Old 04-06-2008, 11:53 AM   #1 (permalink)
Nate
Exhaust easy install?
Basicaly I'm not a very handy person. At the same time, I do hate paying people to do things that I should be able to do myself. I have a 07 Si Sedan and am planning on buying the skunk2 cat back. I have 2 good jack stands and basic tools, no torque wrench.
Is the exhaust just bolt on? Will I have to grind anything cut anything to get the old exhaust off and put the new exhaust on?
Mr Big is offline
Old 04-07-2008, 02:45 AM   #2 (permalink)
Chris
the exhaust bolts right up
streetmachine02 is offline
Old 04-08-2008, 09:06 PM   #3 (permalink)
08_Civic's Avatar
Bboy
Depending on how hard the bolts and stuff are bolted on... If so then you will have to grind/Cut it..
08_Civic is offline
Old 04-08-2008, 09:08 PM   #4 (permalink)
naptown08si's Avatar
Ryan
nah just a little bit of elbow grease for some of the bolts.
naptown08si is offline
Old 04-14-2008, 12:01 PM   #5 (permalink)
7002iSciviC's Avatar
Andrew
its just bolt on I replace my stock Si exhaust system with skunk2 60mm. the oem exhaust is straight bolt on no need to use power tools just a wrench and muscle SPECIALLY the bolts by the catalyst convert.
over all easy simple straight forward to do, as long you know how to tighten up and lossen up a bolt YOUR GOOD TO GO
7002iSciviC is online now
Old 04-18-2008, 03:37 AM   #6 (permalink)
Chris
raise the car high enough for your body to fit under the exhaust and have room to put pressure on the bolt to break it loose. use penetrating catalyst to break free the corroded nuts. a breaker bar to help loosen the nuts and bolts. all the tools to get the job done help.
Old 04-18-2008, 07:21 AM   #7 (permalink)
Civic06SiR's Avatar
Sam
Just make sure you have a lift, it's easier that way.
Civic06SiR is online now
DIY: Easy Low Beam Install [Super White Halogens] Tang841 Do It Yourself Articles 19 07-11-2008 10:09 PM
06-08 civic coupe SI easy after-market tail light install darken0420 Civic SI 13 01-06-2008 03:18 PM
HFP body kit easy install? cronerd Introduction & Pictures 1 12-21-2007 12:15 AM
How easy is it to install the Hondata IMG......... Dwn4nythng Bolt-Ons And All-Motor 14 05-20-2007 05:11 PM
K2 Fog light install...is it as easy as OEM?? REv2Red Lighting, H.I.D.'s, & Neon 13 04-03-2007 07:13 PM
