Old 06-10-2006, 01:01 PM   #1 (permalink)
taste's Avatar
Question Too Early for Tranny Flush??
This is a great weekend to flush the tranny since the wife and kids are going out of town. A great time to do alot of things actually.
Anyway, the MT LX has exactly 4062 miles on her, with plenty of 4k - 6k sweeps on the tach. 75% highway, 25% city, and my last tank was my best yet at 36mpg's. Is it too early to flush the tranny or is now the right time?
I have access to the oil, a buddy's got like 9 leftover quarts of Redline MT-90 I can have. From what I've read, I think I'd rather use the MTL than the MT-90. Any ideas?
So obviously the R18 and the Si motor don't have a dipstick to check the fluid level, we use the filler bolt to check. Where the heck is the drain bolt? I haven't been under there for that purpose yet, it may be staring me in the face. Simple drain and fill right, 1.7 quarts?
taste is offline   Reply With Quote
Old 06-10-2006, 02:49 PM   #2 (permalink)
Tuna Fiddle
twistedframe's Avatar
Dave
this early it would be a waste of money IMO. Wait until you have some miles on the car (i think they recomend every 15k-30k to replace the tranny fluid.)
Old 06-10-2006, 08:17 PM   #3 (permalink)
CivicWithNav's Avatar
make sure honda approves MT-90 fluid.
some require SPECIFIC fluid some require general fluid.
my Jeep needed "jeep specific" manual tranny fluid and or a GM synchromesh or it destroys synchros
so do your studying before you do anything
BUT it is never early to change fluids. Keeping it fresh will only be beneficial
and as far as the drain plug goes, it should be in the manual. I don't have a manual but i'm willing to bet it's on the driver side. two bolts. fill and drain. DO NOT OVER FILL
Old 06-10-2006, 09:10 PM   #4 (permalink)
Photobucket
Silver8th's Avatar
I second that.
Old 06-10-2006, 09:39 PM   #5 (permalink)
av911's Avatar
Does '06 Civic have a transmission filter?
If not, just drain and refill?
I've never changed trans fluid before. BTW, I have 15,000+ miles on it.
Old 06-10-2006, 11:48 PM   #6 (permalink)
kenchan's Avatar
i usually don't flush tranny fluid early. just follow the factory schedule.
Old 06-10-2006, 11:53 PM   #7 (permalink)
Tuna Fiddle
Dave
Yes but it is internal and therefore non-servicable. Almost every honda transmission has an internal transmission oil filter which is not servicable without rebuilding the whole tranny.
Old 06-11-2006, 01:45 PM   #8 (permalink)
06SILVERSI's Avatar
I once heard from the President of Spoon Sports JP said to change your transmission fluid and Oil at the same time ALWAYS!! But you'll be fine following the service schedule!!
06SILVERSI is offline   Reply With Quote
Old 06-11-2006, 06:41 PM   #9 (permalink)
I just recently switched to Redline MTL, car now has roughly 6000 miles.
Result came out great, better shifts than stock Honda MTL, I say do it!
Leonardo629 is offline   Reply With Quote
Old 06-11-2006, 08:28 PM   #10 (permalink)
BLU BY U's Avatar
omg give me a break, every oil change? waste of oil.
Old 06-11-2006, 09:02 PM   #11 (permalink)
I change tranny fluid every third oil change on my MT Civic and on my AT Accord. I also did tranny fluid flush and change on the first oil changes at 5k miles.
psyshack is offline   Reply With Quote
Old 06-13-2006, 09:17 PM   #12 (permalink)
DNieves's Avatar
Manual transmission fluid change
Guys, I haven't had a M/T since my RX7 blew an apex seal a couple of years ago. I never changed the fluid but the shifts were perfect. I know you have to stay on top of an Auto transmission maintenence because the fluid can get dark/burnt and the filter can clog with metal shavings & pieces of internal bands & etc. What's the process involved in changing the M/T fluid? What type of fluid does Honda recommend?
DNieves is offline   Reply With Quote
Old 06-23-2006, 07:55 PM   #13 (permalink)
Car78412's Avatar
changing the MT fluid would be difficult unless you had a lift. The car must be level to check the tranny oil through the fill plug. Unless you plan to jack the car up onto 4 jack stands, refilling the tranny would be difficult with only one side of the car raised.
Car78412 is offline   Reply With Quote
FYI '06 Si owners - Early oil consumption Janizary Civic SI 38 08-19-2006 12:18 AM
New GG Si owner in early June... OHSiGuy Introduction & Pictures 15 05-19-2006 04:37 PM
A-Pillar cover not flush with body WayneBike Mechanical Problems & Technical Chat 7 05-15-2006 06:46 PM
early xmas gift ideas for me webby Water Cooler 2 03-13-2006 01:35 PM
So this morning I get a call... EARLY... BlackSIguy Civic SI 13 02-15-2006 10:11 AM
