Old 09-11-2008, 09:01 PM   #1 (permalink)
acb384's Avatar
Chad
CTR Push start button DIY install w/pics and wiring diagram
I ordered and installed the Civic Type-R start button and bezel + the hazzard button.
This applies to a sedan since the coupes have the mirror controls in that spot.
This is the basic wiring diagram that I used. Its based on ones that other 8th gen users have made but I simplified it.
I borrowed that switch picture as well.
I used a fuse tap to get my +pos power (acc radio.) the -neg is a bolt near the fusebox
JDM packaging and wiring diagram!
some wiring harneses i tried...found one that fit.
i got it out of an old printer...how you do this is up to you.
close up of plug
before picture
tools and supplies (wire stripper, wire; 18-16ga for smaller stuff 14-12 for ign wires, crimps, inline taps etc.)
the lower panel pulls off and you have to get this one screw
how you make this work is somewhat up to you as well. I cut the notches so that it would snap in and then i used some ring terminals to hold it down.
looks good
getting my switch and the GND- and ACC+ leads connected to the relay..test to hear it click.
here are my connections to the IGN and 12v wires...
ran them up to the relay
tidy the wires up and get ready to re-install the dash cover
i installed the CTR hazzard switch while i was at it
here is the installed button close up
finished product in different lighting...the start button lights up but is fairly dim
acb384 is offline   Reply With Quote
Old 09-11-2008, 09:10 PM   #2 (permalink)
Seemund's Avatar
Really really good..
I have a few questions:
1- Where did you get the bezel at? How much?
2- Would this small mod VOID my warranty (Electrical part.. let's say car starts to blow fuses, etc?)
3- GOOD JOB.
Seemund is offline   Reply With Quote
Old 09-11-2008, 09:21 PM   #3 (permalink)
acb384's Avatar
Chad
1- Where did you get the bezel at? How much? I got the bezel/button + the hazzard switch on ebay from the same seller....the only one that has them as far as I know about $80 for both shipped.
2- Would this small mod VOID my warranty (Electrical part.. let's say car starts to blow fuses, etc?) I dont know... If it worries you check with the dealer.
3- GOOD JOB. THANKS!
Old 09-11-2008, 09:29 PM   #4 (permalink)
for pictures to load.
0720Steve is online now   Reply With Quote
Old 09-11-2008, 10:11 PM   #5 (permalink)
pics are taking a while but looks very detailed I may consider doing this mod thx
bill717 is offline   Reply With Quote
Old 09-12-2008, 01:51 AM   #6 (permalink)
menotakoala's Avatar
Joe
Start Button Housing (Click Here)
1A) While you're at it, might want to consider the CTR hazard switch; the CTR Upper Gauge cluster; the lower gauge cluster; and the CTR Steering Wheel which has RED stitching.
Very much will void your warranty if it is found to be the root cause all your fuses blowing out. If you however ask the stealership to do this for you, then no.
3- GOOD JOB.
menotakoala is offline   Reply With Quote
Old 09-12-2008, 11:20 AM   #7 (permalink)
acb384's Avatar
Chad
Yeah...its definetly a 56k no-go.
I could have made them a bit smaller, but its nice to see the details of your considering doing it. All of the pics are 1mb or less....my host is probably the weak link.
Old 09-12-2008, 11:27 AM   #8 (permalink)
acb384's Avatar
Chad
Originally Posted by menotakoala View Post
Very much will void your warranty if it is found to be the root cause all your fuses blowing out. If you however as the stealership to do this for you, then no.
If your confident in your wiring skills and do a good job you dont have to worry about fuses blowing. It wouldn't void the whole car warranty but if it causes a specific problem...say a bad ignition switch it would void the warranty on that. I also doubt a dealer would install it for you.
Old 09-13-2008, 06:27 AM   #9 (permalink)
att Minion
Huckleberry's Avatar
Jesse
i wish there was someone nearby that would be able to help me out on this..
http://farm3.static.flickr.com/2025/2714869979_81026334fa_o.jpg
August 6, 1969 – October 21, 2003
Huckleberry is offline   Reply With Quote
Old 09-18-2008, 03:52 AM   #10 (permalink)
''CA'' All day.
Zeuceone's Avatar
for pics to load. my FIOS is slow i guess
Originally Posted by Zeuceone View Post
For a good time call 909 418 8773
Old 09-18-2008, 06:38 PM   #11 (permalink)
jackolee's Avatar
dude this is a great job. im going to do this soon now
jackolee is offline   Reply With Quote
Old 09-19-2008, 03:37 AM   #12 (permalink)
jackolee's Avatar
Hey how did you run the yellow and white wires for the ignition?
like did you cut the original wire and used that clip to rerun it from the brown harness to the relay?
what happened the other part i was connected to?
Old 09-19-2008, 03:55 AM   #13 (permalink)
''CA'' All day.
Zeuceone's Avatar
wish the pics would load.
Old 09-28-2008, 02:39 AM   #14 (permalink)
dt07Si's Avatar
Dave
You didn't have mirror controls?
dt07Si is offline   Reply With Quote
Old 09-28-2008, 02:49 AM   #15 (permalink)
jackolee's Avatar
the sedan mirror control is around the window controls
the coupe is on the dash
Old 09-28-2008, 02:52 AM   #16 (permalink)
dt07Si's Avatar
Dave
ahhh...coupe owner here
I guess the only alternative for the coupe owner is drilling a hole in the dash or taking out the hazard button...
Old 09-28-2008, 02:54 AM   #17 (permalink)
jackolee's Avatar
OR!!!
get creative, get the sedan door handle(im not sure if it fits) and swap everything lol
Old 10-02-2008, 12:15 AM   #18 (permalink)
honda_racer07's Avatar
Great job I just ordered mine tonight!
honda_racer07 is offline   Reply With Quote
Old 10-02-2008, 12:36 AM   #19 (permalink)
jay3151's Avatar
Juan Carlos
so how does it work really. u stick key in and then turn once its locked it u hit the switch to turn on engine?
jay3151 is offline   Reply With Quote
Old 10-03-2008, 05:28 PM   #20 (permalink)
SpareNoExpenses's Avatar
Scott
Where are the power mirror switches? Do Si's not have them?
SpareNoExpenses is offline   Reply With Quote
DIY: push start button ( wiring diagram) BATANG CITY JAIL Electrical 556 12-08-2009 12:45 PM
Push Start Button? BigNose Civic SI 1 06-13-2008 03:56 PM
push button start. sickyute Do It Yourself Articles 26 02-17-2008 08:15 PM
push button start? NHBP07 Inside and Out 4 05-29-2007 02:58 AM
S2000 Push Button Start Install Guide unplugged Inside and Out 30 10-21-2006 12:01 PM
