Old 06-12-2007, 11:48 PM   #21 (permalink)
udumkid's Avatar
I/E/RH NO REFLASH
Before disconecting the battery,make sure you have your radio code.
udumkid is offline   Reply With Quote
Old 06-17-2007, 06:25 PM   #22 (permalink)
Very good info. This site is going to come in real handy!!
myke_g323 is offline   Reply With Quote
Old 06-17-2007, 06:26 PM   #23 (permalink)
#1 Post Whore
07mugencivic's Avatar
ToE kNeE
why did you take it off...........
Old 06-17-2007, 06:28 PM   #24 (permalink)
''CA'' All day.
Zeuceone's Avatar
for the hondata reflash like she said.
Originally Posted by Zeuceone View Post
For a good time call 909 418 8773
Old 06-23-2007, 03:34 AM   #25 (permalink)
Anti-Fanboy Patrol
atruhondagrl's Avatar
Bump for those who need it.
Thats what she said.
http://s52.photobucket.com/albums/g31/atruhondagrl/The%20Z/?action=view&current=IMG_9050-3.jpg
My Z/ My Si
atruhondagrl is offline   Reply With Quote
Old 06-28-2007, 10:35 AM   #26 (permalink)
does hondata reflash R18's ECU????????
Black Arrow is offline   Reply With Quote
Old 06-28-2007, 02:47 PM   #27 (permalink)
Go Pack!! 11-5
2fast4u2's Avatar
8thcivic.com member #15
Nope.
2fast4u2 is online now   Reply With Quote
Old 07-11-2007, 11:58 PM   #28 (permalink)
why you want to take it off?????
cchuang is offline   Reply With Quote
Old 07-12-2007, 01:03 AM   #29 (permalink)
Go Pack!! 11-5
2fast4u2's Avatar
To benefit from the performance gains:
http://www.hondata.com/reflash_06_civicsi.html
The K20Z3-06Si reflash lowers the VTEC point to 4500 rpm, advances the cam angle and raises the rev limit to 8600 rpm.
We have implemented a VTEC window from 4500rpm to 5800 rpm.
* Below 4500 rpm the K20Z3 is always on the low cam
* Above 5800 rpm the K20Z3 is always on the high cam
* Between 4500 rpm and 5800 rpm the K20Z3 is on the low cam at part throttle switching to the high cam at full throttle.
This one reflash will work well with a variety of aftermarket performance parts. It will work well with:
* An intake
* Cat-backs (as long as they are less restrictive than stock)
* A race header *
* A combination of intake and race header
(*Note that current race headers eliminate the catalytic converter and will generate a check engine light. This engine check light is for emissions and will not affect the car's performance. Race headers are for offroad use only)
You must have a minimum of an intake or header.
It is not designed to work with a stock 06/07 Civic Si and will lose power between 4500rpm and 5600 rpm if installed.
The 06 Civic employs a mass air flow sensor that automatically adjusts the air-fuel ratio for increases in air flow from intakes and race headers. Race headers will not cause this engine to run lean.
The VTEC switch point on this reflash is very smooth - much smoother than previous reflashes. With a stock air box and race header the switch point is virtually undetectable. For the reduction in VTEC "kick" and aural stimulation, we apologize, but this is the path to maximum power.
Power is gained in the midrange from 4700rpm to 6300 rpm. Power gains above 6500 rpm are negligible, although the higher rev limit will raise average power a little.
As this reflash will work with a combination of aftermarket parts we have two examples of the effect of the same reflash on two 06 Civics. (Both Civics dynoed at about 195 stock HP)
* 4500 rpm VTEC point
* Rev limiter raised to 8600 rpm.
* 15-25 Hp gain midrange
* 15-29 ft lb torque gain midrange
Old 07-18-2007, 10:38 AM   #30 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
^ you listed 15-25hp gain midrange, it should be torque
and 15-29 ft lb torque should be hp
Don't kill the messenger pigeon !
Old 09-04-2007, 05:10 PM   #31 (permalink)
hey man nice DIY my question is did ur quarter mile time change dew to the extra power and rpm raised?
thanks
giggity
RALLYRDSI is offline   Reply With Quote
Old 09-26-2007, 11:23 AM   #32 (permalink)
Go Pack!! 11-5
2fast4u2's Avatar
thanks
giggity
Sorry I can't answer that, as my car has never been on the track.
Old 12-09-2007, 04:38 AM   #33 (permalink)
J.K
WOW...Amazing, You guys...
J.K is offline   Reply With Quote
Old 12-09-2007, 11:17 AM   #34 (permalink)
GlxyGry06Si's Avatar
Originally Posted by udumkid View Post
Honda Reflash FTML
first of all nope. second of all what is FTML.
Old 12-09-2007, 06:39 PM   #35 (permalink)
cjackson2435's Avatar
Ceeej
ECU REflash
Where is the best place to get an ECU reflash for 07 civic si sedans besides staight from hondata cuz 600$ is way to much
cjackson2435 is offline   Reply With Quote
Old 03-12-2008, 02:03 AM   #36 (permalink)
MurderedCivic's Avatar
R18
could you reflash a R18 ?
MurderedCivic is offline   Reply With Quote
Old 03-12-2008, 02:45 AM   #37 (permalink)
Acorns!
webby's Avatar
hondata has no reflash for the r18 currently.
cjackson -
Dealers
list of dealers who offer hondata products. You'll find most cost about the same price, because it's technically set by hondata.
webby is offline   Reply With Quote
Old 07-18-2008, 03:12 AM   #38 (permalink)
Civvic's Avatar
Kevin
awsomeee
Civvic is offline   Reply With Quote
Old 07-18-2008, 03:18 AM   #39 (permalink)
Go Pack!! 11-5
2fast4u2's Avatar
Thank ya.
Old 10-23-2008, 08:39 PM   #40 (permalink)
CivNick's Avatar
throwing it out there.
can u swap ecu?
someone with a honda data flash, and wants to sell it ,
can u just swap them? or will this cause problems with the car?
CivNick is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/15347-diy-ecu-removal.html
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-18-2008 05:40 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-11-2008 05:10 AM
Electrical - 8th Generation Honda Civic Forum This thread Refback 01-01-2008 01:14 AM
DIY Bumper and Headlight Removal 06blaksi Lighting 127 10-02-2009 01:06 AM
Si Rear Sway Bar on CSX iluvmycsx Suspension 23 11-13-2008 09:13 AM
Reflash GONE BAD dobiejoe Mechanical Problems & Technical Chat 51 10-14-2006 12:58 AM
2006 Civic Console Removal Pugman Do It Yourself Articles 3 05-22-2006 12:53 PM
