Old 05-11-2008, 05:10 PM   #1 (permalink)
crush bar door dent removal?
hey i was just wondering if you guys might now if a way to repair these dents? there not really dents because they stick out a bit, the door skin on my back passenger side bent around the crush zone bars in the door making a line of about 4 dents. there was no paintloss or anything, just a few minor scratches and the dents any tips?
TUMBLER is offline
Old 05-11-2008, 06:10 PM   #2 (permalink)
sdiori's Avatar
Usually, if your door has sustained damaged into the intrusion beam, you want to replace the entire door shell. The intrusion beam cannot and should not be repaired, and its purpose is as the name suggests. However, if only the skin is damaged, then, obviously, proper repair is far more feasible. If your attempting to repair the door yourself, you can purchase some Paintless Dent Repair tools to pop the dents out, since you have no paint damage. Most of the DIY tools are going to be a multitude of spin-offs on the 'suction cup' method--that is, applying the suction cups to the door and applying enough force to pop the dents out. You can also do it the professional way and remove the trim panel and guts and guts that obscure access to the damaged area, and hammer it out from the inside. Remember to keep a flourescent light handy as its wave patterns help best to identify surface imperfections. If the sratches have not penetrated into the basecoat, 3M makes a good rubbing compound that helps alleviate clear coat scratches (3M's glaze is also good).
Hope this helps. Goodluck
sdiori is offline
Old 05-13-2008, 03:13 AM   #3 (permalink)
SpareNoExpenses's Avatar
Scott
/thread
SpareNoExpenses is offline
Old 05-13-2008, 03:43 AM   #4 (permalink)
thanks for the advice, i removed the inner door panel to gain access to the skin from the inside and i tried to rub and work the dents out. it worked to a degree the 4 main dents got smaller but it made several new smaller dents. sheesh. but i'll give the dent puller thing a try i went halfs with a friend yesterday and he's gonna test it on his z first.
have you any idea how much it would cost to replace the skin?
TUMBLER is offline
Old 05-13-2008, 08:18 AM   #5 (permalink)
sdiori's Avatar
Rear passenger side door skin, $208.38. Prices change all the time, so that could have increased by a couple of dollars.
sdiori is offline
Old 05-13-2008, 09:55 AM   #6 (permalink)
raycl's Avatar
Ray
+ labor, R&I and paint time= alot more than 208.38.
raycl is online now
Old 05-13-2008, 01:21 PM   #7 (permalink)
sdiori's Avatar
He asked for the price of the skin, not the entire repair. He's repairing it himself. There would be no need to quote the entire repair as if it were going to a body shop because that's irrelevant.
If we want to be technical about it, you're looking at a shade over $1k if a shop were doing the work. Labor rates, however, are heavily contingent on where you live. So this figure could increase or decrease should you have a shop repair it.
This includes:
FRONT DOOR
- BLEND
- R+I of Belt molding, body side molding, mirror, trim panel, ext. door handle
REAR DOOR
- Replacement of Skin (Edging, inside), iVTEC sticker
- R+I Belt molding, body side molding, trim panel, ext. door handle
Right Quarter
- BLEND
REAR LAMP
- R+I of Right Tail lamp
Rear Bumper
- R+I of Rear bumper (dropping the RT side)
Labor: 8.1 HRS
Paint: 6 HRS
sdiori is offline
Old 05-15-2008, 05:58 PM   #8 (permalink)
Wait why would the handle and inner workings need replecing if it's just the skin?
TUMBLER is offline
Old 05-15-2008, 07:30 PM   #9 (permalink)
sdiori's Avatar
R+I means remove and install. It need to be replaced, it needs to be taken off.
sdiori is offline
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Dent Removal alphapnoy2 Inside and Out 3 09-15-2007 06:17 PM
DIY dent removal firmhonda Do It Yourself Articles 32 06-06-2007 08:56 PM
Dent Removal... Bron Detailing 5 02-22-2007 02:40 AM
paintless dent removal CivicWithNav Detailing 9 12-05-2006 10:11 AM
HELP Dent Removal!!! eidling Civic SI 1 06-03-2006 05:16 PM
Powered by vBulletin® Version 3.7.0
