#243 (permalink) | |
Christie
#244 (permalink) |
Scott
Thanks! Yeah if you look at the tweeter on the front right you can see a small indentation under the lip of the plastic trim. I just took a small flat head and popped it up. I never had to put too much pressure that I thought I'd damage the plastic. I can post a picture later.
#248 (permalink) |
so basically i have no idea what im doing.. lol.. i have all the wires together.. so i have a ground (round metal one with a hole in the middle) and the wire with the clear rubber thing over it.. what the hell do i do? i cannot understand any of this.. sorry im a newb. haha
#251 (permalink) | |
Derek
That ring is called a ground, it needs to be attached to a screw/bolt that connects to the car chassis. The other wire will be the power probably red, you can add this to your fuse box by going to an auto store and buying a $5 dollar thing thats called add a fuse or something like that. You can also tap this wire into other things but that may void warranty. Stop posting so much ffS? |
#253 (permalink) |
Has anyone done this on an 08 Si coupe?
I just put a voltage meter to every wire up there, and there are 2 wires that get power, but its not linked to the accessory function, meaning they always stay on. My brother's 06 EX has a switched wire, so it gets 12v only when the car is on. Anyone else install on an 08 si coupe? |
#259 (permalink) |
There are none. Only 3 hot lines. No ACC lines in the map light harnesses. (at least in the 08 Si coupe) For the time being, I just have mine wired to a 12v line that stays on. It shouldn't be a problem unless I go on vacation for a month and leave the radar on.
#260 (permalink) |
Allen
Left button is for the hidden garage door opener. I still need to paint the chrome bezel black. Middle is obviously the Passport 8500 remote. Right is obviously an aftermarket foglight switch that will soon be replaced w/ a factory switch as soon as it comes off backorder.
| DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) | GulfCoastGhostHunters | Audio | 503 | 01-23-2012 12:21 AM |
| DIY: Turn Signal Mirrors | CameronJr9 | Lighting | 221 | 12-16-2011 11:09 AM |
| upgrading your electrical system | CivNick | I.C.E., Electrical, Security, & Navigation | 9 | 08-28-2006 09:08 PM |
