#1 (permalink)
![]() Join Date: Jun 2005
8thcivic.com member #15
DIY: ECU Removal
This is an easy job. All you need is a 10 mm wrench. Takes about 5 minutes to remove the ECU. I took quite a few pics so they pretty much speak for them selves. Sooo, here we go:
To benefit from the performance gains: http://www.hondata.com/reflash_06_civicsi.html Quote:
![]() * 4500 rpm VTEC point * Rev limiter raised to 8600 rpm. * 15-25 Hp gain midrange * 15-29 ft lb torque gain midrange This is the ECU located right next to the battery ![]() First we'll need to remove the battery. To do this, remove the bracket by loosening this screw ![]() ![]() Loosen the battery connectors, then remove. ![]() ![]() Once you've pulled the battery out, remove these 3 screws on the ECU. ![]() ![]() ![]() Once you have removed the screws, there are tabs holding the plastic cover on as indicated by the arrows. Push them through with your fingers. Pull plastic cover off. ![]() Voilla! ECU. ![]() Located directly behind the ECU are 3 connectors. We need to disconnect these to remove the ECU. The tabs (as indicated by the arrows), is what releases the connector. Using your finger or thumb, push down on the tab. While you are pushing down on it, flip it up. ![]() ![]() Once all 3 connectors are disconnected, pull out ECU. ![]() ![]() TA DA!
You're welcome everyone. I had fun doing this DIY.
Oh, and if I might add, the total turn-around time from removing the ECU, sending it to hondata, having them reflash it, send it back to me, and installing it again, was 44 hours.
#12 (permalink) | |
Member # 4524
![]() Join Date: May 2006
#13 (permalink) | |
#16 (permalink) |
jerad
how much performance did u get from the reflash and how much did it cost?? do u know if it voids ur powertrain warranty or anything like that? i heard that u can take it to the dealer and they will do the reflash for u....is that true??
#17 (permalink) | |
To have the reflash done you have to send the ECU out to Hondata in California, but you don't pay them, you pay a Hondata dealer, or middleman if you will. I paid $595 for the reflash, this included Hondata returning the ECU via FED X/overnight shipment. I paid around $25 additional to overnight it to Hondata. A dealer cannot deny warranty simply because you have changed a part - see the Magnuson-Moss Warranty Act. Basically, a dealer has to honor the warranty unless they can prove the part you changed caused the fault. e.g. altering your wheels & tires should not effect a warranty claim on the a/c. This sounds straightforward but often things fall into a gray area. For example, supercharging the engine and then trying to warranty a transmission failure. Did the transmission fail because of the extra engine power? Much depends on the relationship with your dealer. Hope this helped. |
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/15347-diy-ecu-removal.html
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-18-2008 05:40 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-11-2008 05:10 AM | |
| Electrical - 8th Generation Honda Civic Forum | This thread | Refback | 01-01-2008 01:14 AM | |
| DIY Bumper and Headlight Removal | 06blaksi | Lighting | 153 | 12-09-2011 09:31 PM |
| Si Rear Sway Bar on CSX | iluvmycsx | Suspension | 24 | 06-08-2010 05:36 PM |
| Reflash GONE BAD | dobiejoe | Mechanical Problems & Technical Chat | 51 | 10-14-2006 12:58 AM |
| 2006 Civic Console Removal | Pugman | Do It Yourself Articles | 3 | 05-22-2006 12:53 PM |
