CTR Push start button DIY install w/pics and wiring diagram - Page 4 - 8th Generation Honda Civic Forum
Old 12-10-2008, 08:40 PM   #61 (permalink)
WeNoh NHBP FA5's Avatar
Vino
Originally Posted by 0720Steve View Post
just to clarify, is the brown harness under the steering wheel or the dash near the fuse box? can't quite tell by the pictures. going to go home and do this tonight.
Brown harness under the steering wheel!
and should i be using 1, 2, or 3 different grounding locations? can the 2 off the switch be combined into one wire and then grounded? or 2 separate wires to the same ground....or 2 wires to 2 different grounding locations?
same with the positives on the button, can those wires be connected and then one wire extended to the power?
I combined both the ground and power wire on my install.
WeNoh NHBP FA5 is offline   Reply With Quote
Old 12-10-2008, 08:42 PM   #62 (permalink)
0720Steve's Avatar
thanks man. i'm just wondering it is it best to run the ground wires independently to 2 separate grounds......
i think it would be ok to combine the power wires, but the grounds i am skeptical of. not sure why.
0720Steve is offline   Reply With Quote
Old 12-10-2008, 08:55 PM   #63 (permalink)
Vino
^just make it easy and combine the ground wires
Old 12-10-2008, 09:02 PM   #64 (permalink)
Zeuceone's Avatar
Old 12-10-2008, 09:11 PM   #65 (permalink)
TW_FA5's Avatar
Waiting for your results 0720Steve.
TW_FA5 is offline   Reply With Quote
Old 12-11-2008, 01:55 PM   #66 (permalink)
0720Steve's Avatar
is there a gauge wire that would be too small for the wires hooked up to the PBS? the wiring on this connector can't be but an 18 or 20. super small.
too small for the positives, grounds and wire to the relay?
if it needs to be upgraded then this plug thing won't work well, if at all.
Old 12-12-2008, 11:11 AM   #67 (permalink)
0720Steve's Avatar
i tried tapping the cigarette lighter. but it didn't work. what am i missing?
Old 12-14-2008, 02:57 AM   #68 (permalink)
Sam Oh
Originally Posted by acb384 View Post
I have a few questions:
1- Where did you get the bezel at? How much? I got the bezel/button + the hazzard switch on ebay from the same seller....the only one that has them as far as I know about $80 for both shipped.
2- Would this small mod VOID my warranty (Electrical part.. let's say car starts to blow fuses, etc?) I dont know... If it worries you check with the dealer.
3- GOOD JOB. THANKS!
can you please tell me the seller so i can order it on ebay?
blueboi87 is offline   Reply With Quote
Old 12-14-2008, 09:00 PM   #69 (permalink)
Vino
Items for Sale by plijokkjiu46521kkjh
Old 12-19-2008, 01:26 AM   #70 (permalink)
0720Steve's Avatar
this is how i ended up doing mine.....
Old 12-19-2008, 01:39 AM   #71 (permalink)
Zeuceone's Avatar
I can haz???!
Old 12-19-2008, 01:41 AM   #72 (permalink)
Zeuceone's Avatar
Old 01-07-2009, 01:22 AM   #73 (permalink)
joon joon's Avatar
used this write up but made my oem looking harness... no hacking up of the incar harness except i ran the relay ground to the ebrake... everything else is plug and play all soldered no splicing
joon joon is offline   Reply With Quote
Old 01-07-2009, 01:25 AM   #74 (permalink)
KMM
KMM's Avatar
Thee Mike Koscow (maybe)
good thats what I like to hear, if you use shrink tubes thats even better
KMM is offline   Reply With Quote
Old 01-07-2009, 11:58 AM   #75 (permalink)
joon joon's Avatar
yeah solder and use shrink tubes... very rare that i use electrical tape to wrap something up... most of the tape i used was for the loom
Old 01-07-2009, 02:31 PM   #76 (permalink)
joon joon's Avatar
im redoing some of the harness i did so i guess ill take pics of that since its not in my car...
Old 01-07-2009, 03:59 PM   #77 (permalink)
joon joon's Avatar
here are the pics of some of the harness...
this is the part
this is the yellow ignition wire... i cut it and put spade connectors (yes i know its the not the best thing haha) so that i could connect them to use the key since right now the key wont work to turn the car on, only the button will work... if i put the connectors together then i could use the key and button to start the car...
then 2 of these wires go to the relay and 1 goes to the button and those will be loomed also when i connect them back in the car..
Old 01-09-2009, 01:28 PM   #78 (permalink)
joon joon's Avatar
does anyone know how to get the button brighter??
Old 01-09-2009, 01:44 PM   #79 (permalink)
Vino
You would have to change the value of the resistor to a lower one (think its 18K-ohms now)or if that doesn't do it, then change the LED.
Old 01-22-2009, 02:36 PM   #80 (permalink)
joon joon's Avatar
could i desolder the smd and put in a regular led?? or leave the smd and add an led??
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/116538-ctr-push-start-button-diy-install-w-pics-wiring-diagram.html
bouton start - Club Civic Quebec :: Forum This thread Refback 09-06-2011 01:57 PM
DIY: push start button ( wiring diagram) BATANG CITY JAIL Electrical 676 02-07-2012 05:14 PM
Push Start Button? BigNose Civic SI 1 06-13-2008 03:56 PM
push button start. sickyute Do It Yourself Articles 26 02-17-2008 08:15 PM
push button start? NHBP07 Inside and Out 4 05-29-2007 02:58 AM
S2000 Push Button Start Install Guide unplugged Inside and Out 30 10-21-2006 12:01 PM
