DIY: radar detector hard wire - Page 14 - 8th Generation Honda Civic Forum
LinkBack (8) Thread Tools Display Modes
Old 07-20-2008, 01:47 PM   #261 (permalink)
8th Knight's Avatar
Allen
Oops, pics were supposed to be replaced w/ mine. Sorry.
8th Knight is offline   Reply With Quote
Old 07-20-2008, 05:04 PM   #262 (permalink)
TailDragger's Avatar
Scott
^^^ That's pretty nice! It's definetly not a simple install, but it's clean....
Next I'm going to add another switch to turn on and off the DRL's.
TailDragger is offline   Reply With Quote
Old 07-20-2008, 10:56 PM   #263 (permalink)
Chase's Avatar
Chase
This would be nice, Currently I just have the fuse pulled..
Chase is offline   Reply With Quote
Old 07-21-2008, 02:29 AM   #264 (permalink)
Scott
Yeah I have that fused pulled too and I think a switch would be sweet, because sometimes I'd like them on. So my plan is to add another switch right under this one in the center. But if you were to add a switch for DRL's, this is exactly what it could look like.
Old 07-21-2008, 12:39 PM   #265 (permalink)
B-Stylz's Avatar
'08 Si-R
Originally Posted by Ntruder View Post
There are none. Only 3 hot lines. No ACC lines in the map light harnesses. (at least in the 08 Si coupe) For the time being, I just have mine wired to a 12v line that stays on. It shouldn't be a problem unless I go on vacation for a month and leave the radar on.
Strange... i know i read of a few other '08's installing at the map light location in this thread.
B-Stylz is offline   Reply With Quote
Old 07-21-2008, 07:47 PM   #266 (permalink)
Scott
Yeah, I just checked all the wires up there and there are no ACC actuated positives, at least not in my Ex. There are constant positives and headlight actuated positives.
I saw the DIY thread about how to install your radar up there and they must have used a constant positive.
Old 07-21-2008, 07:51 PM   #267 (permalink)
Scott
Maybe there is hope for you.
Read this thread, about half or 3/4th down.
"12V when car is on. also it stays powered after you turn the ar off untill you open a door."
I didn't start my car to check the power, maybe Si is different. Worth a look.
Old 07-23-2008, 04:18 PM   #268 (permalink)
I hardwired my V1 about a month ago. Well I will try not to kid everyone my buddy did 99% of the work for me but we tested all the wires in the sunroof and none of them worked. We ended up finding a yellow wire under the dash that works 100% great. If you pop the piece of the dash off right below the steering wheel you will see a wiring harness with a yellow wire and you can just tap right into that. All the wiring is real close and I just ran the phone chord up the pillar and over to the center of the car. I will take some pics and post them up soon.
Eustace1080 is offline   Reply With Quote
Old 07-23-2008, 06:09 PM   #269 (permalink)
B-Stylz's Avatar
'08 Si-R
^ how come I can't use the same switched power wire that the compass mirror uses in my '08? should work yes?
Old 07-23-2008, 06:39 PM   #270 (permalink)
Scott
If you have swithced power to the compass mirror, that should work fine. I believe the Si has switched power up there, but not the Ex.
Old 07-23-2008, 11:06 PM   #271 (permalink)
The info in this thread is very accurate and very important IMHO. We thought we had two good wires up top but then when you lock the doors the wire have power to them again. That would result in your radar staying on 24/7 and I didnt want that. I would def recommend going down below to the yellow wire.
Old 07-23-2008, 11:59 PM   #272 (permalink)
AzNBiGBoI421's Avatar
can anyone explain to me why my sunroof doesnt work anymore? i cut the purple wire and my radar works, but not my sunroof. anything would help. thanks guys
AzNBiGBoI421 is offline   Reply With Quote
Old 07-24-2008, 09:40 AM   #273 (permalink)
Well if you used the tap from the radar detector, there is a good chance that you cut completely through the power wire for the sunroof but there is enough contact to power the radar.
Old 07-24-2008, 01:08 PM   #274 (permalink)
B-Stylz's Avatar
'08 Si-R
^ yep just retrace your footsteps
Old 08-05-2008, 06:32 PM   #275 (permalink)
Erik
Hell yes, just did my 9500ix this way too.
I do have a V1 for sale if anyone is interested PM me. :P
RanEnRui is offline   Reply With Quote
Old 08-08-2008, 11:59 AM   #276 (permalink)
Just so everyone knows I hard wired my V1 into my Auto dim Rear view on a 08. Works great.
natedog_37 is offline   Reply With Quote
Old 08-08-2008, 12:01 PM   #277 (permalink)
B-Stylz's Avatar
'08 Si-R
^ haha told ya so. good deal. any pics?
Old 08-08-2008, 12:10 PM   #278 (permalink)
I can get some pics tonight for everyone. Been like this for about a month with no problems. Hardest part was getting everything hidden since space is so tight.
Old 08-12-2008, 12:45 PM   #279 (permalink)
B-Stylz's Avatar
'08 Si-R
^ any pics yet?
Old 09-15-2008, 09:47 PM   #280 (permalink)
08SINHBP's Avatar
Tyler
just did this on my 08' si coupe. was a piece of cake. i skipped the headliner completely and went straight for the fuse box. i also used fuse spot #8. I have a escort X50 and just used a spare phone cord i had laying around. my cord ended up being green positive, red ground.
theres a small screw by the panel under the dash next to the fuse box i used for a ground. worked perfect. then i just used a 20a fuse (all i have, will switch out for 7.5a later) and plugged it into the top spot of #8. detector comes on when the key is on, turns off when key is off. doesn't matter if the door opens, or anything else. heres a few pictures.
I mounted it to the left and low. hid the wire the best and its pretty stealth. not in the line of sight at all.
And here is the fuse box/ screw i used as a ground. sorry for the crap quality, but you get the idea
08SINHBP is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/15518-diy-radar-detector-hard-wire.html
ClubCivic.com - Honda Civic Forum - View Single Post - Map LIght Removal This thread Refback 02-23-2008 09:12 PM
DIY: radar detector hard wire - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-07-2008 11:15 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 04:33 PM
DIY: radar detector hard wire - Page 9 - 8th Generation Honda Civic Forum This thread Refback 01-15-2008 04:43 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-13-2008 10:49 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-09-2008 11:50 AM
Radar detector jammer forum: View topic - my hardwired v940 *pix* This thread Refback 01-08-2008 11:10 PM
DIY: radar detector hard wire - Page 10 - 8th Generation Honda Civic Forum This thread Refback 12-30-2007 10:45 AM
DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) GulfCoastGhostHunters Audio 503 01-23-2012 12:21 AM
DIY: Turn Signal Mirrors CameronJr9 Lighting 221 12-16-2011 11:09 AM
upgrading your electrical system CivNick I.C.E., Electrical, Security, & Navigation 9 08-28-2006 09:08 PM
