Go Back   8th Generation Honda Civic Forum > Welcome > Driving Experience
Old 01-21-2007, 06:18 PM   #1 (permalink)
Asian Hamster's Avatar
David
Question Confused about process for best mpg
Which is better to do, have the throttle wide open to maintain speed in a higher gear or shift down to a lower gear and only depress the throttle a little. If I'm in a lower gear the engine is spinning faster which I believe requires more fuel. So if I'm going up a slightly steep hill, and it requires me to press the gas all the way down to maintain speed, is this better or worse than shifting down and maintaining the speed at the cost of higher engine revolutions but less depression of the throttle? I hope you can understand what I'm trying to ask here. Thank you.
Asian Hamster is offline   Reply With Quote
Old 01-21-2007, 10:45 PM   #2 (permalink)
Bleached's Avatar
If you're talking about going uphill, then definitely downshift. It's not about fuel economy in this case. It's about Engine strain. It's not good for the engine to pull the car uphill at low RPMs.
Bleached is offline   Reply With Quote
SI city mpg increase after first oil change? RedSIinPA Civic SI 35 02-02-2008 12:22 PM
All those with MPG questions read this uscgbeachbum Civic Coupe And Sedan 32 12-14-2006 12:28 PM
Traded my 06EX for a 07SI because of poor MPG magpilot Civic Coupe And Sedan 75 11-08-2006 09:33 AM
R-18 gives it up. Great MPG!!! psyshack Civic Coupe And Sedan 73 10-14-2006 02:57 PM
