Old 10-03-2008, 09:02 PM   #21 (permalink)
jackolee's Avatar
i answered this already. the sedan has them on the door handle
jackolee is online now   Reply With Quote
Old 10-08-2008, 02:48 PM   #22 (permalink)
megrog2's Avatar
what gauge are those wires for the plug that you have connected to the button. I found a very similar connector and the wires are like 22-20 gauge Im thinking they may be too small for the current draw.
megrog2 is online now   Reply With Quote
Old 10-11-2008, 04:04 PM   #23 (permalink)
honda_racer07's Avatar
I'd like to know when you turn the key on and then crank it will the engine still start? or is that now disabled.
honda_racer07 is offline   Reply With Quote
Old 10-11-2008, 04:19 PM   #24 (permalink)
''CA'' All day.
Zeuceone's Avatar
its disabled or should be.
Originally Posted by Zeuceone View Post
For a good time call 909 418 8773
Zeuceone is online now   Reply With Quote
Old 10-12-2008, 01:06 PM   #25 (permalink)
megrog2's Avatar
it depends on how you connect the switch to the ignition and starter wires. If you tap them you can still us the key, if you cut them you have to use the button.
Old 10-12-2008, 01:45 PM   #26 (permalink)
That's what I thought. Thanks!
Old 10-13-2008, 12:00 AM   #27 (permalink)
Kenpei Snail
azulsi's Avatar
Andre Claros
Originally Posted by bill717 View Post
pics are taking a while but looks very detailed I may consider doing this mod thx
got to get some T2 action man ... dump 56k
azulsi is offline   Reply With Quote
Old 10-13-2008, 12:12 AM   #28 (permalink)
2likru's Avatar
subscribed
2likru is offline   Reply With Quote
Old 10-13-2008, 01:34 AM   #29 (permalink)
After looking at the schematic of the Ignition switch it looks to me that you only want to cut the yellow wire for the starter. This would make the new start button work and the key will no longer start the car. The way it's setup in an
S2000.
Old 10-13-2008, 01:39 AM   #30 (permalink)
9900rpm's Avatar
Any way to make the ignition lock not go to the "start" position, like an S2K? Where the key just stops at the "On" position and no more?
9900rpm is offline   Reply With Quote
Old 10-13-2008, 01:44 AM   #31 (permalink)
No you wouldn't be changing that. Everybody seems to be tapping into the yellow wire and the key will still start your car. Whats the point of adding this if you can still start the car with your key? If you cut the yellow wire per the diagram 1st post then the start button is all that will start your car not the key. Similar to an S2000. Make sense?
Old 10-15-2008, 12:59 AM   #32 (permalink)
PANG S2's Avatar
Question for the OP. Does your start button dims and brightens with the rest of the dash control lights? I noticed mine doesn't do that it just stays the same.
I only did the Start Button but not the JDM hazard button. And I noticed the OEM hazard button dims and brightens just like the rest of them.
07 NHBP RDX Tech Pkg.
08 Mugen Civic Si
PANG S2 is offline   Reply With Quote
Old 10-16-2008, 02:41 AM   #33 (permalink)
acb384's Avatar
Chad
I have not been on in a while....catchin up on some questions that have not been answered.
Originally Posted by jackolee View Post
Hey how did you run the yellow and white wires for the ignition?
I used parallel taps in the yellow and white wires...nothing was cut as I wanted the key to still work as a backup. I accessed them behind the steering column cover.
so how does it work really. u stick key in and then turn once its locked it u hit the switch to turn on engine?
Put the key in
Turn it to the run position
Depress clutch
Press start button.
They are very small wires...dont know what guage. If you know what a PC fan wire is like they are about the same. You'll be using a relay which seperates the high current loads from the switch. Very little current will go through the switch.
no you cant make it physically lock at "on"...you would have to change out key mechanisim. As far as cutting or not it comes down to personal prefrence and also how much you trust your wiring. If you go all out S2k style and cut the wire and your wiring fails, your stranded. I personally left it connected.
pt 1. The switch will dim only depending on what you hook the bac wires up to. As seen in the diagram I hooked my ignition switch bac to the ACC feed. That way the start button lights up and stays on as soon as you turn the key on.
you could tap into the mph/km buttons for a dimming bac feed. but then the button wouldn't light up when you turn the key...only when the lights were on. I think my way is more badass..
pt 2 the hazzard switch is hooked up to the same stock wiring as the factory switch so of course it dims.
acb384 is offline   Reply With Quote
Old 10-24-2008, 07:17 PM   #34 (permalink)
ortivt6's Avatar
Ant
I want this so bad... how long did it take u to instaled???
ortivt6 is offline   Reply With Quote
Old 11-03-2008, 11:50 PM   #35 (permalink)
portabuddy's Avatar
Thats Mr.Bart to you!
HAY, did you guys know that its almost identical to the VSA switch... meaning that you can transfer the housings from one to another... BTW here are some Sweet inside shots
Oh and i found a bunch of aluminum rings that i can use to trim the buton. since i plan on doing it a bit differantly. but the ring needs some machining.
button.
and the LED.
portabuddy is online now   Reply With Quote
Old 11-03-2008, 11:58 PM   #36 (permalink)
portabuddy's Avatar
OH. here is the internals of the VSA...
and the housing i plan to use...(the hazzard one for the eng. and the VSA for the hazzard.)
Old 11-04-2008, 12:04 AM   #37 (permalink)
KMM
I look like rapist to U?
KMM's Avatar
Thee Mike Koscow (maybe)
^I'm so happy that we got those macro rings
I can place the rings on the lathe but it's had to balance it right by just one person I would need some one to tighten the jaws as I center it
KMM is online now   Reply With Quote
Old 11-04-2008, 12:07 AM   #38 (permalink)
portabuddy's Avatar
nono... i'll do it by hand on the polisher. anyway lets not clutter up this fine thread. I'll start one once we get closer. I just wanted to leave some cool pics here.
Old 11-04-2008, 04:47 PM   #39 (permalink)
WHAT THE f /STOP.........
WeNoh NHBP FA5's Avatar
Vino
Ok I just ordered the Push Start button and the hazard button, But I have a problem. I have the K2 foglights and the switch is in the same location that the push start button will go into. Does anyone have any ideas or solution to my Dilemma? Oh I don't want to spend more money and buy the foglight stalk and harness.
WeNoh NHBP FA5 is online now   Reply With Quote
Old 11-04-2008, 05:01 PM   #40 (permalink)
KMM
KMM's Avatar
well you can just wise the foglights right into the headlights so that they will come onwhen you turn the headlights on with out the need for a foglight switch
DIY: push start button ( wiring diagram) BATANG CITY JAIL Electrical 556 12-08-2009 12:45 PM
Push Start Button? BigNose Civic SI 1 06-13-2008 03:56 PM
push button start. sickyute Do It Yourself Articles 26 02-17-2008 08:15 PM
push button start? NHBP07 Inside and Out 4 05-29-2007 02:58 AM
S2000 Push Button Start Install Guide unplugged Inside and Out 30 10-21-2006 12:01 PM
