#222 (permalink) |
David P.
In the picture it looks like the wiring is going to the center of the car but you said you ran it up the weather stripping. I assume this is the left door weather striping nearest to the fuse box not the right door stripping, am I correct?
#224 (permalink) |
D rock
Mute button for x50 8500 in switch box
I modified the mute button from the hard wire smart cord with a blank from the switch box for the fog lights and vsa buttons to fit in place of a blank. I am thinking about making a few and selling them, let me know if your interested
#225 (permalink) |
Scott
Yes.. I ran it in the weather stripping on the left side and then tucked it into the A frame and ran it up that into the ceiling liner.. didn't even have to take anything off.. I'll post a picture up in a minute when I get done eating.
#234 (permalink) |
The King - Justin
Will hardwiring the car adapter process work the same with doing it to an XM radio reciever? Im thinking of getting rid of the clunky adapter since it isnt long enough to hide in the arm rest.
#235 (permalink) |
Mark
You need a female adapter to hard wire a sirius. Unless there is some other way to do it...I bought the female and popped ot the ACC adapter and tapped into the positive and negative from there.
#236 (permalink) | |
Derek
Great DIY hope it is similar to my LX sedan 07. |
#238 (permalink) |
i ran the wires on the side pillar and underneath the steering wheel. i actually made the hole bigger in the center console so i can put cord in but small enough to cover it with the mute button.
#240 (permalink) |
Scott
Oh and it's not that hard to pop out the tweater on the dash and run the power cable out the back side of it. It required no dremeling and the tweater sat flush when reinstalled. Then you can run the cable down the crack of the windshield to wherever you want it. I noticed many ran it across the pilar where it can be seen.
| DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) | GulfCoastGhostHunters | Audio | 503 | 01-23-2012 12:21 AM |
| DIY: Turn Signal Mirrors | CameronJr9 | Lighting | 221 | 12-16-2011 11:09 AM |
| upgrading your electrical system | CivNick | I.C.E., Electrical, Security, & Navigation | 9 | 08-28-2006 09:08 PM |
