CTR Push start button DIY install w/pics and wiring diagram - Page 11 - 8th Generation Honda Civic Forum
Old 05-22-2009, 09:04 PM   #201 (permalink)
joon joon's Avatar
mine hasnt...
joon joon is offline   Reply With Quote
Old 06-02-2009, 08:46 PM   #202 (permalink)
HERO's Avatar
I just ordered mine today.
I wonder if it messes up the warranty... anyone know? I have an appointment Friday for a new seat belt buckle (turns out I got a factory defected one that caused my SRS light to stay on). I can ask then but for the mean while anyone know?
BTW to the OT and to Steve - thanks for the DIY insight.
HERO is offline   Reply With Quote
Old 08-04-2009, 09:40 PM   #203 (permalink)
ctboy31's Avatar
Kuya J
Originally Posted by Albrecq'sSI View Post
Just asked my dealer about it. Since they get parts from streetlightz and work with this site they are going to do it. $215 for parts (hazard switch, housing, and push start) and install. Is it worth that much?
which dealer in SanDog?
ctboy31 is offline   Reply With Quote
Old 08-04-2009, 09:44 PM   #204 (permalink)
ctboy31's Avatar
Kuya J
$80 for the whole CTR PSB including the bezel and about $45 for the hazard switch. $100 labor. i think it's worth it. are they going to warranty the install?
Old 08-05-2009, 02:06 PM   #205 (permalink)
The switch and bezel are like $40 from A&J Racing. I just got mine yesterday.
A&J Racing*::*Interior*::*JDM Parts*::*JDM Honda Start Button - Acura CSX 06+ (FD2)
jamzey is offline   Reply With Quote
Old 08-07-2009, 01:12 PM   #206 (permalink)
You don't need to use a relay because there is already a relay in the circuit.
Installed mine today. Works great. Also put in a toggle switch to turn the key off and on in case the switch fails.
Old 08-07-2009, 01:33 PM   #207 (permalink)
ctboy31's Avatar
Kuya J
my electrician installed a relay. you need one just like what both CTR PSB DIY thread asked for. key still works even without pushing the PSB just in case something happens with it.
Old 08-08-2009, 03:51 PM   #208 (permalink)
If you wire like the diagram you are installing a 2nd relay to do the same function as the existing one. I went to school at the Acura/Honda apprenticship program in Toronto so I have a bit of knowledge with cars. Also I work in the Honda engine plant in Alliston, ON and discussed this with several licensed technicians that work in our repair dept. They all came to the same concensus Honda would not design a vehicle that would allow that much current to go to the Key switch. So installing a 2nd relay is redundant and consuming power.
Also I wired in a toggle switch to be able to turn the key on and off in case my switch fails.
Old 08-08-2009, 03:54 PM   #209 (permalink)
ctboy31's Avatar
Kuya J
ic. mine does not have a toggle switch, but the key sitll works even when the PSB doesn't. how much for that school? any website for that to get infos.
Old 08-08-2009, 04:00 PM   #210 (permalink)
I went in the early 90's and Honda paid for it books and all. Kinda ironic I work at the factory now...lol.
The school is Centennial College.
Full-Time Program 8682 - HONDA CANADA INC. - AHAP
Old 08-08-2009, 07:09 PM   #211 (permalink)
av911's Avatar
It's also redundant to have a toggle switch to be able to turn the key.
Old 08-08-2009, 07:30 PM   #212 (permalink)
Post
Touche...lol. Yes it is indeed. I wanted my key to be disabled but wanted a backup if the switch ever failed. So really it does have a function. Unlike the relay who's job is being done by the factory relay. To each his own.
Old 09-26-2009, 11:34 PM   #213 (permalink)
cbp27's Avatar
Clayton
I have a coupe too and don't like the idea of drilling a hole in my dash. What if this JDM Honda Jazz Button fit into the Blank VSN Off plug?? Then you may be able to put the engine start button into the original hazard button hole? Just an idea...
Here's a link to the Fit's hazard button with a picture below:
A&J Racing :: Interior :: JDM Parts :: JDM Honda Hazard Switch - Honda Fit/Jazz 06-08 (GD3/GD4)
CTR Push start button DIY install w/pics and wiring diagram-image.php.jpeg
cbp27 is offline   Reply With Quote
Old 09-27-2009, 12:19 AM   #214 (permalink)
av911's Avatar
http://www.8thcivic.com/forums/6254820-post517.html
I changed it to a VSA button recently.
Old 09-27-2009, 12:25 AM   #215 (permalink)
joon joon's Avatar
i think someone was saying that the button will work in the space where the power outlet is..
Old 09-27-2009, 12:59 AM   #216 (permalink)
cbp27's Avatar
Clayton
You mean the power button will fit in power outlet like in the picture below? Guess that's okay.
CTR Push start button DIY install w/pics and wiring diagram-ag_08civicexl_int-2.jpg
Old 10-10-2009, 02:09 PM   #217 (permalink)
hondahead814's Avatar
Chris
how do you do the type r hazard button? does it just swapout with the stock one?? sry im really bad with electric jobs.
hondahead814 is offline   Reply With Quote
Old 10-10-2009, 02:25 PM   #218 (permalink)
joon joon's Avatar
yeah sorry i didnt get back to u.. but yeah, i read somewhere it'll fit.. where that arrow is pointing in that pic...
the hazard button is a direct swap
Old 10-14-2009, 12:12 PM   #219 (permalink)
MECPFORYOU's Avatar
So I was looking over this great diy but, I became a little confused when he said he tapped in to the ignition wire when it is really the starter wire..idk just throwing it out just incase some one really hooks this up to their ignion wire and then there car doesnt crank. Im not trying to knock the diy cause its a great one.
MECPFORYOU is offline   Reply With Quote
Old 10-14-2009, 05:21 PM   #220 (permalink)
av911's Avatar
Who cares what it's called? Tap it into the yellow and white wire.
LinkBack to this Thread: http://www.8thcivic.com/forums/electrical/116538-ctr-push-start-button-diy-install-w-pics-wiring-diagram.html
bouton start - Club Civic Quebec :: Forum This thread Refback 09-06-2011 01:57 PM
DIY: push start button ( wiring diagram) BATANG CITY JAIL Electrical 676 02-07-2012 05:14 PM
Push Start Button? BigNose Civic SI 1 06-13-2008 03:56 PM
push button start. sickyute Do It Yourself Articles 26 02-17-2008 08:15 PM
push button start? NHBP07 Inside and Out 4 05-29-2007 02:58 AM
S2000 Push Button Start Install Guide unplugged Inside and Out 30 10-21-2006 12:01 PM
