DIY: radar detector hard wire - Page 18 - 8th Generation Honda Civic Forum
LinkBack (8) Thread Tools Display Modes
Old 02-01-2010, 09:58 AM   #341 (permalink)
fl07si's Avatar
i did this on saturday..... on an 07 sedan its the purple wire. got it all wired up and it wasnt working so i was getting mad so i said to hell with it and screwed everythign back in and it started working..... everythign must be screwed in for the lights to be grounded and to get power.
was a good DIY
fl07si is offline   Reply With Quote
Old 03-09-2010, 06:27 PM   #342 (permalink)
Brandon Ly
so i attempted to do this- but it didn't work for me. I have a 08 ex coupe, and ideas on which wire i should cut into? in the end i put everything back together and now my dome lights dont even come on! great!
gold3ndragon8 is offline   Reply With Quote
Old 03-09-2010, 07:52 PM   #343 (permalink)
Brandon Ly
ahh.. i blew a fuse! that's why.. any one know if the wire from the radar.. white or red = ground wire?
Old 03-09-2010, 07:56 PM   #344 (permalink)
FijiBlueFG2HT's Avatar
Mitch [Ryan #3]
Originally Posted by TexasK20Z View Post
During the time without a radar detector, I was pulled over 17 times. All but one of those resulted in tickets. Since I got the radar detector, I have been pulled over twice (once was total BS... the other laser). The time with the laser, I was gonna get a ticket regardless... something about 85 in a 60 in traffic (I was passing)... although the intergrated units offr some advantages, I don't think they justify the additional cost... that is... unless you are talking about Lidatek products... :devil:
How about you put normal colored wheels on your car and stop speeding?
FijiBlueFG2HT is offline   Reply With Quote
Old 03-09-2010, 09:32 PM   #345 (permalink)
Chase's Avatar
Chase
I doubt the guy is on here anyone, he posted that over 3 years ago.
Chase is offline   Reply With Quote
Old 04-21-2010, 06:08 PM   #346 (permalink)
matt
i hate to bring a thread back from the dead, but it's better than starting a new thread for 1 question IMO. Anyways, I know practically nothing about electrical wiring/systems, and am trying to do this with my GPS. what exactly does it mean to "tap into the green wire"? Do I have to cut it, strip it and connect the GPS wire to it and solder it back together? Also it only said that the positive goes to the green. where does the negative go?
Sorry for the ignornace, but I've looked through a bunch of DIY's on this type of thing, and the OP expects you to already know how to do this stuff, so I can't find the info.
mattgrimes is offline   Reply With Quote
Old 05-03-2010, 06:13 PM   #347 (permalink)
2007 Civic EX Coupe:
I can definitely confirm that it's the Green Wire, 4th from the left, thicker of the two green wires.
Stripped my RD's 12V adapter (Red+/White-) and bought a Self Stripping - Tap Connector.
Tapped the Red wire to the Green, stripped the white wire by 1.5 inches then swirled it on the dome light screws.
VIOLA! A 10 Minute Install - Thanks to the DIY.
* Just a suggestion, make sure you purchase a tap connector. They're only $2 for a pack of 3. Don't ever strip the wires yourself from the harness as you may risk blowing your fuses.
armon is offline   Reply With Quote
Old 08-01-2010, 06:04 PM   #348 (permalink)
KevinB91's Avatar
Hey,
Just and FYI, for the 2008 si coup the positive wire is pink.
-Kevin
KevinB91 is offline   Reply With Quote
Old 11-29-2010, 09:46 PM   #349 (permalink)
justin13031's Avatar
Justin Jacobs
i have a 2010 si coupe... tried to wire to the map lights and it wont work this way for 2008 to 2010. it has 2 12v sources up there but both are constant ( meaning they are always on and if you tap them your device will always be on 2 ,, draining your batt when the car is not in use.. i tapped the fuse box. port #8 for my power. works great and turns off when car is turned off. there is a diy on his thread about half way through.. the fuse box is a much easier hookup than the map light ne ways. just wanted to put in my 2 cents to help others.. 2008-2010 WILL NOT WORK WHEN TAPPING MAP LIGHTS ONLY TAPPING FUSE PORT 8.. i wasted 2 hrs cutting up my map light harness figuring this out lol.. go to auto store and ask for an ADD A CIRCUT KIT for your fuse box.. only 5 dollars.. ps i used this method to hardwire a tom tom gps so it works as well
justin13031 is offline   Reply With Quote
Old 11-29-2010, 09:58 PM   #350 (permalink)
Man.. A very old thread but ill do this :$
basang_pekpek is offline   Reply With Quote
Old 12-24-2010, 05:50 PM   #351 (permalink)
Lex31905's Avatar
Lex Smith
I read up to like pg 10 on this thread and if its after that sorry I'm impatient.
