Upgraded injectors + cold start = rev hang - Page 7 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > ECU Tuning Information
Old 02-18-2010, 05:02 PM   #121 (permalink)
soxfan143's Avatar
Originally Posted by mucter View Post
I think a lot of it has to do with the turbo you're using... if it's too large for the engine, then it'll feel peaky as the power rushes on. My car is really easy to boss through corners, I love the torque, it's amazing and very easy to control.
I've also been working on a new throttle map though.... this has given me the ability to have complete control over the torque output in 1st/2nd gear. And a much broader throw of pedal when trying to put down a moderate amount of torque. I'm thinking that it'll be the key to me getting the car down the 1320 on these all seasons.
Yea my car is the same way. The power delivery is awesome.
Originally Posted by VitViper View Post
It does depend on the turbo selection, but when you're running 23-25psi on even a small turbo it has quite a kick in the ass, even with throttle modulation (it spools so fast that you go from nothing to OH SHYTE WE'RE MOVING in a split second).
lol..So true.
soxfan143 is offline   Reply With Quote
Old 02-18-2010, 05:30 PM   #122 (permalink)
If the S/C setups had a good aftercooler that didn't require running water to it (scary, imo), the S/C setups would be very good options. As it stands right now they are 'meh'. They do however provide very linear power, and as such make an awesome choice for a track car since you're not dealing with the spike in power from spooling a turbo.
the set up for the aftercoolers is the same as say cobras use. and they are very safe and reliable. heat exchangers that use water vs air are way better at cooling.
vtecmike1 is offline   Reply With Quote
Old 02-18-2010, 08:01 PM   #123 (permalink)
Supa Ninja's Avatar
Nick
I second that!
Supa Ninja is offline   Reply With Quote
Old 02-18-2010, 09:14 PM   #124 (permalink)
wrecked's Avatar
Jason
just another thing i have to add to my list of stuff that needs to be done to my car.
wrecked is offline   Reply With Quote
Old 02-18-2010, 09:21 PM   #125 (permalink)
VitTuned 4tw
VitViper's Avatar
That may be so, but I'm hesitant to trust it since a leak spells disaster.
http://flashprotuning.com - FlashPro Video Tutorials, Displays and the Home of the eDyno | MyVTECBroke.com - My Si... and stuff.
Got a turbo, S/C or N/A K20 or R18? Don't get scammed, get a QUALITY eTune from the most established and reputable eTuner in the community @VitTuned!
VitViper is offline   Reply With Quote
Old 02-19-2010, 01:46 PM   #126 (permalink)
Under Moderation
skunk2civic's Avatar
Chris
Just use e85 then .. Like me
skunk2civic is offline   Reply With Quote
Old 02-19-2010, 01:48 PM   #127 (permalink)
VitTuned 4tw
VitViper's Avatar
That would work if I didn't have a 2 hour round trip to fill up on e85.
Old 02-19-2010, 04:34 PM   #128 (permalink)
ditto.
45 min for me each way. i'm just gonna do meth i think. its cheaper and more effective then simply aftercooling.
running both would be ideal but i think meth alone will be awesome.
raises octane too so its kinda like mini e85 lol.
Old 02-19-2010, 05:20 PM   #129 (permalink)
Under Moderation
Chris
Haha. I'll be ordering my meth kit soon, and a hondata 4bar map sensor, and smaller pulley, then get it re tuned. My e85 station is 10 mins away.
Old 02-19-2010, 09:02 PM   #130 (permalink)
what injectors are you using again? you'll need very large ones for e85
excited to see your results.
Old 02-20-2010, 12:26 AM   #131 (permalink)
Supa Ninja's Avatar
Nick
5 min from a E85 pump, got to get the tune first. I'm finally in texas you'all!
Old 02-24-2010, 02:33 PM   #132 (permalink)
Str8JDM's Avatar
Full Race FA5
is this good to do with stock injectors?
Str8JDM is online now   Reply With Quote
Old 02-24-2010, 02:35 PM   #133 (permalink)
VitTuned 4tw
VitViper's Avatar
You shouldn't have to with the stockers.
Old 02-24-2010, 02:51 PM   #134 (permalink)
Str8JDM's Avatar
Full Race FA5
reason i ask is because I will be installing a turbo kit with Fuel Injector Clinic injectors in about a month. but because i dont have too much time in the shop, i am trying to do everything i can to utilize as much lift time as i can.
Old 02-24-2010, 02:52 PM   #135 (permalink)
SBD Mode
It won't hurt the car with the stockers, so if you want to do it ahead of time. Go ahead.
becauseHONDA™
mucter is offline   Reply With Quote
Old 02-24-2010, 02:52 PM   #136 (permalink)
Str8JDM's Avatar
Full Race FA5
thank you for the quick answer. add that to the pre shop install list
Old 02-24-2010, 04:01 PM   #137 (permalink)
David
I beg to differ. This made a huge and immediate difference and I have stock injectors. If you haven't reduced the idle RPM curve at points below the temperature that the assist valve closes then you won't notice the rev hang as much because your engine is reving so high to begin with. If you do adjust the idle RPM at these points then it becomes obvious and was totally fixed by pulling the vacuum line.
OrdnanceMarine is offline   Reply With Quote
Old 02-24-2010, 04:10 PM   #138 (permalink)
VitTuned 4tw
VitViper's Avatar
I never had a problem with the stock injectors, but I felt no need to lower the cold start idle below 1800 back then anyway.
Old 02-24-2010, 04:19 PM   #139 (permalink)
David
That probably explains it. I'm actually going to bump some of the settings back up ~100 RPM from where I have it as it takes about 6 cylinder compressions to start when the coolant temp is ~50F but only 2 when it is ~100F.
Old 03-02-2010, 04:21 PM   #140 (permalink)
BlueSi4's Avatar
Oriol
Doing this towards the end of the week, I know Nick is gonna be like "It was about time "
Thanks guys!
BlueSi4 is offline   Reply With Quote
getting rid of rev hang k20los Hondata 9 12-25-2009 04:16 PM
Rev Hang gbawol Cobb Tuning 9 12-11-2009 11:57 AM
SI rev hang? pr0gress Dealership Experience 18 06-13-2009 11:11 PM
"Cold Start" Issue Fuel injectors Spray Pattern? Pir8pete Forced Induction And Nitrous 62 06-07-2009 10:49 AM
Rev Hang changes when cold Si Speed 317 Mechanical Problems & Technical Chat 8 01-20-2008 05:59 PM
