DIY: Automatic Window Up - 8th Generation Honda Civic Forum
Old 05-11-2008, 09:36 PM   #1 (permalink)
ok i wasnt able to get all of the pics because i used my sisters camera to take them and she deleted them thinking i didn't need them :-/ i did take a few with my phone, they look alright but i do remember exactly what i had to do so il outline it and if anyone needs any help tell me and il help out
after a little playing around with wires i was able to find out which wire was which and where the best place to attach the module. i found that taking out the fusebox gives you better access to the wires behind it which gives you access to all the wires you need except the driver window which you have to pass through the driver boot.
btw im using this module Car Alarm Window Rollup by Asianwolf Vehicle Security Manufacturer with this diagram
ok so first disconnect the positive battery terminal
then proceed to take apart the fusebox to get access to the wires behind it.
driver
Yellow/Silver UP
passenger window
Orange/Silver UP
rear passenger
Blue/Silver Up
rear driver
Green/Silver Up
door unlock
teal/white
the only wire you have to cross through the driver door boot is the yellow up wire for the driver window, which to me was a PITA.
lets take a look at the diagram supplied with the module we get 2 wires per window, we got a constant 12v, and a ground on the main harness and then on the little harness we have + and - trigger and accessory.
what we have to do is find the UP wire for each window and cut it, that does NOT mean splice it, you have to cut the wire in two and then you have two sides to the wire, one that goes to the switch and one that goes to the window motor. you can connect the windows in any order you like. just remember to keep in mind which side goes to which and connect the corresponding wire. you can get most the wires you need behind the fusebox. if you connected it right your window should work correctly when you use the driver door switch or any switch for that matter.
what i did was cut all the wires connect all the stuff and then when i put everything back together i checked with my multimeter if i got the right wires, you MUST check every wire with a multimeter, not a continuity tester.
then for the red constant 12v i tapped into the big white wire on the side of the fusebox and ground you can connect to anywhere u like, i used this screw that was already being used as a ground for sum factory stuff.
then we get to the little harness this is where we get the automatic up. you have to connect the door lock trigger to the blue - trigger on the module and then get an accessory from somewhere, i used the radio accessory.
if you have wired everything right then you should now have automatic window up on lock. this thing is pretty smart i know some of you are probably thinking if its connect to the lock trigger then your going to get your window rolling up when you lock car when its on, well it doesn't. if the car is on the module detects the ACC wire and doesn't activate, itll only work when the car is off. im going to try to get some pictures to make this DIY better. later il check the DIY as im writing it on the fly. please point out my errors in spelling or if you need clarification dont be afraid to ask.
CorntoeGoblin
CorntoeGoblin is offline
Old 05-13-2008, 07:43 PM   #2 (permalink)
tcd2004's Avatar
seems like a pretty good idea. some better pictures and step-by-step would be great!
tcd2004 is offline   Reply With Quote
Old 05-14-2008, 01:04 AM   #3 (permalink)
av911's Avatar
Subscribed!
Old 05-15-2008, 11:11 AM   #4 (permalink)
Fickle1's Avatar
Is there any way to get this to work with the factory alarm for the trigger? IE hitting the lock button twice? Also is it possible to use one of the outputs to close the sunroof (I have a coupe)? Thanks for the writeup!
Fickle1 is offline   Reply With Quote
Old 05-15-2008, 11:41 AM   #5 (permalink)
realxlai's Avatar
M. Bison
any info for how to do it on the coupe?
realxlai is offline   Reply With Quote
Old 05-16-2008, 12:19 AM   #6 (permalink)
Fickle1's Avatar
I think this may be the factory alarm trigger. Can anyone confirm?
I found it from the wire guide:
Factory Alarm Arm - orange (-) dr kick or MICU, 34 pin plug, pin 32
(Credit to benmunger for the last two pictures from the manual)
Old 05-16-2008, 01:15 AM   #7 (permalink)
maximus20895's Avatar
Max
Yea! I want to do this in my coupe!
maximus20895 is offline   Reply With Quote
Old 05-19-2008, 12:36 AM   #8 (permalink)
Fickle1's Avatar
Well after checking the orange wire I pointed out earlier, it doesn't seem to be the one that I need. It has a 12v constant. When the doors are locked it has a slight drop in voltage. Can anyone explain to me what a ground when armed wire should read as? I am trying to do this with the alarm as the trigger and not the door locks.
Old 05-19-2008, 12:51 AM   #9 (permalink)
oj88's Avatar
It should measure 0V (referenced to ground) when the alarm is armed (red LED besides the speedometer is flashing).
Btw, any way I can get a copy of the electrical diagram or any info pertaining to it? with the likes of the snipet you posted above can be helpful for a lot of DIYs I have in mind.
oj88 is offline   Reply With Quote
Old 05-19-2008, 03:10 PM   #10 (permalink)
Fickle1's Avatar
The pictures I posted above were posted on another thread on here. I don't have them personally. You can get the manuals at http://www.helminc.com but I don't feel like shelling out $125 for them.
Since I can't seem to find the factory arm wire, I am looking into tapping into the horn wire. The only problem I see there is if the vehichle is turned off and you hit the horn, the windows will go up
Old 05-19-2008, 03:17 PM   #11 (permalink)
illusionstwice's Avatar
The original --> "J" <--
Originally Posted by av911 View Post
Subscribed!
All paid jobs absorb and degrade the mind.
*Aristotle*
illusionstwice is offline   Reply With Quote
Old 05-21-2008, 12:22 AM   #12 (permalink)
Fickle1's Avatar
Got it working with the moon roof. Haven't tackled the windows yet. I am using the horn to trigger the module. Will have pics up in a few days.
Old 05-22-2008, 11:44 PM   #13 (permalink)
Fickle1's Avatar
Got the driver's side window done (what a pain in the ass) Will have the passenger done this weekend. I should have pics up shortly after.
Old 08-02-2008, 01:13 PM   #14 (permalink)
Izzo86's Avatar
Izzo
So how well did this work out? any fuses burn out? this DIY recommended? Cuz i been thinking bout doing this...
Izzo86 is offline   Reply With Quote
Old 08-02-2008, 01:32 PM   #15 (permalink)
ZeWind's Avatar
Ok, so What if I have power windows already. And I want to have Auto down AND auto up on the Passenger side window?
ZeWind is offline   Reply With Quote
Old 08-02-2008, 01:42 PM   #16 (permalink)
Izzo86's Avatar
Izzo
this is something diff. this is to open/close ur windows with alarm key. ur looking for this
Old 08-02-2008, 02:29 PM   #17 (permalink)
ZeWind's Avatar
Thanks
DIY - Automatic Shift Knob Replacement Cr8tive_leo Interior Style Mods 273 02-04-2012 07:37 PM
DIY: Automatic Transmission Flush mike_si_29 Do It Yourself Articles 6 12-12-2011 04:31 AM
automatic window up CorntoeGoblin I.C.E., Electrical, Security, & Navigation 61 05-16-2008 01:44 AM
front passenger window squiking noise as window goes down. rustynail Mechanical Problems & Technical Chat 3 03-20-2008 01:04 PM
DIY Window Antenna Repair 60103 Do It Yourself Articles 7 09-21-2007 09:18 AM
