DIY: radar detector hard wire - Page 17 - 8th Generation Honda Civic Forum
LinkBack (8) Thread Tools Display Modes
Old 09-25-2009, 12:37 PM   #321 (permalink)
just confirmed that there is no accessory wire where the lights are, only one that had 12v was the two wire connector (dark green is positive) used a voltmeter to check. I dont know if i should throw a wire up there from the fuse box, any recommendations? i dont think the radar would draw that much anyways to kill the battery if i left it over night but I will be checking (just to make sure and cover forgetfulness)
mechandi1 is offline   Reply With Quote
Old 10-26-2009, 10:12 PM   #322 (permalink)
Just did the install on an 06 EX Sedan. It was the purple wire. Worked great! thanks
I really didn't want to go the route of having to wire it down the A pillar to the fuse box. I have it wired to my map light in my BMW and was hoping I could do the same in this car. Lots of room to hide the wires up there too
Hinz is offline   Reply With Quote
Old 11-05-2009, 08:36 PM   #323 (permalink)
does anyone know off hand what wire to tap into on the 09 or 10 civics four door I went to do it thinking it was the same as my 06 si and the harness and all the wires were different
civic404 is offline   Reply With Quote
Old 11-06-2009, 07:21 PM   #324 (permalink)
Just pick up a cheap multimeter and test which wire has the acc on 12v source. Should take a min or two.
Old 11-13-2009, 05:28 PM   #325 (permalink)
darkstar107's Avatar
Shawn
Why not, instead of naming the color of the wire (which, it sounds like is different between years) someone say what pin number in the harness the wire is connected to? That way, as long as everyone has the same harness it doesn't matter what color the wire is...
With that said, I don't wanna read through the whole thread so is the wire that you want to tap into green on the 07 Coupes?
darkstar107 is offline   Reply With Quote
Old 11-13-2009, 06:52 PM   #326 (permalink)
Shawn
Nevermind...I just went with the flow and my gut feeling and was right lol. I have an 07 EX Coupe and it was the big dark green wire. When you first remove the light enclosure the harness is laying down and wires point to the front. The 4th one from the left (if you are looking at it how you took it out) on the top row is the one you want to connect it to. Provided the harnesses are the same. The wire is a little bigger than the rest of them.
Old 11-13-2009, 10:43 PM   #327 (permalink)
DTNguyen107's Avatar
You guys think this will work for a small handheld navi?
DTNguyen107 is offline   Reply With Quote
Old 11-19-2009, 03:37 PM   #328 (permalink)
hwudoin's Avatar
Craig
Well, I read all the pages on here about how to wire my Belltronics Sti... I'm still confused. Green wire, pink wire, dome light wire, etc.... So I thought I'd just give it a go on my own. The only thing I'm clear on is that the green one won't work at all and the pink one works as long as the dome light is off and that's including after you shut off the car and the light goes out.
So... Do any of the wires up there in the dome light area act as a 12V acc? I have an '08 Si. Thanks again in advance.
hwudoin is offline   Reply With Quote
Old 11-19-2009, 03:38 PM   #329 (permalink)
hwudoin's Avatar
Craig
Oh... And it's a sedan, not a coupe. :o)
Old 11-19-2009, 03:59 PM   #330 (permalink)
I'm having the same prob as you tried a couple and ran into the same situation what i think I'm going to end up doing is just buying a mini fuse tap and taping into one of the fuses in the interior fuse box
Old 11-20-2009, 08:29 AM   #331 (permalink)
hwudoin's Avatar
Craig
Has anyone ever blown a fuse using a volt meter? Just by testing the wires above the map lights, I blew 3 fuses! There was no acc power to be found in my car up there. I did find one wire that was 12v constant, but after the fuse poping thing, I thought it would be more wise to go down to the fuse box. All wired in now and the STi is working great! :o)
Old 11-20-2009, 11:23 AM   #332 (permalink)
what fuse did you tap into
Old 11-20-2009, 10:51 PM   #333 (permalink)
Jacob
This is a DIY I have to try.
ViagraFalls is offline   Reply With Quote
Old 11-20-2009, 11:38 PM   #334 (permalink)
hwudoin's Avatar
Craig
It blew a fuse under the hood called "back up", an acc fuse under the dash, and another 5V fuse under the dash as well. Before we fixed the fuses, the sunroof had stopped working, no int lights at all, radio didn't work, headlights would only come on with the key turned on as well as the door chime would only come on after the key was turned!!
Glad we got it figured out now! After taping into the fuses below and running the wires from there... All is good and working great!
Old 11-29-2009, 07:58 AM   #335 (permalink)
mrutter1's Avatar
no suction cups/perfect aim
Suction cups well...suck. Do a google search on V1 brackets if you like what you see. This bracket allows proper air for your unit. Our mirror shaft dia. is .750. Wire is run down to fuse block after slightly lowering headliner and removing and replacing A pillar. V1 operates on key.
DIY: radar detector hard wire-dsc00231.1.jpg
mrutter1 is offline   Reply With Quote
Old 11-29-2009, 07:59 AM   #336 (permalink)
mrutter1's Avatar
aim...not air
Old 12-12-2009, 04:41 PM   #337 (permalink)
busychild's Avatar
Just thought I would add my first mod to my GGM Si Sedan. Suction cups didn't work too well and I found this for my SpecV last year. Works on the Civic too!
After seeing Taildragger's pic, I like that mounting for the remote mute.
BTW, I have some better pigtails that I used to tap the fusebox. I will snap a pic tomorrow.
busychild is offline   Reply With Quote
Old 12-16-2009, 12:19 AM   #338 (permalink)
Xysatnaf's Avatar
Lam Tran
what's the color wire for 08 coupe?
Xysatnaf is offline   Reply With Quote
Old 12-21-2009, 05:37 AM   #339 (permalink)
Eric.'s Avatar
Eric
So are we confirming that wiring into the dome light/sunroof harness is not an option to have switched power in a 2008 Si sedan? I also found that there were only three hot pins.
Does anyone have some pictures of how I'd get the headliner pulled down enough to tuck the wire as well as getting it under the A-pillar cover and the rest of the way to the fuse box if I end up doing it that way?
Eric. is offline   Reply With Quote
Old 01-29-2010, 01:44 PM   #340 (permalink)
utilitarian's Avatar
I've already ran my V1 cable up to the rearview and don't want to tap into the sunroof (as I've always done) since I have an '08 sedan and there seems to be confusion about doing such.
Having never tapped into the fuse box, is this "add a fuse" accessory all I need to get power from the #8 tap that everyone seems to use? I'll ground the V1 kit to the bolt on the right side of course.
thanks so much,
Matt
'08 NBP Si Sedan
utilitarian is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/15518-diy-radar-detector-hard-wire.html
ClubCivic.com - Honda Civic Forum - View Single Post - Map LIght Removal This thread Refback 02-23-2008 09:12 PM
DIY: radar detector hard wire - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-07-2008 11:15 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 04:33 PM
DIY: radar detector hard wire - Page 9 - 8th Generation Honda Civic Forum This thread Refback 01-15-2008 04:43 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-13-2008 10:49 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-09-2008 11:50 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-08-2008 11:10 PM
DIY: radar detector hard wire - Page 10 - 8th Generation Honda Civic Forum This thread Refback 12-30-2007 10:45 AM
DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) GulfCoastGhostHunters Audio 503 01-23-2012 12:21 AM
DIY: Turn Signal Mirrors CameronJr9 Lighting 221 12-16-2011 11:09 AM
upgrading your electrical system CivNick I.C.E., Electrical, Security, & Navigation 9 08-28-2006 09:08 PM
