Upgraded injectors + cold start = rev hang - Page 8 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > ECU Tuning Information
Old 03-02-2010, 04:45 PM   #141 (permalink)
Supa Ninja's Avatar
Nick
Originally Posted by BlueSi4 View Post
Doing this towards the end of the week, I know Nick is gonna be like "It was about time "
Thanks guys!
Supa Ninja is offline   Reply With Quote
Old 03-02-2010, 04:46 PM   #142 (permalink)
BlueSi4's Avatar
Oriol
I knew it!
BlueSi4 is offline   Reply With Quote
Old 03-03-2010, 02:05 PM   #143 (permalink)
BlueSi4's Avatar
Oriol
I went to NAPA and the only thing they had was the thread sealant
Old 03-07-2010, 02:59 PM   #144 (permalink)
BlueSi4's Avatar
Oriol
Jay, what size is the bottom part of the valve? A 23mm??
Old 03-07-2010, 03:01 PM   #145 (permalink)
Supa Ninja's Avatar
Nick
I beleive it's cresent wrench size
Old 03-07-2010, 03:58 PM   #146 (permalink)
SBD Mode
A 15/16" wrench works perfectly.
becauseHONDA™
mucter is offline   Reply With Quote
Old 03-07-2010, 05:31 PM   #147 (permalink)
BlueSi4's Avatar
Oriol
I bought a 21mm but it's too small, gotta return it and pick up something else that will work.
The mod is halfway done, I mean, it's done but it's ghetto rigged lmao
Old 03-07-2010, 05:33 PM   #148 (permalink)
SBD Mode
15/16" (or maybe 24mm) open end wrench should get it done. You'll need some serious elbow grease too. Honda used some sort of "Incredible Hulk" thread locker on that ish.
becauseHONDA™
Old 03-07-2010, 05:33 PM   #149 (permalink)
Teegs's Avatar
Matt
come on now ladies...
Teegs is offline   Reply With Quote
Old 03-07-2010, 05:35 PM   #150 (permalink)
SBD Mode
Seriously, my wrench started to bend before it finally popped. I thought it was going to snap.
becauseHONDA™
Old 03-07-2010, 05:37 PM   #151 (permalink)
BlueSi4's Avatar
Oriol
I KNOW!!
I was trying to do it at first with an adjustable, and it almost snapped and the nut didn't even move
Old 03-07-2010, 05:52 PM   #152 (permalink)
Supa Ninja's Avatar
Nick
I must have had my wheaties that morning, it was no big deal.
Old 03-08-2010, 02:58 AM   #153 (permalink)
VitTuned 4tw
VitViper's Avatar
Weak wrench IMO.
Or user error.
http://flashprotuning.com - FlashPro Video Tutorials, Displays and the Home of the eDyno | MyVTECBroke.com - My Si... and stuff.
Got a turbo, S/C or N/A K20 or R18? Don't get scammed, get a QUALITY eTune from the most established and reputable eTuner in the community @VitTuned!
VitViper is offline   Reply With Quote
Old 03-08-2010, 09:09 AM   #154 (permalink)
BlueSi4's Avatar
Oriol
Originally Posted by VitViper View Post
Weak wrench IMO.
Or user error.
I haven't tried it with the 24mm, so I can't say. But after taking the filter and a few things out, space was very limited and couldn't apply that much force to it. The BOV is in the way too, might have to remove that in order to get a better grip
Old 03-08-2010, 06:31 PM   #155 (permalink)
Pete
My valve tip just broke off as i was trying to pull the hose off so was planning to plug the holes up. The only real question i have is will this throw any cels.
habred24 is offline   Reply With Quote
Old 03-08-2010, 06:55 PM   #156 (permalink)
Supa Ninja's Avatar
Nick
no cels
Old 03-08-2010, 06:56 PM   #157 (permalink)
David
Been there, done that! Definitely won't throw any CELs.
OrdnanceMarine is offline   Reply With Quote
Old 03-08-2010, 07:07 PM   #158 (permalink)
Heh. So I did this yesterday, and I didn't feel like pulling my blower off to unscrew it. So I just sawed the one side, and snapped that bia bia in half with a pair of vise grips. Came off rather easily with a 15/16 socket and 1/2" breaker bar. :o Oh, and by the way, this works with the stock modified injectors that come with the CT kit. I just need to ask Jay a few questions. - Sent you a message. Or Vit if you could help maybe..
Edit: Ah heck with it I'll just post here to see if I can get help. Ok, so as stated, I went ahead and got rid of the IABT (or AAV) valve. I have the modified stock 520CC CTE injectors. Everything seems to run like a champ after the car comes to temp and the valve is supposed to be closed. (Shifts even seem smoother but maybe it's placebo effect.)
Anyhow, when the car is still cold, and I'm babying it around the development here I get a bit of resurgence when shifting from 1st gear to neutral. So to give a for instance. I start the car let it idle for a minute or so, then I begin to slowly baby it on my way to the stop light out of the development. On the way to the stop light, I don't go above 1-2 gears. So lets say I'm coasting down the street at 6 MPH in 1st. I'm coming to the intersection to turn, so I throw it in neutral and coast to an easy stop before turning. When I go from 1st -> neutral, it seems I get a bit of resurgence. The AFR's drop to about 11.5-12, the engine seems to "stumble" a bit, as if there was a slight surge and in 2 seconds it rebounds right back to normal low load operating AFR. (14.7 or so). I am assuming this is coming from the car thinking the IABT valve is present and the car still being cold. Anyhow - how do I remedy this? Someone please enlighten me.
keefer is offline   Reply With Quote
Old 03-08-2010, 08:28 PM   #159 (permalink)
SBD Mode
Keith, you might want to try the idle learn procedure. It might help with that bit of weirdness when the engine is cold. I noticed that at first as well, but it went away with time.
Let car cool completely.
- Take off negative battery terminal for 10 seconds.
- Reattach positive battery terminal
- switch key to II(run) position for 10 seconds
- start car
- Rev to 2900-3000 RPM for 7 minutes
- leave the car on, and let idle for 15 minutes.
becauseHONDA™
Old 03-08-2010, 08:34 PM   #160 (permalink)
Supa Ninja's Avatar
Nick
- start car
I've never once done that, oh well mine idles fine.
getting rid of rev hang k20los Hondata 9 12-25-2009 04:16 PM
Rev Hang gbawol Cobb Tuning 9 12-11-2009 11:57 AM
SI rev hang? pr0gress Dealership Experience 18 06-13-2009 11:11 PM
"Cold Start" Issue Fuel injectors Spray Pattern? Pir8pete Forced Induction And Nitrous 62 06-07-2009 10:49 AM
Rev Hang changes when cold Si Speed 317 Mechanical Problems & Technical Chat 8 01-20-2008 05:59 PM
