Originally Posted by xmx250
I'm gonna try this. What kind of tape? like scotch tape?
try packaging tape with a glossy surface...
benmunger is offline   Reply With Quote
Old 02-14-2007, 09:00 PM   #42 (permalink)
JZILLA's Avatar
yeah clear packaging tape is what i used
JZILLA is offline   Reply With Quote
Old 02-20-2007, 04:06 PM   #43 (permalink)
Member # 4524
GlxyGry06Si's Avatar
what is the dot matrix used for. can we scrape a lil portion of it off so we can put the suction cups on. im gonna do the install today. thnx
Originally Posted by TheIncident88 View Post
Sometimes I actually wonder if you are serious or just ******* with me. If it's the latter, then well played sir. If not, then I shall return my palm to it's previous position upon my face.
Old 02-20-2007, 04:27 PM   #44 (permalink)
Member # 4524
bump.........................
Old 02-21-2007, 10:58 AM   #45 (permalink)
Member # 4524
super easy install. 10 minutes and it works perfect. thanks for the detailed do it yourself instructions.
Old 02-21-2007, 11:03 AM   #46 (permalink)
06si's Avatar
Kenny G
subscribed
06si is offline   Reply With Quote
Old 02-22-2007, 01:45 AM   #47 (permalink)
Coop's Avatar
Coop
Hows that silicone glue working for you, any probs?
Coop is offline   Reply With Quote
Old 02-22-2007, 04:27 AM   #48 (permalink)
rmfa's Avatar
Ronnie
I ended up just sticking mine to the tint eyebrow... It works great
Old 02-22-2007, 05:32 PM   #49 (permalink)
Member # 4524
good idea. what is the dot matrix for? anyone????
Old 02-22-2007, 05:51 PM   #50 (permalink)
rmfa's Avatar
Ronnie
Supposedly, it helps block the sun. It doesn't do JACK but cause problems.
Old 02-22-2007, 08:05 PM   #51 (permalink)
Member # 4524
so i can scrape that off so i can get the radar detector up even higher. what do you think. should i
Old 02-28-2007, 07:06 PM   #52 (permalink)
xmx250's Avatar
This is a great DIY. I just mounted mine right below the rear view. I'm happy with it there.
xmx250 is offline   Reply With Quote
Old 03-01-2007, 02:32 PM   #53 (permalink)
hey guys, my first post. just received the hardwire to do the install, but there are two parts on one of the ends. what i mean is that there is that one end where you connect the wire to the detector and the other end that you tap into the car with. the end where you tap into the car with has two ends. what do i do with them? I am completely clueless when it comes to this stuff. Ive never done this. any help would be greatly appreciated. Thanks everyone
ikylim is offline   Reply With Quote
Old 03-01-2007, 03:10 PM   #54 (permalink)
never mind, i got it done. didn't realize that that was the ground. but anyway, i have a 07 si navi and i connected it to the thicker green wire, but it wasn't the darker one. It was the fourth from the end of the harness and it works. only thing is that when im starting the engine, my passport says LOW VOLT. Is this going to be a problem?
Thanks
Old 03-01-2007, 03:14 PM   #55 (permalink)
Coop's Avatar
Coop
well one of the two wires if for your power (positive) and the other is your ground (negative). The positive for mine has a thin red line on it and this is the one that you connect to the power in your car via the T clamp. The other wire (ground) is the one that you have to connect to the chassis of the vehicle. On this you connect via one of the screws. Hope that helps. If there is no thin red line, thin you have to find out which one is round and which one is positive.
Old 03-01-2007, 05:32 PM   #56 (permalink)
xmx250's Avatar
Maybe you have the wrong wire? Mine doesnt say low volt on start up
Old 03-02-2007, 02:55 AM   #57 (permalink)
i guess it works fine. checked the voltage when the engine is on and it's around 14.7V. thanks guys
Old 03-02-2007, 03:03 AM   #58 (permalink)
JZILLA's Avatar
my bel 995 says low volt when i push both windows at the same time
Old 03-02-2007, 03:05 AM   #59 (permalink)
JZILLA's Avatar
other than that it is fine
Old 03-02-2007, 03:09 AM   #60 (permalink)
gbae007's Avatar
I'm going to have to do this.
Subscribed for later...
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/15518-diy-radar-detector-hard-wire.html
ClubCivic.com - Honda Civic Forum - View Single Post - Map LIght Removal This thread Refback 02-23-2008 09:12 PM
DIY: radar detector hard wire - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-07-2008 11:15 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 04:33 PM
DIY: radar detector hard wire - Page 9 - 8th Generation Honda Civic Forum This thread Refback 01-15-2008 04:43 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-13-2008 10:49 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-09-2008 11:50 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-08-2008 11:10 PM
DIY: radar detector hard wire - Page 10 - 8th Generation Honda Civic Forum This thread Refback 12-30-2007 10:45 AM
DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) GulfCoastGhostHunters Audio 503 01-23-2012 12:21 AM
DIY: Turn Signal Mirrors CameronJr9 Lighting 221 12-16-2011 11:09 AM
upgrading your electrical system CivNick I.C.E., Electrical, Security, & Navigation 9 08-28-2006 09:08 PM
