Old 04-10-2008, 09:28 PM   #1 (permalink)
mdbrich's Avatar
Best way to wire 4 Ohm Type-R to amp?
Ok, I have been curious on what the best method to hook my subwoofer up. I have looked around on the internet about how and yadda, spend hours got nothing. So I turn to you guys here is what I am working with:
1. Alpine Type R 4OHM Dual Voice Coil Sub
(Enclosed in a Single Box, Just Hooking up the one subwoofer)
-=Link=-
Alpine Type R 1500 watt/Amplifier DUB 400 watts - eBay (item 220220007266 end time Apr-12-08 22:14:27 PDT)
2. Memphis 500 Watt amp
Power Output RMS 250 Watts x 1 @ 4 Ohm 500 Watts x 1 @ 2 Ohm
-=Link=-
eBay Motors: Memphis Audio 16-st500d amp amplifier 500 Watts system (item 250231432918 end time Apr-06-08 12:45:53 PDT)
I just want the best possible method for installing this. I have not worked with many Dual Voice Coil Subs, and I want the best from this setup. I was wondering how I would run 4 wires through the box, when it only takes two wires, to both voice coils. Anyone someone please enlighten me!!!!
mdbrich is offline
Old 04-10-2008, 09:40 PM   #2 (permalink)
ooskers's Avatar
Subwoofer Wiring Diagrams
ooskers is offline
Old 04-10-2008, 09:52 PM   #3 (permalink)
mdbrich's Avatar
ok next question i have another amp that pushes 200w rms at 4ohm, how could i use both amps?? Hook one amp up to each voice coil?
mdbrich is offline
Old 04-10-2008, 09:59 PM   #4 (permalink)
ooskers's Avatar
I suppose, but you are best off running both coils in a parallel series to create 2 Ohm of resistance. The amps must be identical for that situation. And if I recall, you may need a special type of amp for that. Connecting two amps to one sub is not a great idea.
This should help: Matching Subs & Amps
ooskers is offline
amp turn on wire 08CivicSiGG I.C.E., Electrical, Security, & Navigation 5 01-25-2008 12:14 AM
1/0 Gauge amp wire FG207Si Mechanical Problems & Technical Chat 17 09-29-2007 09:27 AM
Amp turn on wire. Slug I.C.E., Electrical, Security, & Navigation 24 08-05-2007 06:56 PM
Amp Wire? 2006silver I.C.E., Electrical, Security, & Navigation 3 01-25-2007 12:16 PM
