#25 (permalink) |
I do look like a monkey
The power stick isn't that bad of vibration. I'm thinking if you make the mounts stiff enough they'll transfer more vibration. As I've said in the original thread, 3M was opposed to being one of the hardest compounds but according to it's shore grade it's the lowest of the selections. I'm looking forward to seeing the feedback from the person that tries them. I've thought about filling mine too a while back but this is the first thread I've seen on someone trying this on our cars. I'm really curious to the comparison of other compounds.
#28 (permalink) | |
#31 (permalink) |
Well you made a good decision with 3M. I dunnoe if you drew straws or whatever to pick this one out of all your other choices but this is what I was going to use too. It's a proven compound and guarantees 100% satisfaction if not more price wise.
#35 (permalink) |
I found and added an image to the first post showing the torque values for the upper torque rod. I don't have an image or know for certain the torque specifications for the two lower torque rod bolts...Could someone with a shop manual look it up and let us know?
#36 (permalink) |
Edit: oops I got the value for the upper bolts mybad... I have corrected the info.
Install both bolts and snug them down. The sequence is the oil pan (horizontal)first followed by the subframe bolt (vertical). Torque the oil pan bolt to 65 ft-lbs then torque the subframe bolt to 69 ft-lbs. Got the info straight from my Helms. Sorry, I'd post a pic but I have no scanner and my camera is downstairs =X. Last edited by mad monkey; 05-02-2008 at 07:56 PM. |
#37 (permalink) |
either my clutch is gone or the epoxy dogbone is doing it's job. the car does not wheel hop in the rain any more. launching in the rain usually results in wheelhop in one place, but now it just wheel spin. also the mount broke in and now it is more enjoyable to drive.
#39 (permalink) |
ive been researching this for a long time now, and i couldnt figure out what material i wanted to use, but im really glad that someone figured it out, and jw but in an above post vythai said he couldnt chirp third anymore, if the mounts are stiffer then wouldnt that be the opposite?
| Ongoing DIY: Motor Mount Injection/Inserts | blueroadster | Do It Yourself Articles | 24 | 04-30-2008 08:19 PM |
| Broken Motor Mount ? | 07_FG_4Dr_S.i. | Mechanical Problems & Technical Chat | 4 | 04-09-2008 01:27 AM |
| 06 SI, oil pan crack, broken motor mount ? | VinValintino | Civic Coupe And Sedan | 2 | 02-13-2008 03:33 AM |
| Motor mount bolt shifted? | speedys4 | Mechanical Problems & Technical Chat | 12 | 04-17-2007 01:43 PM |
| Bad Motor mount - rattle on right front side | leonsphinx | Mechanical Problems & Technical Chat | 15 | 03-14-2007 04:33 PM |