Has anyone found a way to keep the mute button on the cig lighter control functional?
I would like to keep it if I can, but understand if its not possible. Also, can I get a break down of the phone wire trick of what wire does what ie. Black = ground Red = power but what about the other two???
Wow, reading that again I can't fully understand myself.... Ask questions.. I have the dumb right now.
Lex31905 is offline   Reply With Quote
Old 01-04-2011, 02:23 PM   #352 (permalink)
BTB08Si's Avatar
todd
i did this it worked out great thanks
BTB08Si is offline   Reply With Quote
Old 02-07-2011, 01:57 PM   #353 (permalink)
hndawhre07's Avatar
Jeff
on a 2007 sedan. what wire should i tap into for power by the fuse box under the steering wheel? i and grounding to the fuse box bolt that holds it up but i dont know which wire to attach to for power
hndawhre07 is offline   Reply With Quote
Old 02-07-2011, 02:55 PM   #354 (permalink)
UNIQUE MODZ
sleeper101's Avatar
Lee
use a test light to find the power wire
Front Splitters,Throttle Body Spacers, Gaskets, Pyrex Glass Coolant Line, Polycarbonate Fog lens Replacements, Polished Stainless,Clear or Colored Mannifold and Spark Plug Covers,
UNIQUEMODZ.NET http://youtu.be/AdHBfbH5CVY
sleeper101 is offline   Reply With Quote
Old 04-03-2011, 01:48 PM   #355 (permalink)
Jay4dnb's Avatar
Jay a.k.a. JDM AS FUK!!!
Just did this install on a 2011 FA5 and the power wire was a purplish/pinkish one. Thanks for the info! +1
Jay4dnb is offline   Reply With Quote
Old 04-10-2011, 09:38 PM   #356 (permalink)
High Revs Si's Avatar
Ron
Question
I just wired it up to my '11 FG2 and noticed theres a pink wire and purple wire so I tapped into the pink. It works, then shuts off when I open the door which is fine because I'm exiting the car, but when I lock the doors with the remote from the outside it turns back on again. I'm assuming I'll have to switch wires and tap into the purple one? Did/do you have this issue? I don't want to leave it on all the time or have to use the power button on the unit, I just want it to turn on when I'm using the car and off when I'm leaving the car.
High Revs Si is offline   Reply With Quote
Old 04-14-2011, 09:53 PM   #357 (permalink)
Ron
Question
I noticed power to the sunroof cuts off when the doors opened, is there a separate power lead to the sunroof switch that I can tap into instead of the lights?
Old 04-14-2011, 11:25 PM   #358 (permalink)
Jay4dnb's Avatar
I am having the same issue... I am going to try a few different wires this weekend and I will let you know...
Old 04-15-2011, 07:28 PM   #359 (permalink)
Ron
Thanks man, perhaps it might be one of the wires on the separate smaller harness that clips into the back-left side of the assembly.
Old 04-22-2011, 12:03 PM   #360 (permalink)
Jay4dnb's Avatar
Had a rainy day today, no work, so I decided to go ahead and try each wire... I have come to find that anyone with a 2009+ Si cannot get the same results as the guy who did this thread. There is not a constant current running to any of the wires in that area. The yellow wire that is up there is the moon roof wire, but unlike previous years that does not have constant current, so jumping from that wire means you will only get power to your radar detector when you are opening, closing or raising your moon roof.
So that leaves 2 options... tap into the pinkish wire and have your radar detector turn on and of every time you open your doors and stay on even when the car is off... Or do a direct wire into the fuse box.
I am eventually going to switch to the fuse box option myself.
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/15518-diy-radar-detector-hard-wire.html
ClubCivic.com - Honda Civic Forum - View Single Post - Map LIght Removal This thread Refback 02-23-2008 09:12 PM
DIY: radar detector hard wire - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-07-2008 11:15 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 04:33 PM
DIY: radar detector hard wire - Page 9 - 8th Generation Honda Civic Forum This thread Refback 01-15-2008 04:43 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-13-2008 10:49 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-09-2008 11:50 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-08-2008 11:10 PM
DIY: radar detector hard wire - Page 10 - 8th Generation Honda Civic Forum This thread Refback 12-30-2007 10:45 AM
DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) GulfCoastGhostHunters Audio 503 01-23-2012 12:21 AM
DIY: Turn Signal Mirrors CameronJr9 Lighting 221 12-16-2011 11:09 AM
upgrading your electrical system CivNick I.C.E., Electrical, Security, & Navigation 9 08-28-2006 09:08 PM
